Question about Bose Wave Music System CD Shelf System
Poor FM reception
I live not far from a mountain in the Bay area. My FM reception on my Bose Wave Music System is poor. Where can I obtain an external 75 ohm antenna? Would you please provide me with details such as price, where to buy, etc.?
Incidently I have purchased 3 such systems in the past 2 years and am obviously a devoted fan and customer.
Dr. Jerome Eldridge (stjerome2@msn.com)
16605 Englewood Avenue
Los Gatos, CA 95032
  • 1 more comment
  • Anonymous Jan 13, 2009
    poor fm reception problem
  • bpatenaude2 Feb 06, 2009
    I have poor am and fm reception on this system and not other radios
  • Anonymous Feb 13, 2009
    I have the same problem...  poor FM reception
Having paid over $1,800 for 3 Bose Wave systems in the past year, I was surprised and quite dismayed to find that Bose is trying to squeeze a few more bucks out of me in order to provide some very simple information. My Solution: I will never purchase another of your radios. Most humbly, Dr. Jerome Eldridge
P.S. You might wish to upgrade your PR Department
Posted on Sep 10, 2008
Have a bose wave and live in a metal building. Can't get hardly any am fm radio recept. 3.5 mm antena jack. Can I get an am fm antenna? And do I need to mount antenna outside?
The Bose has the option for external antenna, but uses the AC cord as the antenna, so first try stretching your AC cord to its fullest extent in a straight line, then in different directions to see if that improves the situation. This is for FM only. The AM uses an internal ferrite rod antenna, and this is sensitive to direction, so try rotating the radio in different directions to see if signal improves on AM, and place unit as near a window as possible.
If none of this helps, you will be able to use an external antenna, and no it is not mandatory that they be mounted outside ... as long as you have room indoors. In fact, several manufacturers market indoor antennas for apartment dwellers and others under restrictions against mounting antennas outdoors.
But, logically, the best way to improve reception is the largest antenna mounted as high up and as far away from obstructions between the antenna and transmitter as possible.
Good luck.
Don Miller, CET
CET Services
Bose Wave Radio Repairs
don.miller60@outllook.com
Apr 30, 2016 | Bose Audio Players & Recorders
Am fm reception bad
FM reception is weak
What to do
• Extend the power cord as much as possible. The FM antenna is in the power cord.
• Move the power cord to adjust the FM antenna
• If you still have problems with FM reception, you may need an external antenna.
* Call Bose®Customer Service to request one.
The external antenna on your radio is a coax (round) design It needs an adaptor and an antenna which are cheap.
Easy to make, radio shack "F" connector 90 degrees or straight, to 300 ohm wire connections. Attatch a 300 ohm flat ribbon antenna cable to those two screws and plug into radio and see how your reception is. You will need to position the antenna wires to get best reception. I have hid them in back of paintings and so on.
Cheapest solution next to putting an extension cord on radio power cord.
Jan 03, 2011 | Bose Wave Radio
I am having very poor FM reception with my Bose Radio wave system. Is there an external antenna that can be attached?
The power cord is the antenna and it should be stretched out straight for best possible reception. You could experiment with re-orienting the Bose, too.
There is a threaded 75-ohm coaxial FM External connector. You could probably get a compatible FM antenna at an electronics store.
See the manual, Page 10
Dec 25, 2010 | Bose Wave Radio
I have a bose wave radio and cd player the cd
you sure have a problem with your cd pick up unit or servo drive,for that must bring it to your local repair shop
as for the poor recepcion olease try a better antena
Dec 18, 2009 | Bose Wave Radio
How good is fm tuner reception? We live approx 50 miles from transmitters and have trouble getting clear signals. Is Bose just good sound quality, or does tuner provide superior reception?
I live in Vail Az about 110-120 miles from Phoenix Az I can pick up 60% of the stations decent. The power cord acts as a fm antenna. Plus this Bose Wave CD/MP3/FM
Aug 16, 2009 | Bose Wave Radio
AM reception
Since there is no AM antenna input on this radio, you will have to get an AM proximity antenna. One that does not need to connect to the radio. At Bose they recommend the Terk AM Advantage proximity antenna. I think you can get it on Audiovox.com.
Jun 17, 2009 | Bose Wave Radio
How can I get the Bose Wave radio to work in Europe??
Yes. The tuner spacing option should do this. If it's a Wave Music System or a Wave Radio II, go into the 'setup menu' and look for 'tuner spacing'. -If it's older, you may want to call Bose for a solution.
Jun 11, 2009 | Bose Wave Radio
Am antennas
Hi, to all. There are currently two types of Bose Wave Radio system available in the market. The first one being the WRCD with the top loading CD mechanism. This unit does come with the Antennae cable inside the box and this should sort out your problem. Another option is using an outdoor aerial antennae and connect this to the antennae port behind the unit. The second one is the new Wave Music System with the front loading tray mechanism. This system uses a unique concept of using the electrical cable included in the box and utilise your electrical pwoer line as the antennae receptor. I recommedn to keeping the pwoer calbe fully extended. Another solution for this is that Bose service centers do have a specific spare parts calbe called the AM/FM antennae cable for WMS which you can simply buy for around 20$ I assume. this basically bypases the power calbe and routes antennae reception through this minicable (brownish colored RJ calbe).
Glad to be of service...
Oct 14, 2007 | Bose Wave Radio
Bose Wave Music System CD Shelf System Logo
880 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
