Question about HP LaserJet P3005n Printer
P3005n did you ever resolve your issue of the tray 2 jamming?
Tray 2 has a little piece of cardboard that can easily be overlooked. you'll probably have to pull it out by sticking your hand in the back of the printer, tray 2. can't be done from the front because the cardboard piece keeps tray 2 stuck, and gives paper jam errors.
Posted on Oct 08, 2008
Getting error jam in tray 1 in hp printer
Check tray 1 pick up roller, paper sensor, clean registration sensors..check any paper particles jammed inside..
Apr 10, 2011 | HP LaserJet P3005n Printer
LaserJet 2420 Printer: hp 2420n 13.20.00 jam inside rear door...
i have 2420 dn printer..printer reddy mode the power on...but not initlizing...13.20 paper jaming error coming but paper is not jam..hw to resolve
May 06, 2010 | HP LaserJet 2420 Printer
Issues with HP Laserjet P3005n
That means that the output tray is filled to capacity, or one of the students broke the "bin full flag" at the top of the printer.
Feb 24, 2010 | HP Hewlett Packard LaserJet P3005n Printer
I had a paper jam and I took the back off and this
Step one: Remove any loose paper
Remove all loose paper from the input and output trays.
1. Turn off the product.
2. Unplug the power cord from the back of the product.
3. Push the button on either side of the rear-access panel or the duplexer (two-sided printing accessory) and then remove the panel or duplexer.
4. Find any jammed paper inside the product, grasp it with both hands, and then pull it out of the product, toward you.
5. If the product has a duplexer, push the latch on the top of the duplexer and lower its cover.
6. Carefully remove any jammed paper.
7. Close the cover.
8. Reinsert the rear-access panel or the duplexer into the product.
9. Plug the power cord back into the product.
10. Turn on the product.
Step three: Open the top cover and clear the jam
3. Open the carriage access door. The carriage moves to the right side of the product.
4. Gently pull the paper out of the rollers.
5. After clearing the jam, close the carriage door.
6. Plug the power cord back into the product.
7. Try printing a document.
· If the issue is resolved, do not continue troubleshooting.
· If the issue continues, proceed to the next step.
Step four: Clear the jam from paper tray 1
1. Remove all paper from the output tray.
2. Turn off the product.
3. Unplug the power cord from the back of the product.
4. Lift the output tray and then check for jammed paper in input tray 1.
Use these steps to remove any jammed paper.
a. Raise the output tray.
b. Grasp the jammed paper and pull it out of the product, toward you.
c. Lower the output tray.
5. Plug the power cord back into the product.
6. Try printing a document.
· If the issue continues, and if paper tray 2 is not installed on the product, proceed to 'Step six: Clear the jam from the automatic document feeder (ADF).'
· If the issue continues, and if paper tray 2 is installed on the product, proceed to the next step.
Step five: Clear the jam from paper tray 2
4. Lift the product off tray 2.
5. Remove the jammed paper from the bottom of the product or from tray 2.
6. Reposition the product on top of tray 2.
7. Plug the power cord back into the product.
8. Try printing a document.
3. Remove the ADF input tray and open the ADF cover.
4. Remove the jam cleanout part. With both hands, lift up on the two handles until the part unsnaps. Rotate and lift the cleanout part and then set it aside.
5. Lift the green lever attached to the pick mechanism and then rotate it back until it stays open.
6. Check the ADF paper path for jammed paper.
7. Check for jammed paper where paper enters the ADF paper cleanout.
o If the paper comes out with gentle pulling, proceed to step 9.
o If the paper does not come out with gentle pulling, follow these instructions.
1. Open the ADF, and then use both hands to gently loosen the paper.
2. When the paper is free, gently pull it out.
3. Close the ADF.
8. Lower the green lever.
Reinstall the jam cleanout part. Push down on the two tabs until the part snaps into place.
9. Replace the ADF input tray.
10. Check the following to make sure that the ADF frame and parts are secure and correctly set up.
o Make sure that the ADF frame is secure and attached correctly.
o Make sure that the ADF cleanout part attachment is secure. If it is loose, push down on the two tabs until the part snaps into place.
o Make sure that the ADF pick mechanism is secure. Lift the green lever attached to the pick mechanism and then rotate it back until it stays open.
Make sure that the two-catch is holding the roller mechanism securely in place and that the stack stopper is in the correct position.
1 - Stack stopper
2 - Two-catch
11. Plug the power cord back into the product.
12. Turn on the product.
13. Try printing a document.
Jan 01, 2010 | HP Officejet Pro L7680 All-In-One Printer
HP laserjet P3005n. Cannot get jobs to print from bypass tray (1)
It could be a flag issue or sensor issue but, you should always try the easy stuff first. Check to see if the manual feed is on. To do this:
Press the check mark and arrow down to configuration menu
Press the check mark and arrow down to printing menu
Press the check mark and arrow down to manual feed, highligt the on and press the check mark.
In this setting the paper (if present) should pull from tray 1 first.
Let me know if this resolved the issue, if not, we can try another test.
Dec 14, 2009 | HP LaserJet P3005n Printer
Hp printers continue to jam
Print a self-test report Use the following steps to print a self-test report.
  1. Load plain white paper in the input tray.
  2. Press Setup , and then press 2 . The Print Report menu displays.
  3. Press 1 to select and print a Self-Test Report .
IMPORTANT! Try to print a self-test report after every solution even if the solution resolves the issue. Solution one: Clear the paper jam Follow these steps in the order presented to resolve the paper jam. Step one: Remove loose paper from the tray Remove any loose sheets of paper from the input tray and the output tray. CAUTION: Do not remove jammed paper at this stage. Trying to clear jammed paper from the front of the product can damage the print mechanism
Sep 08, 2009 | HP OfficeJet 6110 All-In-One InkJet...
P3005n prints one sided fine, but jams in fuser on duplex
Lower the rear door ALL THE WAY DOWN past the 2 stops
Remove the 2 screws, pull off rear cover
Remove the small left rear cover and small right cover
Unplug the 2 small plugs on the right side.
Remove wires from white clip.
Remove large white plug on big circuit board
Remove 2 screws and pull out fuser
Look for a switch knocked off
Feb 13, 2009 | HP LaserJet P3005n Printer
New HP Laser Jet P3005n is not printing and amber light is flashing, it's telling me that the printer is out of paper and it's full.
I'm a certified technician. Paper sensor flag has come out of position. Did you have a jam that you had to clear before this problem or was the pick-up roller replaced recently? Even HP's service manual has the wrong pictures for replacing the tray 2 pick-up roller on this machine.
Jan 07, 2009 | HP LaserJet P3005n Printer
Hp p3005n keeps getting paper jam error in tray 2 like every other page it prints and there is no paper jammed. I replaced the printer with a new one and get the same annoying error. So when you printing a...
I had the same problem, the transfer roller rubber was completely slick and would not pick up paper (it would also make a clicking sound).
Replaced it and the problem went away.
Jun 11, 2008 | HP LaserJet P3005n Printer
HP LaserJet P3005n Printer Logo
272 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
