Question about Ingenico I6550 (6550US0041)
I6550 configuration/initial install
I powered up an i6550 signature capture device, it runs through a boot sequence, and comes to a stop with the comport listing, including USB, com . . .
then it just stays there. Is there some way to activate the device? i notice there is a slot for smart card, is this a requirement to use the device? Does a manual exist?
thanks
You can find the user's manual at the URL below. From my experience, using this terminal requires active support from your POS software. It is said to work with Microsoft RMS, but I'm still trying to get mine to talk to the computer. Good luck with it.
www.ingenico.com/INGENICO_GALLERY_CONTENT/Documents/USA/products/multilane/DL00458_RevE_i6500.pdf
Posted on Oct 07, 2008
How do I unlock the Bios on an Acer ES-1 111M Laptop
To boot from a CD, DVD or USB device, make sure that the device has boot sequence priority over the hard drive.
BIOS Boot
BIOS (Basic Input Output Subsystem) is a programmable chip that controls how information is passed to various devices in the computer system. A typical method to access the BIOS settings screen is to press ESC, F1, F2, F8 or F10 during the boot sequence.
BIOS settings allow you to run a boot sequence from a floppy drive, a hard drive, a CD-ROM drive or an external device. You may configure the order that your computer searches these physical devices for the boot sequence.
The first device in the order list has the first boot priority. For example, to boot from a CD-ROM drive instead of a hard drive, place the CD-ROM drive ahead of the hard drive in priority.
Before you set boot priority for a USB device, plug the device into a USB port.
To specify the boot sequence:
  1. Start the computer and press ESC, F1, F2, F8 or F10 during the initial startup screen. Depending on the BIOS manufacturer, a menu may appear.
  2. Choose to enter BIOS setup. The BIOS setup utility page appears.
  3. Use the arrow keys to select the BOOT tab. System devices appear in order of priority.
  4. To give a CD or DVD drive boot sequence priority over the hard drive, move it to the first position in the list.
  5. To give a USB device boot sequence priority over the hard drive, do the following:
    • Move the hard drive device to the top of the boot sequence list.
    • Expand the hard drive device to display all hard drives.
    • Move the USB device to the top of the list of hard drives.
  6. Save and exit the BIOS setup utility.
  7. The computer will restart with the changed settings.
Boot Priority Options
Some computer manufacturers allow you to select the device that contains the boot sequence from a special device selection menu. The example below uses a Dell system board.
To set boot priority using a device selection menu:
  1. When the computer starts to boot up, after the manufacturer's ID screen, press F12 several times. The device selection menu appears.
  2. Use the up and down arrows to select CD-ROM or
May 04, 2015 | Acer Aspire Computers & Internet
Hi, everytime i connect my External Drive it says i need to format the disk before i can use it... and when the disk is plugged in and i try to open my computer or anything of that sort, Windows explorer...
have you tried turning on pc first and allowing it to boot. and then plugging in the external hdd?........ explorer.exe is basicly your desktop icons an such, and sometimes have probs with devices attached with a different file format.
Jan 01, 2011 | Western Digital My Book Essential 1TB...
Computer advises NOT to install as not Windows
Hi. Thanks for your question
Digital signature is a part of file added to it for security reasons. Although not every manufacturer decides to digitally sign it with microsoft. Sometimes new signatures are included in windows updates removing mysterious information about signature . As long as you know were your file comes from you are pretty safe to ignore the message from windows. Just click next and you should be just fine. If you would like to know more about this subject. This is a link to Microsoft's website "what is digital signature" - http://windows.microsoft.com/en-US/windows-vista/What-is-a-digital-signature Hope this clarified your view. Please let us know if this was helpful.
May 01, 2010 | DekCell EasyCap USB 20 Video Capture...
E-machine gets the blue screen that says.....stop 0x0000007E(0xC0000005, 0x8053A593) what does this mean
A registry error or device driver is causing this. Attempt a boot to safemode by tapping f8 after the computer boot logo screen and before the windows logo screen.
if you can't boot to safemode then try the same key sequence but select "last known good configuration". If this does not work, then you will have to repair reinstall the operating system.
if you can get in safemode or last known config, make sure to run a spyware/virus check if you didnt' install any programs, devices or used a registry cleaner like CCleaner
Feb 14, 2010 | E-Machines eMachines Desktop PC
IBM 300 GL desk top
IBM computers use the F1 key. It is critical that the keystroke is captured at the right moment in the boot sequence. Otherwise it is ignored. Start tapping the key repeatedly as soon as you turn the system on. Shortly after the memory check and mouse initialization is complete, you should get a BIOS setup menu. If you're still having problems, you might try a different keyboard since it is always possible to have a defect there.
Oct 21, 2009 | IBM PC 300GL PC Desktop
I had forgotten the password of my Cisco Catalyst 3550 Switch
password recovery procedure 3550 catalyst cisco switch
1>Attach a terminal or PC with terminal emulation (for example, Hyper Terminal) to the console port of the switch. Use the following terminal settings: ¨ Bits per second (baud): 9600 ¨ Data bits: 8 ¨ Parity: None ¨ Stop bits: 1 2>Unplug the power cable. 3>Power the switch and bring it to the switch: prompt 4>Issue the flash_init command 5>Issue the load_helper command. switch: load_helper switch: 6>Issue the dir flash: command. Note: Make sure to type a colon ":" after the dir flash.
7>Type rename flash:config.text flash:config.old to rename the configuration file. 8>Issue the boot command to boot the system. switch: boot Loading "flash:c3500xl−c3h2s−mz.120−5.WC7.bin"...############################### ################################################################################ ###################################################################### 9>Enter "n" at the prompt to abort the initial configuration dialog. −−− System Configuration Dialog −−− At any point you may enter a question mark '?' for help. Use ctrl−c to abort configuration dialog at any prompt. Default settings are in square brackets '[]'. Continue with configuration dialog? [yes/no]: n !−−− Type "n" for no. Press RETURN to get started. !−−− Press Return or Enter. Switch> !−−− The Switch> prompt is displayed. 10>At the switch prompt, type en to enter enable mode. Switch>en Switch# 11>Type rename flash:config.old flash:config.text to rename the configuration file with its original name. Switch#rename flash:config.old flash:config.text Destination filename [config.text] !−−− Press Return or Enter. Switch# 11. Copy the configuration file into memory. Switch#Type rename flash:config.old flash:config.text to rename the configuration file with its original name. Switch#rename flash:config.old flash:config.text Destination filename [config.text] !−−− Press Return or Enter. Switch# 11. Copy the configuration file into memory. Switch#copy flash:config.text system:running−config Destination filename [running−config]? !−−− Press Return or Enter. 1131 bytes copied in 0.760 secs Sw1# The configuration file is now reloaded.
Destination filename [running−config]? !−−− Press Return or Enter. 1131 bytes copied in 0.760 secs Sw1# The configuration file is now reloaded. 12>Overwrite the current passwords that you do not know. Choose a strong password with at least one capital letter, one number, and one special character. Note: Overwrite the passwords which are necessary. You need not overwrite all of the mentioned passwords. Sw1# conf t !−−− To overwrite existing secret password Sw1(config)#enable secret <new_secret_password> 13>!−−− To overwrite existing enable password Sw1(config)#enable password <new_enable_password> !−−− To overwrite existing vty password Sw1(config)#line vty 0 15 Sw1(config−line)#password <new_vty_password> Sw1(config−line)#login !−−− To overwrite existing console password Sw1(config−line)#line con 0 Sw1(config−line)#password <new_console_password> Write the running configuration to the configuration file with the write memory command. Sw1#write memory Building configuration... [OK]
Mar 24, 2009 | Cisco Catalyst 3550-24 24-Port Ethernet...
Ingenico I6550 (6550US0041) Logo
901 people viewed this question
Top Ingenico Computers & Internet Experts
Scott Fair
Scott Fair
David Payne
David Payne
Are you an Ingenico Computer and Internet Expert? Answer questions, earn points and help others
