Question about Sony Ericsson Walkman W810i Cellular Phone
My phone won't restarted when the last time i took out the usb cable without stoping the software first.
My phone won;t restarted and it keeps blinking on and off . i even try to take out the memory card because i am scared of losing my data.
pls help me reply A.S.A.P
  • zafirah Sep 15, 2008
    thanks ah guru haha :) LOL
    Brigadier General:
  • 7,752 Answers
You need to take the phone and have the firmware reflash on the phone, you can do this online at topsony.com or take the phone to a repair service center and have them do it for you.
Posted on Sep 13, 2008
How to restart spooler
How are you connecting the computer to the printer? This printer can be set up to work on the wireless network, a wired network printer or as a USB printer.
First to clear the spooler completely, use the MS-DOS command window. Click Start > All Programs > Accessories > Command Prompt. (If you have Vista or Windows 7, right click on Command Prompt and choose Run As Administrator.) Type "net stop spooler" without the quotes followed by pressing enter. Press Y if you see a warning about the fax service stopping. Then type "net start spooler" (again without the quotes and followed by enter). Then restart the computer. Wait for a while before trying another print job. If you do not enter the start command, the spooler will take longer to restart.
If this is a USB printer, try a new USB cable and changing the USB port that you are using on the computer. If you use a USB hub, try a direct connection with the computer.
If this is a networked printer, you may want to restart the router.
Another thing to try is to uninstall the printer and then reinstall it. For a USB printer, make sure to unplug the USB cable before uninstalling the printer. Otherwise, your OS may install a generic printer driver which could cause additional problems. You can get the latest software and drivers for your Canon Pixma MP620 for supported OS versions here: http://usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mp_series/pixma_mp620#DriversAndSoftware . Use the drop-down menus to select the OS. Install the full software (Navigator EX) if you want to use all of the features of the all-in-one.
Please add a comment with the details of your setup for additional support. I hope this helps.
May 03, 2012 | Canon PIXMA MP620 All-In-One InkJet...
There is a problem in my mobile sumsong GT-C3303K as it is restarting itself without any reson and it is not opening just restasrting only plz help me in solving this problem
First remove the battery and leave it for about 5mins,then you install the battery back on it, then you turn on the phone, if it does the same, then it means the start upfile of the phone is corrupt and will not start up the phone and will keep doing the restarting thing.
The solution there on, is for you to have the phone flashed. To flash the phone, you will be needing the best appropriate software for the phone on a pc and the usb cable toconnect the phone to the pc, then you format the phone and reinstall its operating system back on using the software.
That way the phone will be rebooted back to the factory settings.
Hope this was helpful to you. Goodluck Elect_Comp
Aug 17, 2011 | Cell Phones
I had updated my phone software today but while installing the could not restart for that reason i removed data cable,now it cannot get start
oh this the major problem. the company srictly advises you dont remove the usb cable while updating the software.. otherwise the phone will corrupted. Next time dont remove Usb cable while Updating the software. the phone restarts automatically while updation. its a common factor......
Nov 04, 2009 | Nokia 5220 XpressMusic Cellular Phone
Computer crashes in post when printer attached
uninstall the hp F2210 update.
reinstall the print driver and software from the original CD.
Jan 12, 2009 | HP PSC 2210 All-In-One InkJet Printer
Sony ericsson k800i connection to laptop to upload phots
First uninstall all the drivers and of the phone and the software, then remove the cable usb of the phone and restart the computer, insert the software CD and install the software's while installing at one point it will ask to insert the usb cable of the phone at that time insert only the cable without the phone, after installing restart the computer again, now you can connect the phone to the USB cable, when you connect the cable, the phone will automatically ditect and wait for sometime cos the computer will install some drivers to the phone. when this is finished try using
May 09, 2008 | Sony Ericsson K800i Cellular Phone
Cant download pics from phone to computer no more...why ???
Disconnect the phone cable USB then open Nokia PC Suite (I presume you've got a Nokia N70) At the top of the PC Suite window go to Settings/Manage connections, tick the two bottom boxes, Serial Cable [CA 42] and USB cable, TWICE so as to highlight the Configure button.
Click OK, then follow the instructions to connect the cable to the USB then the other end to the phone.
It should now work if you're lucky, if not do a restart.
After restart connect the phone to the cable.
Give plenty of time for the icon on the PC to go green before clicking it to open PC Suite.
Feb 21, 2008 | Cell Phones
N73 software update
Try:
Press * 3 send at the same time and turn phone on. Keep them pressed until the reset screen appears.
Give it time to reset.
If this does'nt do it, it will need to go to a repair shop.
When updating software on Mobs, be sure to:
HAVE A FULLY CHARGED BATTERY INSERTED;
PUT IT ON GENERAL PROFILE;
TURN OFF YOUR PIN NUMBER;
CONNECT YOUR CHARGER TO YOUR MOB AND SWITCH IT ON;
DO NOT ----- DO NOT ---- TOUCH YOUR PHONE WHILE THE UPDATE IS GOING ON;
THIS CAN TAKE 30 MINUTES OR MORE.
And obviously don't unplug the phone from the PC.
Be patient, you may have to do a restart or two on your mob afterwards. Even remove the battery to get it going again (not recommended). But give it plenty of time.
It is also wise not to use your PC while updating software, just in case the PC freezes.
If the PC freezes during an update, you're up the creek without a paddle...
I did an update on a Sony Eric 810i it took nearly two hours.
More... Your phone turns itself on and off, sometimes more than once while updating software, you should leave it well alone during the update.
Before updating software you should check that there's a newer version of software available.
Feb 01, 2008 | Nokia N73 Cellular Phone
Software Upgrade
install the cd that came with the phone, once that is done and you have connect you phone via usb cable to the pc, switch on the phone then when the pc has located and recognised your phone go to the update column and the pc will search nokia site for a new upgrade.
Dec 11, 2007 | Nokia N70 Cellular Phone
Black screen, improper USB cable disconnection
You will need to flash the phone using a third party software. Before trying this hold down the '2' and '5' buttons at the same time and connect the USB cable while holding the buttons down. Keep holding them untill the computer registers the phone is there. This may force the phone to reset and start working again.
Nov 24, 2007 | Sony Ericsson K800i Cellular Phone
Sony Ericsson Walkman W810i Cellular Phone Logo
35 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
