It probably has a virus or some malware that is keeping it from functioning. Try inserting into the computer and run a scan disk or a disk cleaner on it. I did two like that yesterday with a scan disk program that appeared one day on my computer and they are fine now. Unfortunately it didn't work on the third and I had to Format it, which wipes them clean. If you are like I was didn't care if that one was wiped clean then just format it. If not try the clean-disc software in them. If you don't have anything like that on your computer, then not to worry free one's are a dime a dozen on the Internet. dhgill
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts
It might be burn. or u need install driver in ur pc or check it with differetn pc
Please un-install and then re-install your usb port drivers. refer local service tech
