Question about Fine Digital FineDrive 400 GPS Receiver
STREET ADDRESSS SCREEN BLANK
I CAN PULL UP EVERYTHING,BUT WHEN IT GOES TO PUTTING IN THE STREET ADDRESS THE SCREEN IS BLANK,I TRAVEL ALOT AND I REALLY NEED THIS
Try removing the memory card, then performing the problematic functions, then shut off the unit. Wait 5 minutes, insert memory card, turn on unit and perform functions again, see if it works.
Posted on Oct 21, 2008
How do i use navagation on my 2013 escape
You can probably find a Manual online for that feature. What you will have after choosing Navigation versus Entertainment is 2 tabs in the upper right of the screen. One is Dest (destination) and the other Menu. The Dest will get you a screen which allows you to enter your City or State, then City. Everything is then presented by street, address number and so forth. Some screens allow for Zip code instead of typing the City.
The Menu tab allows setting choices on what type of roads you travel. You can also select notifications of Hazards, avoiding Toll roads or Ferries. You can set volume and even voice types.
Oct 19, 2014 | 2013 Ford Escape
Can't select correct street/avenue
Can you please give the make and model no. of the device.
Jun 18, 2008 | GPS
2008 Triumph Street triple instrument display not working
Hi, Chuck if some or all of your instrument cluster goes dark/blank immediately upon startup or a few minutes later riding down the road the usual suspects are:
1. Blown instrument fuse.
2. A bad ground in the instrument circuit.
3. Faulty wiring before or after the fuse.
4. Faulty wiring or connector between the fuse and the instrument cluster.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Gauge cluster died bike wont start HELP
Instrument Cluster not displaying tach neutral light speedo engine temp
Triumph Speed Triple Service Manual
https://www.triumphestore.com/
Triumph Speed Triple User Manual
Sep 01, 2017 | 2008 Triumph Street triple
When I press address it goes straight to Street. It doesn't ask what State. If I put in address....it says not found. Brenda Romero
need a lot more info .... what gps model do you have,
your saying you put address it goes straight to street? then say i put addrees it says not found
Most Nuvi units you have to press Where To...Address....and on the bottom of screen you will see Change State / Province
First select your State..... then go back and select the City... it should now let you put the number of house press done ..then the street name
Nov 06, 2010 | Garmin GPS
Dont know how you enter address as well as postcode
if you select enter city location instead of post code it will give you that option. you can leave some fields without putting anything in them to get the the street option just by selecting next or done on the screen that asked you for the city for example on the city entry option enter noting then it will give you the option for the street and number option.
Oct 24, 2009 | Garmin Nuvi 205T Sat Nav GPS Receiver
H ow do i reset my garmin street pilot c340
To reset the Garmin C340 you will need to pull the Bezel off that goes around the screen. There is a reset button under there. Make sure that is what you really want to do before you do it.
Harleyknut
Mar 30, 2009 | Garmin StreetPilot c340 GPS Receiver
Getting started
I just moved to another location - changed the start point !
Nov 05, 2008 | Tomtom ONE GPS Receiver
Can't finish typing street address or city before choices are given I don't need
If the unit is not allowing you to continue to enter the street address, press the back button until you get to the city. Press "Search All" instead of the name of the city and try the address again. It could be that the unit has the address listed in a different city (it sometimes goes by how the post office lists the ZIP code). See if this helps. As for taking the unit apart to access the reset button, all you have to do is remove the faceplate. There is an intentation under the top. Insert your fingertip and pull it forward. Carefully remove the faceplate, and the reset button is on the right hand side.
Feb 26, 2008 | Garmin StreetPilot c340 GPS Receiver
StreetPilot c 340 does not allow to enter address
Ok, you've tried a reset, but have you tried a Master Reset? Doing this WILL ERASE ALL OF YOUR FAVORITES, but it may help. Turn the unit off. Press the "On" button with your finger on the bottom right of the screen at the same time. Release the "On" button, but keep pressing the screen until the unit asks if you're sure you want to reset all data. Press "Yes". See if this helps.
Nov 04, 2007 | Garmin StreetPilot c340 GPS Receiver
Open Questions:
Fine Digital FineDrive 400 GPS Receiver Logo
60 people viewed this question
Top Fine Digital GPS Experts
ChuckyMo
drivealot
Iqbal Husain
Iqbal Husain
Are you a Fine Digital GPS Expert? Answer questions, earn points and help others
