Question about Broan-NuTone WS330 Kitchen Hood
WS3 Broan Allure Range Hood Premier 36 inch
This hood worked fine until a light bulb blew out. Put in a new light bulb, but the lights will not turn off. Is the light switch bad or is there a problem with the control panel? The fan still works fine but the lights will not turn off or adjust dim or bright.
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 171 Answers
Hi shealy,
I'm Harvey the Master Plumber.
Your problem is: This hood worked fine until a light bulb blew out. Put in a new light bulb, but the lights will not turn off. Is the light switch bad or is there a problem with the control panel? The fan still works fine but the lights will not turn off or adjust dim or bright.
You're on the right track. The light control switch needs replacing. You might try utilizing the Repair Directory to find a repairman. If you have the tools and ability just remember to turn off the electric first.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Posted on Sep 13, 2008
  • sonia oleksuik
    sonia oleksuik Feb 23, 2014
    fan isnt working either if I fix the lights it still won't fix the fan
Lights won't turn off - everything else works fine
I have a NuTone Allure WS2 range hood. The fan works fine, so does the control board seem ok, but the lights work only intermittently. NuTone tech support said to replace the control board, which I suspect is its kneejerk response. The board costs almost $200--and for two lights???
My problem is similar to the one whose lights work, fan doesn't, but I have a feeling my problem is different.I hope simpler.
Thanks in advance for help (light) on the problem anyone can offer.
Larry R
Apr 23, 2009 | Broan-NuTone Allure III QS330SS Kitchen...
42" Allure II Broan Range Hood I put a new bulb to replace
Get two new bulbs and install them. These bulbs are exposed to a lot of heat above the stove and the filaments get brittle. I suspect that the filament on the bulb that still worked broke when you were screwing it out or back in. good luck. please rate my answer. thanks noreen.
Feb 03, 2009 | Broan-NuTone Broan Range Hoods Allure II...
My broan allure turns on by itself
Isn't it suppose to turn on automatically? The broan has a heat sensor!
Jan 08, 2009 | Broan-NuTone Broan Range Hoods Allure II...
Broan Nutone Allure lll light problem
The problem is the little lever in the socket. Turn breaker of fan off, grab a flat head screw driver and lift the little lever slighty like a 45 deg angle. If not the replacement socket assembly is
part # R111630 comes in a pair. I do service calls for broan & Nutone
We have the part: www.inventex.com
Jean-Marc
Feb 11, 2008 | Broan-NuTone Allure III QS330SS Kitchen...
Broan allure II range hood
Did you ever find out what blew the fuse originally? Do the lights have a dimmer feature on them? If so, the reostsat may be bad, or the switch that controls the light intensity, 1,2,3. ect. Something caused the fuse to blow, maybe a wire on the bulb or switch somewhere.
Dec 20, 2007 | Broan-NuTone Broan Range Hood Accessory
Controller failed when a bulb blew
Control Board: Part # R111638 = $110.00
I do service calls for Broan-Nutone
Inventex Inc
Nov 12, 2007 | Broan-NuTone Allure II QS230SS Kitchen...
Broan Allure II
I called Broan technical support. They said that they had heard of this issue before, but that there was no recall. I suggested that it was a frequent enough problem for it to come up 3 times in 12 mo. on one website. She was underimpressed with this statistic and said that they sell millions of them. She would not disclose the name of their supplier so that I could get some information on the actual controller unit. She did not seemed as pained as I was by having to part with $130 for a new controller.
Jan 30, 2007 | Broan-NuTone Allure II QS230SS Kitchen...
Broan-NuTone WS330 Kitchen Hood Logo
1,713 people viewed this question
Top Broan-NuTone Kitchen Ranges Experts
Dan Phillips
Level 1 Expert
Phil Lovisek
Phil Lovisek
Are you a Broan-NuTone Kitchen Range Expert? Answer questions, earn points and help others
