Question about Samsung CLP-510 Laser Printer
Paper is getting crinkle up
The two orange rolers are also wrinkled possiblt overheated????
  • 691 Answers
If the paper if getting a fan fold and then jamming at the fuser unit, this would suggest a pick off finger may have come off its mount or spring. If the paper clears the fuser ok put has an elephant skin type wrinkle down it, then this would suggest fuser is past it's best and should be replaced. Remove the fuser and check there is nothing wrapped round one of the rollers. If all is clear, change the fuser.
Posted on Sep 14, 2008
How do I stop the paper from crinkling prior to printing in Canon D320
check the whole paper flow. special look out for things in the printer that don't belong there, like a paperclip or screws of paper.
sometimes things fall in a printer and can spot all the fun.
Jan 21, 2015 | Canon Office Equipment & Supplies
Wrinkled paper
The rollers are sticky, clean the rollers with methylated spirits.
May 08, 2013 | Fuji Xerox® DocuPrint C3055DX Laser...
We are suddenly experiencing 2 problems. First,
The fuser needs to be replaced, it is causing your smears and the wrinkling/jamming problem.
Apr 28, 2009 | Lexmark T430 Laser Printer
Paper is coming out wrinkled in one spot
Most of the crinkled paper issues I deal with have to do with the fuser roller lining going bad. If this is your issue the crinkle will be a vertical line from the leading edge to the trailing edge. You will need a new fuser.
Jan 30, 2009 | HP LaserJet 2840 All-In-One Printer
Paper crinkles
This is what I've seen with wrinkled pages in these machines.
Usually only happens with letter size paper.
At some point a leaking toner was used in the machine the excess toner works its way toward the fuser and builds up on the guide where the paper enters the fusing assm.
You can try to clean the toner thats built up or replace the fuser.
Hope this helps
Jan 13, 2009 | HP LaserJet 8000n Printer
Cannon copier/fax is crinkling outcoming paper
Although you did not mention the model of the machine, it sounds like you have a torn fuser film. Needs the fuser rebuilt or replaced.
Printdoctor
Dec 17, 2008 | Canon Office Equipment & Supplies
Crinkled paper
sound like you fuser is bad
Jul 08, 2008 | Office Equipment & Supplies
Paper feed
in the fuser assembly, pressure roller might be gone over it has to be replced and greasing has to be done
Apr 21, 2008 | HP LaserJet 3030 All-In-One Printer
Printer only prints on the left side and wrinkles up the paper on the left side
Hi there it could be that the fuser or the drum unit has some sticky labels attached to it check these units also check the paper feed path as there may also be some obstruction causing the paper to crease and crinkle.
Hope I could help
Thanks J
Jan 17, 2008 | Ricoh Aficio SP-C210SF Printer
Samsung CLP-510 Laser Printer Logo
591 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
