Question about Sub-Zero 650 / O Bottom Freezer Refrigerator
Opening door wider than 45 degree angle
I need to wipe up a spill in the refrigerator and cannot get the door open wider than 45 degrees to allow removal of the bottom produce drawer
  • 750 Answers
Does your door hit a wall behind it?
I have seen this situation the fridge had to be rolled or pulled out far enough that the door then can be swung open more and for the door bins had to be taken off to get the crisper out.
But if you have a Sub Zero that can be a problem!
How did it turn out?
Huum
Posted on Sep 17, 2008
The door on my Hotpoint Washing Machine WT741 won't open even though the programme has ended. We've tried running the programme again and pumping out but still the door won't open.
The door latch may have broken. You can sometimes open the door from the inside. You will know the door latch is broken if the door handle is floppy. If the door handle is not floppy - then the issue is probably with the door interlock. This is the electronic part that prevents the door from being opened during and after the wash has finished.
Either way - you'll need to get the door open.
To do this, unplug the washing machine from the mains and then move it out from where it is. Tip the washing machine to a 45 degree angle. Don't tip it over 45 degrees as you may break internal parts.
You need two people to do this - one person hold the machine at 45 degrees angle, whilst the other person puts their hand up into the machine - you should be able to feel the door catch mechanism and depending on the model, open the door that way. Sometimes the manufacturer has helpfully put a manual release inside - and sometimes they don't.
If you aren't able to open the door using that method. Get a length of strong string and poke the middle section of the string into the gap between the washer door and the machine body - to the right of the door handle. Use a flat headed screw drive to push the string into the gap, all the way around the door, so that you end up with the two ends of the string on the left hand side of the door. Now have someone put the ends of the string whilst the other person pulls the door handle. If the string is pushed in far enough it will release the door latch and the door will open. It takes a bit of persistence to get it right.
Once you have the door opened you can usually replace either the interlock mechanism or the door latch itself. Parts are easily available online from sites like espares and yourspares.
Mar 29, 2013 | Washing Machines
Tip
How to install a new oven door on your electric range.
First you need to remove old oven door by opening it at a 10 or 15 degree angle and pull stright up on door,door should just slide off of the hinges.Then reposition the hinges as they spring back into the stove after old door becomes free,so position the hinges at aprox... 45 degree angle hold new door above hinges then proceed in sliding the new door on over the hinges,door should slide right in to place.KEEP FINGERS CLEAR!!!!!
on Jan 30, 2010 | Kitchen Appliances - Others
One of the doors (on the Viking french door fridge) opens too wide (180 degrees). I want to tighten it so it only opens slightly more than 90 degrees. The other door is fine. Thanks.
Check with your Viking rep. I have the same problem and got word from Viking they are coming up with a new hinge doorstop at different angles. It will come in a form of a kit. The one I'm getting is about 100 degree opening. The problem I had was the door was hitting and adjacent electric oven from Viking. It just swung too wide.
Oct 29, 2010 | Viking VCFF036 Bottom Freezer French Door...
Is there a way to adjust the refrigerator door so it will stop at a 45 degree angle rather than swinging on back?
check the level of the fridge. If you adj.till it is level the door will stay wherever you stop it. Usually they are adjusted till the door falls shut if started so the door is not left open
Oct 28, 2010 | KitchenAid Superba KSRG25FK Side by Side...
How to install a Kingston 1GB DDR2 memory into the Toshiba Satellite A135 S2386 laptop
The memory compartment is dead center of the bottom of the case. open the access door and look at the modules in their slots. On either side of the module you will see a silver arm that flexes. Pull these arms off to the outside away from the module. The module will flip up at a 45 degree angle. Pull the module from the slot at that 45 degree angle. To insert the module back into the slot, go at the slot at that same 45 degree angle and push into the slot until it "seats", it only goes in one way because of a "keyway" slot cut into the bottom where the gold contacts are. Once you have "seated" it, push the module straight down and the arms will snap into place. If you are replacing both, make sure to put the bottom one in first, then the top.
Jun 10, 2010 | Toshiba Satellite A135-S2386 Notebook
How to remove an oven door on a Kenmore self-cleaning oven
To remove door open to a 45 degree angle or till it opens at an angle not 90 degrees then pull the door up at that anglr off the hhinges.
Sep 14, 2009 | Kenmore Kitchen Ranges
Finding the length of a triangle
might try
(54tan)/45
I don't have a calc that will do it or I would try it and see.
Jul 31, 2008 | Office Equipment & Supplies
Oven stops after a few seconds
I like the information you give.
If the unit will work with the control Panel at a 45 degree angle it tells me you have a loose connection. The 45 degree angle puts enough pressure on the connection to keep it completed. With the Control Panel in it's normal position, the loose connection Heats and Opens the connection. After it cools connection is again made until it Heats up again. Remember Expansion, Contraction. I do not believe you have a Magnetron issue!! A Magnetron does not know if the Control Panel is at an angle.
Can you hear a slight "Click" when the unit shuts down? If so this is a relay opening. When you say you replaced the Control Board. Was this the Control Panel PC Board, or was it the Cook-Relay Control Board? A Door Switch not making solid contact can do this. Is your Door latching down solid? Check for loose connections, not open LOOSE.
Jan 27, 2008 | GE JVM1650 1000 Watts Microwave Oven
Pump contiues running as soon as you switch on carrys on running with door open and after re set not filling timer working
Yes tipping the unit on its back at 45 angle for a few minutes worked. However, when the dishwasher was pushed back under the surface the problem re occured. We solved this by altering the feet at the back so that it was just slightly lower at the back and it works fine again. Excellent advice on this page. Has definately saved us a call out fee.
Aug 30, 2007 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
Open the modem door
The modem door does not open beyond a 45 degree angle to the base unit. Damage to the modem door will occur if forced open beyond a 45 degree angle.Open the manual for additional details.
Sep 14, 2005 | NEC MobilePro 900 Handheld
Sub-Zero 650 / O Bottom Freezer Refrigerator Logo
111 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
ACME Sub Zero...
ACME Sub Zero...
Sal DeAngelo
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
