Problem for Coffee and Espresso Makers
Generic problem for all Coffee and Espresso Makers
Espresso will not come through my Saeco Gra...
I have had this machine for some time, about 8 months ago the water was not coming through the coffee...thought perhaps it was ground too fine but that wasn't it...realized that I had not descaled it so I did and cleaned the portafilter and it seemed to work fine since until now. So I descaled it again but to no avail...thought it might be the portofilter so got a new one but that did not help....once heated up I try to make an espresso, you can hear the pump working but nothing comes out!! I am so frustrated, I love this machine and miss my coffee!!! I use a French/Italian blend of beans from a local roaster...maybe the beans are too oily and have clogged up things..what should I do can you help me!!!
Clarification Request
Posted by intisuarez on Dec 29, 2008
PS: indeed, I forgot to put in the check valve. Now I did, original problem persists. By the way, you people might be interested in this:
http://www.partsguru.com/user/0226.550.650%20Gran%20Crema.JPG
Looking forward to your insights, I.
Same Problem
Feb 04, 2009
-   water comes through without handle. Seems to be a pressure problem. Dissassembled the handle and worked fine but now has clogged up again. Perhaps the rubber has perished and now its not getting to pressure to open the mechanism.-
tomaszsawick Dec 29, 2008
-   same problem, adding that I assemble and disassembled the portafilter, and now water is coming through the screw that is holed. Probably I forgot to assemble something. Anyway, the problem is the same. -
intisuarez Oct 07, 2008
-   no water is getting into the system from the reservoir-   Guest
Best Solution
posted on Sep 09, 2008
Rank: Guru
Rating: 89%, 68 votes
Well first thing I got to ask to exclude a couple of things.
Does it come out water if you dont have the filter or the handle on the machine?
Popular Solutions for Coffee and Espresso Makers
Questions and Unsolved Problems for Coffee and Espresso Makers
Where in North-Central London can I purchase a replacement gasket for a 1-2 cup vigano stovetop...
(More)
Where in North-Central London can I purchase a replacement gasket for a 1-2 cup vigano stovetop espresso maker?
How do you disassemble the black and decker undercounter spacemaker coffee maker. I've removed the...
(More)
How do you disassemble the black and decker undercounter spacemaker coffee maker. I've removed the screw at the rear of the unit but there must be something else that has to be unlatched
My Keurig one cup maker has been malfunctioning and water and coffee grounds gush up and out the...
(More)
My Keurig one cup maker has been malfunctioning and water and coffee grounds gush up and out the sides instead of a stream down into the cup. I have been using the refillable basket with my own coffee. After cleaning/descaling twice my coffee maker still will not brew a cup without shooting the water and the grounds all over and outside of the cup. Can you please advise? Is it fixable??
