Question about NetGear (RP114NA) Router
How is Port Forwarding Configured? - NetGear (RP114NA) Router
    Scholar:
  • 130 Answers
To Enable Port Forwarding for MR314 or RP114 1. Type the router's address in an Internet browser's address bar. (By default the router's address is 192.168.0.1). 2. Enter the router's username and password. 3. Click Advanced > Ports on the left menu bar. 4. Enter the first port number in an unused Start Port box. 5. If only one port number is to be forwarded, enter the same number in End Port. To specify a range of ports, enter the last port to be forwarded in the End Port box. 6. Enter the IP address of your local server in the Server IP Address box. 7. Click Apply.
Posted on Feb 19, 2006
SOURCE:
Set port forwarding with 2 adsl lines
NAT port mapping sould only be configured on the node that is connecting a LAN network (private address) with a WAN network public adddress (not 192.168...)
Aug 07, 2013 | TP-LINK TL-R480T+ Broadband Router 2xWAN,...
I have DIR-600 and using to access 2 DVR. Have configured on port forwarding both the DVR. I hav a static IP from the ISP. SO can you please suggest as to how can i connect to each DVR as the same is not...
An internet connection is the same for every wireless gadget you have in your house.
therefore instead of using them as one just connect them separately and you should have no problem.
p.s if your gonna do what i just described make sure to turn port forwarding off.
Mar 19, 2011 | D-Link DIR-600 Router
Port forwarding
This isn't a very detailed question, so I have to give you a very general answer.
Port Forwarding is configured in the "Firewall" tab of your router's configuration screens. This set of screens is described in the manual beginning on page 35. You can find the manual here:
http://www.2wire.com/pages/pdfs/5100-000326-000.Rev.A.pdf
Jul 13, 2010 | 2wire 2700HG-B Router (2700HGB)
Unable to get VPN working - have set up port 1723 TCP/UDP without success
1. Check at this phone number for tech support.
+44 - 1933 35 20 00
2. make use port forwarding is configured properly for UDP/TCP
3. check the DMZ rules.
Apr 24, 2010 | Belkin N Wireless Modem-Router F5D8633au4A
Port conflict with other service with netgear
It's telling you that there is already some type of service configured with the port you are trying to use. Confirm that the port number you are trying to forward is not listed elsewhere in the already-configured rules. or in the defaults of the router. If so, you will need to adjust the port you are using to something that does not conflict, or disable the existing rule.
Feb 20, 2010 | NetGear WGR614 Wireless Router
BL-C131 port forwarding.
So you've configured port forwarding on the router. Do you have any anti-virus applications installed or have your set an exclusion in Windows firewall?
Feb 01, 2010 | Panasonic BL-C131 Network Camera
Port forwarding not working on cisco 1811 router? Via the SDM, I have configured NAT, and verified that these settings are correct. However, our videophone application (which requires, TCP:1720,15328-15248...
Most of the CISCO 1800 series have some ACL's configured by default.
You may want to run a show run from the CLI to make sure that there isn't one interfering.
Also from the CLI, see if you can debug port forwarding. I can't remember the command off the top of my head but I will look it up and post it for you.
Oct 15, 2009 | Cisco 1811 Router
PORT FORWARDING
i have problem with my internet
Jul 31, 2008 | D-Link ADSL2/2+ Modem/Wireless Router...
Port Forwarding
Hello Just wondering If both are on the same work Group in the network settings. (Same Name) You probably did that already but if not give it a try and maybe your forwarding will resume and work properly. Hope so. Thanks
Jan 16, 2008 | Linksys EtherFast Cable/DSL Router
NetGear (RP114NA) Router Logo
805 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Mike
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
