Question about NetGear RO318 Router
Why can't I access my ISP's resources, such as their mail and news servers on my RO318?
    Scholar:
  • 130 Answers
If the servers have simple names like 'mail' or 'news', the problem may be that the ISP's domain suffix is not being added to these names before DNS lookup. Add your ISP's domain suffix as Domain Name in the RO318's System menu. In addition, the ISP may be looking for a particular host name for your account, in which case you should enter the host name as the System Name in the RO318's System menu. Example: Consider the following account with the ISP "earthlink.net". 1. Host Name: C-223344-A 2. Domain Name: www.earthlink.net Mail Server mail Although the ISP lists the name of their mail server as 'mail', the fully expanded name is actually: mail.earthlink.net If the ISP automatically provides the domain suffix to your router, the router will append the domain suffix to DNS requests. If not, you can try one of these methods: 1. In each application (such as mail client or news reader), list the fully expanded server name, 2. Manually configure DNS parameters in the network settings of each of your PCs, and enter the domain suffix manually.
Posted on Feb 19, 2006
SOURCE:
Yahoo connection server for incoming and outgoing mail
http://www.realifewebdesigns.com/web-resources/pop3-smtp-news-servers/yahoo.asp
Nov 03, 2016 | Yahoo Computers & Internet
I cannot retrieve my mails or send emails, what is it
do you have an internet connection ? what email program ?
Doing a little detective work can save you a lot of extra hassle. If you're having trouble sending email from clients like Outlook, Eudora and other POP3/IMAP software, please check the following issues:
Correct Passwords
Verify that all password information is correct.
We get many requests that simply turn out to be a password error.
When cutting and pasting be sure to watch out for extra spaces.
Mail Server (SMTP) is Offline
Your server could be running and serving both POP3/IMAP but not providing SMTP service. On many systems, the program responsible for POP3/IMAP is not the same as the one for
open an email click tools accounts mail then on the right select properties you should see your email adress then click on servers you will see
POP3 should have mail. with your provider ie: mail.bigpond.com
and outgoing mail the same mail.bigpond.com
SMTP. As a result, you may be able to check mail but not send.
Try restarting your server or email service from your control panel.
ISP Blocks
An increasing number of ISP's are blocking port 25, the port used to send email.
Many of the major ISP's, including NetZero, MSN, Earthlink, AT&T, Comcast and Verizon, block port 25 in an attempt to control spam. If your ISP blocks port 25, then you will be unable to send email out of your server.
This is not a server problem but a direct block by your ISP. We can often work around these blocks by configuring your mail server to listen to additional ports.
You can test if port 25 is blocked by using a telnet client to connect to port 25.
If you connect successfully to port 25, you will see your mail server's banner.
This will list some information about your mail server.
If you cannot connect to port 25, then either your mail server is down or your ISP has block port 25.
ISP blocks are becoming an increasing problem.
Generally, once password issues have been ruled out, sending email is all or none. If the mail server is down, no one will be able to send email.
ISP blocks will only impact those clients behind that ISP's network.
Server Load Throttling
Many SMTP servers will begin to reject email if server loads are too high.
If you have root access, you may want to login and run "uptime".
This will tell you your current load averages.
Many systems stop responding to email requests if loads exceed 12 for a five-minute period.
If the load does not decline to below 4 within a few minutes, then you may have a service performance issue.
SMTP Authentication
Most email servers use one of two mechanisms to determine if a user is permitted to send email.
The first method, "POP before SMTP", requires that the user first check their email before they can send.
If a user cannot check their email, then they will not be able to send.
Try restarting your POP3/IMAP server and testing again.
The second and preferred method is called SMTP Authentication.
This method should be used if your system supports it.
Current Ensim, Plesk and cPanel servers all support SMTP AUTH.
To use this feature, the user must check configure their email client to use authentication for sending mail. In Microsoft Outlook, there is a check box called "This server requires authentication."
That box should be checked.
hope this helps
Sep 17, 2012 | Dell Latitude D 600/610
Cannot access my 2nd email address
Hello. You might like to check your mail server addresses, both incoming and outgoing. It might look like "mail.isp.com"
Jan 14, 2012 | ASUS Computers & Internet
Cannot send email but I can receive email. What is the problem? Yahoo email
Hello, ''Wanda'' sorry, for your problem. If you're able to receive but unable to send mail using your POP mail client (such as Outlook), please review the possible troubleareas below. SMTP Server In the fight against unsolicited commercial email (spam), some Internet service providers require their subscribers to send mail through the ISP's own SMTP servers. If you experience problems sending email, please contact your ISP to determine if it requires different SMTP server settings. Youwill need to use the ISP's SMTP server in place of Yahoo!'s SMTP server when configuring your POP mail client. The following is a partial list of ISPs that require you to use their SMTP servers. If your ISP is among them, try replacing the Yahoo! SMTP server with the ISP server in your POP mail client settings, or consult the ISP's help files. If your ISP does not appear in the list below, please contact your ISP directly for more information. Thanks
Oct 01, 2011 | Yahoo Mail
I have a imac and I cant seem to send mail by using the stamp. It says that the outgoing server is wrong. I have ymail. Can anyone help
make sure you setup the outgoing smtp server correctly. look online to see what their incoming and outgoing settings should be.
Mar 15, 2011 | Computers & Internet
WorkCenter M118 it stop sending scan over email. Insted of sending it print the NDR with error E11202
Solution : Make Sure the SMTP (Mail) Server is an Open Relay Server or Uses POP-Before-SMTP Authentication The mail server being used must be an Open Relay server or use POP before SMTP authentication. If the mail server being used requires SMTP authentication, the scan to e-mail process will fail. The WorkCentre is unable to access the mail server when SMTP authentication is required. Contact your Internet Service Provider (ISP) or System Administrator for additional information.
NOTE: The WorkCentre was designed to send e-mail through internal corporate mail servers. In most cases, if using your Internet Service Provider (ISP) mail server, the scan to e-mail process will fail because most ISP mail servers require SMTP authentication to send mail. Contact your ISP for additional information.
Feb 24, 2011 | Xerox WorkCentre M118 Black and White...
Camot send or receive out llook exspres
SMTP Server
In the fight against unsolicited commercial email (spam), some Internet service providers require their subscribers to send mail through the ISP's own SMTP servers. If you experience problems sending email, please contact your ISP to determine if it requires different SMTP server settings. You will need to use the ISP's SMTP server in place of Yahoo!'s SMTP server when configuring your POP mail client.
Aug 05, 2010 | HP Computers & Internet
Am tring to set up my email on my new note book in out look express but dont seem to be able to come up with the log on page so am not able to do any thing like send an email can use email on my hotmail...
Outlook Express needs you to have an email account with your ISP, and your ISP should provide you with the setup items like Mail Servers. Once this isw done, you will have complete access to your email.
As an example, my ISP is Comcast and my mail servers are
mail.comcast.net to receive, and
smtp.comcast.net to send.
Your ISP will have their own servers, of course.
You will need to log in to these servers, using logins and passwords provided by your ISP. Outlook Express manages this as well.
Oct 30, 2009 | Microsoft Outlook Express
I need to know my mail server to access Outlook Express.
Your mail server is provided for you by your internet service provider (ISP).
Your ISP's help pages, initial setup pages will detail all the settings for your mail servers. Likewise gmail yahoomail hotmail setup pages detail their server settings.
capitus extractum rectuus
Jun 28, 2008 | Computers & Internet
Feb 19, 2006 | NetGear RO318 Router
NetGear RO318 Router Logo
159 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Mike
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
