Question about Hitachi 53UDX10B 53" Rear Projection Television
Will not come on
52 hitachi would shut off while watching now it will not turn on at all will this be pricey to fix
  • 927 Answers
Good Day, codysdad0331;
Before calling an Authorized Service Center, try unplugging TV from wall for 3 to 5 minutes plug TV back into A/C outlet (reset). If no fix call "ACS". Average cost for you TV is about $650.00 depending on shop, location; always get a written estimate. Good Luck, big IRISH.
Posted on Sep 09, 2008
I have an RCA 52" screen TV and I was watching tv and all of a sudden the picture went blank and then the TV shut off. When I try to turn the tv on all i get is a scratching noise and then it turn off. can...
Hello again you need to Rate my solution other wise they are not going to pay me! since i did give you correct answer to fixing your TV ThanK You Replace 3 capacitors cp150 2200uf use 25v and cp114 cp120 220uf 35v.
Dec 19, 2009 | RCA HD52W58 52" TV
My 50 inch samsung plasma tv turns off and on by itself. it also clicks while this happens.
My Samsung 52" plasma TV will shut off while watching TV. It will do it repeatedly and we have to turn it back on. Is it overheating and shuts down? How can this be fixed?
Oct 27, 2009 | Samsung HP-R4262 42 in. Plasma Television
Hitachi Ultravision 50in will power on but no picture or sound!!!
Replace Ballast Board it is what turns Lamp on! Call Encompass for Part 1-800-638-3328
Sep 26, 2009 | HP Pavilion MD5020N 50" DLP HDTV
Our RCA high-def 52 inch TV is shutting off on
It has you Posted as a projection TV and Not DLP, if Fan to Lamp stops running set will shut off to protect Lamp,I had a DLP that would play sometimes 30 mins then shut off drove me crazy trying to firgure it out and it turn out to be Fan would stop running I replaced Fan TV working fine . When you remove back engage toggler switch to up position put a piece of tape on it to hold it is a safty switch ,then turn tv on watch to see if all fans are running also if when tv trys to come on is there a spark coming from Ballast Board if so your new Lamp is defective it does happen if not your ballast board maybe Bad it is what turns on Lamp.If all fans are running Ballast Board.
Sep 22, 2009 | RCA HD52W56 52" Rear Projection HDTV
Hitachi Ultravision Projection Tv problem
Hitachi TV also Model # 46UX7K, Serial # W1H002013. I was hoping I can get help with this one too. The picture is dark and has lost most of it's color. I don't know if the color is off because it is so dark. Is there parts that I can buy from you to fix this problem.
Aug 09, 2009 | Hitachi UltraVision CineForm 55VG825 55"...
52 INCH RCA REAR PROJECTION SHUTS OFF
Your TV is overheating.. easiest remedy is to point a fan at the back of the TV or... clean the inside of the TV, Im sure its full of dust and stuff... this prevents air circulation inside the TV thus creating more heat...
Jun 19, 2009 | RCA HD52W56 52" Rear Projection HDTV
Tv turns off
sounds like a bad solder connection i usually fix these problems for a very fair price call tv shop but i'm 90% sure dad solder
May 02, 2009 | RCA HD52W58 52" TV
I Have a hitachi 52 inch tv, that we were watching one day and it just turned off and wont come back on, what do you think is the problem and how much to fix it?
You need a professional.
Stop using the TV until it is repaired.
Continue to use it and your problems will multiply and grow more expensive.
Call the manufacturer to find you nearest authorized service center.
MR. TV Sales & Service Inc
Milwaukee Wisconsin 53405
(414) 762-8600
Established 1974
Mar 24, 2009 | Televison & Video
Remote for hitachi 52 inch projection tv not working
1st step, replace battery of remote, no result, 2nd step, check / replace Remote Sensor of TV.
Aug 02, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Hitachi 53UDX10B 53" Rear Projection Television Logo
59 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
