Question about Microsoft Xbox 360 Console
Xbox360 My 360 is 8 months old,when i turn it on it looks like snow moving on the screen can someone help me.
  • 23 Answers
First check the cable connections, unplug and replug them in. Next check the end of the video cable that plugs into the 360 and make sure the switch is set for your type of TV. It sounds like that may be your problem.
However if it is not even loading past the boot "logo" and your are getting multicolored boxes/"kaleidoscope" effect, then your console is bricked.
Contact microsoft support @ 1-800-4MY-XBOX for an RMA before the warranty runs out.
Posted on Sep 08, 2008
My Toro 221E, model 38582 is 3 years old. It ran great this morning (blizzard, 14" snow). When I got home from work in the afternoon to continue, it started fine but when I engaged the paddle to...
Hi, will try to help. This sounds like there is ice or debris that is in around the paddle or the auger preventing to turn at full speed. Without the blower running, look all over around the paddle and auger and get out anything that might be in there. I think that is the problem. This has happened to me many times, and have repaired many like that. I hope this helps you out. All the best and good luck.
Feb 02, 2011 | Toro Garden
6MTH OLD HOTPOINT PLASMA TV SUDDENLY HAS NO PICTURE NO SOUND
Hiya!
Sounds like it's on the wrong input, maybe it's analog tuner. Have you tried changing it's input?
Feb 21, 2008 | Samsung HP-R5072 50 in. Plasma HDTV
I have a dell studio 1745 laptop that is 13 month old. The display has very fine snow storm on it and there are fine lines going from left to right and slowly moving down the page. The colours are all...
This is due to loose connection which could happen after a period of time between the screen to the laptop.
Solution:
You can use another LCD screen as you secondary screen which you need to hook up to your laptop onto the blue connector (vga connection) or get the laptop screen replaced altogether
Feb 02, 2011 | Dell Studio 17 Notebook
I have a "96 Chrysler
Open the hood and look from the driverside, look back and down you will be looking at the trany and at the top you will see the linkage arm with the cable going to it, have someone move it through the gears with engine off!!!!, and see if the arm is moving, if the arm is moving then you may have trany problems, these tranys are known for problems, good luck. hope this helps. also heres a diagram to help you locate the arm at trany.johnjohn2_59.gif
Jan 10, 2011 | 1996 Dodge Intrepid
Hi there. I have a pb dot s2 netbook which is only a month old. When i turn it on the mouse pointe ris froze in the middle of the screen and will not move using the touchpad. Everything seems to be booting...
The problem sounds like it is either related to the touchpad drivers or it is a hardware issue. As the netbook is only a month old the best advice I can give would be to return it to your supplier for resolution under warranty.
Nov 25, 2010 | Computers & Internet
KDL-32L5000 model cracked screen
Someone or something impacted the screen. There is absolutely no other way this could have happened. The cost of replacing the panel will far exceed the cost of a replacement TV.
Mar 13, 2010 | Sony Televison & Video
How can i fix my touch screen on the samsung tocco lite? I can no longer use the touch screen on my phone and it is only 2 months old!! It has not been overused or badly treated. Please help
I think the touch screen is faulty. You not badly treating or overusing the phone does not mean it would not not get spoilt. Remember it an electronic, anything can happen.
You need to take the phone to an expert to change the touch screen for you.
Take care.
Dec 18, 2009 | Cell Phones
Snow screen
yes! your right! its a cable connector problem.
May 24, 2009 | Televison & Video
Green line down left side and geen snow
Horizontal or vertical bars on the screen could be from an ac line interference, adjacent magnetic field, bad input wire connections.....especially HDMI connector cables. A bad HDMI cable causes all kinds of unwanted picture interference. Check the conditon of all connection wires for proper fit and function. Keep in mind the method in which you connect your tv will result how the tv performs. As well this line problem could be a circuit issue too, requiring a technician to look at it.
Jul 23, 2008 | Samsung LE32R73BD 32 in. HD-Ready LCD...
Yellow splotches inside screen?
Hi. I would need more info, it sound like you have damage the screen's, at this point no warranty would cover it, you can try. The problem is the voltages between screen's acking causing the smear on your screen. If it is a rear projector lcd then it is the engine, or obto some call's it.
I hope this helps
Jan 10, 2008 | Televison & Video
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
