Question about Electrical Supplies
Runs but does not put out correct voltage
Runs but surges and does not put out enough wattage to run anything.
  • blasutton Sep 18, 2008
    I have the same problem. I took the carb totally apart, totally cleaned jets and blew out with compressed air. Cleaned the gas filter, checked the diapham and all checks good. There is a small black filter on the vacum line that let air in slow to the diapham valve which I might replace next.
    This unit was bought new after Katrina Sept '05 and ran for 2 weeks then. Always ran the gas out of carb and started several times a year. I ran it for Gustav for 3 days and it started surging the 4th day and got worst as time went on. I changed the plug nothing. If you hold the governor on the alternater at idle it run fine. Once you let it go it goes to half speed and starts to surge every 10-15 seconds. Saturday I played around with the choke flapper and throtle by hand and it stopped and ran good. I started Sunday same surge and played with the choke and throtle again and it quit. I'm afraid this thing might fail when I need it most. By the way my unit is a FG6000MK but it is a 11HP and the motor is a Wenling Jennfeng. Any help would be appreciated. Thanks
    Novelist:
  • 72 Answers
Almost 90-95% of all the Genset problems found by the factory approved Genset Service Centers are related to the fact that people don't read the OWNERS MANUAL first, and just didn't put OIL in the Genset (or the right amount) - as they are shipped from the MFR without OIL in the units to begin with!!!!
And here I thought everybody KNEW THAT!!
I guess sometimes you just have to ask the most OBVIOUS ??'s first huh (dumb as " it " may sound)?
If you bought your Genset from other then a Home Depot Store, and it's still under warranty - then you will have to contact that outlet, and see what they have to say or hopefully can do for you.
Esp all those Gensets that are Made in China and have flooded the USA market in the last 10 years or so - no thanks to our representatives in WASH DC that's for sure. It's a wonder this country even functions with all this "inferior" Made in China JUNK that keeps prematurely failing before it's normal time. Sad to say the least!
Some other obvious things to CHECK for that may be the cause of a NO start condition even after adding proper gas & oil to the brand new Genset:
1 - Some Genset gas tanks come with a gas cap "blocking insert" under the gas cap that should be removed according to your manual if it states this. (Read manual section on "First Time Starting")
2 - Is the gas tank shutoff valve FULLY OPEN? By the same token (even if the Genset is or isn't brand new) does it have an in-line fuel filter anywhere in the gas line? If not then esp read #5.
3 - Is the RUN SWITCH set to ON or RUN position (this is purely an "Electrical Switch" btw)? Is it working properly? Test it using a known good quality DVM or OHM meter! It's contacts may have become tarnished just from sitting around too long? Esp where you have saltwater conditions in the surrounding air!
4 - Is the choke being set to the proper position with or without using Ether spray to the Carb?
5 - Does the Carb have a Yellow or Black wire coming off of the bottom of the Float Bowl? This goes to the GAS CUT OFF SOLENOID mounted in the Main Jet inside the Float Bowl. NEVER CUT THIS WIRE as some know-nothings have suggested here and elsewhere in postings, as there are better ways to test the solenoid without doing that! If equipped with one - This anti-dieseling solenoid has to work properly or else flooding will occur with the gas shutoff valve OPEN.
6 - VERY IMPORTANT - Is the Float stuck in the CLOSED position not letting gas into the Main Jet? You might try and TAP CAREFULLY on the bottom or side of the Float Bowl with a hard rubber hammer first to try and see if you can dislodge the stuck Float inside. If there is a WIRE at the bottom of the Float Bowl on your model - DO NOT HIT THAT GAS SHUT-OFF SOLENOID WITH THE RUBBER HAMMER - as you WILL damage it! If this dislodges the stuck Float then your problem is solved! NEVER FORCE ANYTHING!! It's possibly that you might have to loosen slightly and/or totally remove the Float Bowl (usually 2 screws) to see if indeed any gas is getting inside to the Float at all. If gas comes out readily but still no gas is getting into the Main Jet and intake then you purely have a DIRTY CARB issue and nothing more! If you're not smelling gas through the air filter box then you are FUEL STARVED. ALSO - Many a brand new shipped Genset will have some kind of NEW gas tank (usually metal gas tanks only) MICRO DEBRIS inside the tank itself or even in the rubber gas line (I've heard of this before, and seen this myself 100's of times with cheaper rubber hoses). That is why an added in-line FUEL FILTER (if your Genset has none) is SO important!! Usually a common $2-3 item at any auto parts store. Once gas is added to the tank all this micro debris is set free to enter into the CARB FLOAT BOWL, and that is where Carb problems will start - even with a "brand new" never run before Genset!!
7 - As dumb as this next ? is to ask I have to ask anyway - Are you getting GOOD spark at the spark plug? Some units ship with the spark wire cap disconnected and it may look like it's on the plug, but in reality it really isn't fully connected! If you are getting a good spark then it's highly unlikely that the Maintenance-free Magnetron® electronic ignition would be bad. Fouled spark plug - YES - bad Maintenance-free Magnetron® electronic ignition - hardly.
8 - If your Genset is used and said to be ? years old, and it just indeed might have some high RUNTIME HOURS on it - it just could very possibly be what sounds like to me (and I personally HAVE SEEN this happen myself firsthand) that the generator brushes are nearly shot - as in almost worn out. They may be getting too too hot - as from excessive current draw at point of contact, and thus the generator sensing circuitry itself is doing an electrical CUTOUT!!
An added protective Genset circuit feature in that the generator itself may indeed be linked to the engine as a type of REV LIMITER or CUTOUT on the Maintenance-free Magnetron® electronic ignition. Again - your operators or service manual should have a pretty good troubleshooting section in it unless you don't have that anymore or never got one if you bought it used to begin with.
If you unscrew & remove the Generator brushes for servicing yourself, and they are indeed below the recommended length (or worse case they are indeed totally worn down) then that most likely is your starting or output problem right there. If you are having Output problems as well.
If you choose to replace the old brushes with new ones yourself - be very careful when seating the new ones - as to their insertion and cap retainer tightening. Never over-tighten those black plastic-like brush retainer screw caps - for if you break one (hard to get immediate replacements is why), or fracture one it could cause the Genset to fail under LOAD, and that very well could do some severe damage to the generator part itself. Take your time doing it, and be patient!!
It has to be one of the CHECK scenarios listed above, as I've covered every possible cause short of a broken wire somewhere - which in that case you will have to schematic trace and DVM or Ohm-meter out wire to wire contacts. This being the least likely scenario from experience.
If you indeed find the Float Bowl assy to be the cause of dirt contamination or varnish build-up clogging the Carb, and you need a walk-through of taking it apart, cleaning it out, and then re-assembling it again - as well as re-adjusting the fuel mixture Adjustment Screws - just give me a shout here, and I'll walk you through it step by step.
That's about all there is unless you got a Defective Genset from the start. Next stop - Home Depot!
Best regards to all with the same problems, and hope I helped you out 100% - all political humor/truth aside.
Please post me a reply as to finding this solution being the best resolve to your Genset problem there by following my recommendations above. Also please rate my troubleshooting fix as well.
Keep me posted and I'll follow up as well.
Best regards,
Frank
Posted on Sep 08, 2008
My LCDTV/DVDCOMBO , MODEL NO /3255HD ,Had a power surge from a 5.5 Kva generator , is there any internal surge protection if so were , if not which curcit board would be damaged .?
most likely the power circuits as there is no internal surge protection
have the set properly diagnosed and go from there
always use a power board with surge protection for all electronic equipment
as the voltage from a genset is reasonably well controlled , even at over rpms the voltage would not go high enough to cause damage for example a 240 volts running at correct rpms will only get to 255 volts uncontrolled rpms as the governor lever is fully open
however a lower voltage (200 volts ) increases amp flow and that is probably what did the damage
Jan 04, 2017 | Electrical Supplies
Capabilities of the Robin 2400is generator
no
ac units are 2000 watts minimum, washing machines are 1500 watts minimum, microwave is what is on the plate and start at 650 watts but most are 2000 watts
the 2400 is the peak out put for start up of fridge , washer etc and the running wattage will be 2000 watts or less ( duty cycle )
to run more than one of the nominated items at once you will be needing a 5500 to-6500 watts unit
they handle a start up surge of 6500 watts ( larger one) and will comfortably handle 5500 watts run full load
it works like this , the plate on the gen set is the surge short time load capacity of the genset and not the duty load which is 500 to 750 watts less than that plate wattage
for example your 2400 is is surge rated at 2400 watts but duty load is less than the 2000 watts
many people make the mistake of buying a gen set that looks big enough but do not calculate the maximum load capable on being put on the gen set
fully loaded uses more fuel /hr
wears out faster
has power surges as the extra load cuts in and the motor struggles to get back to required rpms for voltage and cycles
will not cover extras like lights ,
a much large gen set will take it all in it's stride , no power surges, better economy, less stress
talk with an electrician , do your maths on everything you wish to run and that which you forgot about then add 1000 watts to the duty cycle and that will be close to the gen set you require
Oct 17, 2016 | Electrical Supplies
I cannot keep this weed wacker running.
i do not think this is a voltage issue, this a wattage or power out is not enough power in watts to keep the weed eater running, you need to know what wattage the weed eater requires to run.
even though you have a generator that says it will run 3000watts, but in the generator only runs at 1500watts continuously running time until it runs out of gas.
know lets say your generate say 2000watts, that means you are only going to get 1000watts continuously unit you run out of gas.
Oct 05, 2015 | Electrical Supplies
How do you run ac units with generator
You have to be sure the generator produces not only enough power to run the AC but also to handle the load when the AC initially starts or the compressor kicks on. That means it either must have a continual wattage rating to handle the load or a surge rating that's powerful and long enough to handle the start up.
Aug 21, 2014 | Heating & Cooling
AC surge current?
you are missing the voltage supply here to get an definitive answer
for 240 volts drawing 4.8 amps the required wattage is 1152
for 120 volts the wattage is 576 watts
for 120 volts with a current of 900 watts , it equates to 7.5 amps
with 240 volts with a current of 1150 watts , it equates to 4.79 amps
so you can see the problem by not stating the supply voltage
get access to an cable clamp amp meter / watt meter from an electrician and read the current on starting the ac unit
if it exceeds 900 watts for 120 volts or 1150 for 240 volts , consider a bigger generator
Aug 31, 2017 | Fixya.com Heating & Cooling
After an overnight power outage, my computer will not turn on. You can hear the fans run when you press in the power button but everything is dead as soon as it is released. If I hold down the power button...
Sounds like the Power supply got surged. Have the power supply tested or take one from an older computer and use that to test the main board and other components.
Oct 04, 2011 | HP Compaq Presario SR2050NX PC Desktop
The generator kicked the breaker of and was smoking and smelled like electrical
What type of load (electrical) was hooked up to this generation?? If the surge voltage and current was exceeded above the generator maximum for any length of time. There problems, it could be the regulator, insulation burnt off the windings.
I am taking a guess here. Now, 7100 Watts is it typical surge wattage. This mean that the generator will deliver 7100 Watt (voltage times current) this is know as the power factor. The actual operating load would be 6800 Watts and I would even operator the generator at its peak wattage. Something in the neighborhood of 10--15% less the peak wattage. Therefore a good positive theatrical Wattage would be 5800 to 6350 operating wattage. Then this generator would run all day.
Just remember Ohm's Law. Current plays a big factor in loading of a generator while the operation voltage is at 120 AC Volts. Example: electric motor; Now electric motor when starting will pull three time its operation current. Operating current for a 1/2 HP AC motor is 6 amperes but start this electric motor will require 18 amperes. This is one reason why they starting capacitors on smaller electric motors. Larger three phase electric motor can literal stop a generator cold...in its tracks. It put such a large demand on the generator it stops the engine powering the generator. I have seen crankshaft break because the generator could handle the heavy current load.
Remember, any time you are running a small gas powered generator. All ways figure what the load and surge current load will be before hooking up any generator. Normally this is figured in VA (volt/amps). Wish you lock. GB...stewbison
Sep 05, 2011 | Robin Subaru RGX7100 7100 Watt Gas...
The output(w) is indicating o.oo and it's indicator light is red .I only have a couple of floor model fans plugged. Should it be showing something and should the light be green?
inverters run on a square voltage unlike normal 110 runs on a round voltage, the only 2 things that won't run on the inverter is fans and electric blankets
Jul 22, 2011 | Cobra 2500w Power Inverter
My new AMD Athlon II Quad 640 3g Crashes. It crashes almost once a day. All temps seem ok. the setup display says that it suffering fron power surge the cause. I have put a power surge device in the mains....
You might not have your voltage set properly in your bios and/or your power supply is either insufficient or going bad on you. Have someone test all the leads and be sure the voltage produced is as it should be. Also evaluate your system as a whole and compare the wattage -vs- the power supply you have. (i.e. running a powered vid card.. tv tuner.. two hard drives.. extra ram AND a beefy cpu on a 150watt supply is highly unlikely.)
Apr 12, 2011 | Advance AMD Athlon II X4 640 3 GHz...
We have a Valsi 5500 watt generator that isn't putting enough voltage out to run everything in out small travel trailer. It runs the lights but doesnt push out enough voltage to carry the A/C, microwave,...
How long have you had this generator?
Has the generator worked on all of these loads before?
Model 5500 is a 5500 Watt generator which could easily be 5500 watts (Peak) and not continuous.
Your AC is an inductive load.
Your lights are resistive loads
An inductive load can cause issues when starting due to an increased current demand at start up that some generators cringe under. Do the lights flicker or are they stable? I'd say your diodes on your stator are working if you have light stability but you haven't provided nearly enough information for a detailed solution.
I'm sure you have enough voltage but you aren't getting enough current to run specific loads. How many watts is your AC? How many watts for your microwave? Both of these units demand a great deal of energy to run and when you place too much demand on your generator, it will choke it out and eventually, will cause damage to the generator. You may consider getting a beefier generator with a greater amount of wattage output.
Seeing these specs online and noting what you are trying to run, you have an undersized generator and need to get one that can produce a greater amount of running wattage (as well as peak wattage).
Apr 12, 2011 | Watts Onan Portable Generator - 4000 ,...
Electrical Supplies Logo
612 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
