Question about NetGear MR314 (MR314NA) Wireless Router
How To Make a DMZ - NetGear MR314 (MR314NA) Wireless Router
    Scholar:
  • 130 Answers
A router normally stops incoming Internet traffic from getting on your network, unless the traffic is in response to one of your computers or when using port forwarding. But instead of discarding the incoming traffic or using port forwarding, you can send incoming traffic to one computer on your network by establishing a "Default DMZ Server". (DMZ = humorous reference to "Demilitarized Zone".) This avoids you having to figure out what ports an Internet application wants ? by throwing all ports open for that computer. For regular network operation, NETGEAR recommends you do not use a DMZ. A computer with DMZ loses firewall protection, and is exposed to exploits from the Internet. If compromised, your own computer can attack the rest your network. Instead of DMZ, use port forwarding, as described in How is Port Forwarding Configured? However, the DMZ server feature is helpful: * When you have a problem connecting to an Internet service. Setting up a DMZ will determine whether a closed port is responsible for the problem. * With some online games and videoconferencing applications that are incompatible with NAT. Follow the procedure under your router model to create a DMZ To Create a DMZ for RP614, MR814, FVS318, FVM318, WGR614 1. Open a Web browser, and type the router's IP address (The router's default IP address is 192.168.0.1). Click Go. 2. Enter the username and password for the router (Default username is admin and password is password). 3. From the browser Main Menu select Advanced > Security. Some routers, such as the MR814, use the WAN Setup Options, page, instead. 4. Enter the server's IP address. 5. Click Apply. To Create a DMZ for FR114P, FR114W, FM114P, FR328S, FVL328 1. Open a Web browser, and type the router's IP address (The router's default IP address is 192.168.0.1). Click Go. 2. Enter the router's username and password (Default username is admin and password is password). 3. From the browser Main Menu select Advanced > Security. 4. Click Rules. 5. Check the box for Default DMZ Server, and enter the server's IP address the corresponding box for the IP Address. 6. Click Apply. To Create a DMZ for RH340, RH348, RT328, RT338, RT311, RT314, RP114, RO318, MR314, DG814 * Going through the GUI and going to Port Forward in the left menu bar. * For RM356: Going through telnet and from the main menu go to menu #15. 1. Open a Web browser, and type the router's IP address (The router's default IP address is 192.168.0.1). Click Go. 2. Enter the router's username and password (Default username admin, password 1234). 3. From the Main Menu of the browser interface, under Advanced, click Port Forwarding to view the port forwarding menu. 4. Enter the IP address of the DMZ server in the corresponding Server IP Address box. 5. Click Apply at the bottom of the menu.
Posted on Feb 19, 2006
Can anyone help me set up a dmz on this router(zyxel p 334)
Do you have a static IP to portforward with? i would not recommend DMZ because most routers lie - they still use a firewall even with DMZ.
Jul 01, 2009 | Zyxel Prestige 334 Router
Ploblems with dmz-outside (webpage). pix
Remove this line:
static (DMZ,INSIDE) 10.10.0.0 10.10.0.0 netmask 255.255.255.0
You don't need a translation going from a lower security level to a higher one. You will also need a nat line for the dmz so that pc's on the dmz will be translated outbound. The only connection that will work on the dmz is the webserver when he's sending traffic outbound with a source port of 80. Something like:
nat (DMZ) 101 10.10.0.0 255.255.255.0
Other than that, it looks like it should be working. You've got permission, a route, and a translation. Maybe "clear local-host 10.10.0.2" to get rid of any bad xlates and try again. Check debg level syslogs, run packet captures, "clear asp drop" then "show asp drop" after an attempt?
Feb 28, 2009 | Cisco PIX Firewall 506
Set your router to the DMZ?
You just need to access your router setup page then go to Firewall then select DMZ, To put a computer in the DMZ, enter the last digits of its IP address in
the IP field and select “Enable”. Click “Apply Changes” for the change
to take effect.
Mar 28, 2008 | Gateway Belkin 54g Wireless DSL/Cable...
3com router dmz doesnt allow to ssh to the asa
undo the dmz and forward the ports 22 for ssh and any other services you need to the cisco. Ok dmz is not good... 3com calls port forwarders virtual servers just add what you need there... hope that helps.
Mar 20, 2008 | 3Com OfficeConnect Router
DMZ setup
Is there a setting in the software to select the IP address for the DMZ? I'm not sure about the firewall, but most routers need you to configure the software to actually show which IP on your network is allowed DMZ.
Aug 24, 2006 | HotBrick SoHo 401 Firewall
How do I enable DMZ on the router?
1. Open your web browser, type in the router's IP address (standard: 'http://192.168.2.1') and press enter. 2. Click on Login, Advanced Setup, Firewall, enable it and click on apply. 3. Click on DMZ and select Yes to enable DMZ. 4. Enter the IP address of the machine, which was assigned a static ip address to be kept under DMZ, and click on apply.
Feb 19, 2006 | SMC Barricade 7004 Router
How To Make a DMZ
Feb 19, 2006 | NetGear RO318 Router
How To Make a DMZ
Feb 19, 2006 | NetGear MR314 802.11b
How To Make a DMZ?
A router normally stops incoming Internet traffic from getting on your network, unless the traffic is in response to one of your computers or when using port forwarding. But instead of discarding the incoming traffic or using port forwarding, you can send incoming traffic to one computer on your network by establishing a "Default DMZ Server". (DMZ = humorous reference to "Demilitarized Zone".) This avoids you having to figure out what ports an Internet application wants ? by throwing all ports open for that computer. For regular network operation, NETGEAR recommends you do not use a DMZ. A computer with DMZ loses firewall protection, and is exposed to exploits from the Internet. If compromised, your own computer can attack the rest your network. Instead of DMZ, use port forwarding. However, the DMZ server feature is helpful: * When you have a problem connecting to an Internet service. Setting up a DMZ will determine whether a closed port is responsible for the problem. * With some online games and videoconferencing applications that are incompatible with NAT. Follow the procedure under your router model to create a DMZ To Create a DMZ for RP614, MR814, FVS318, FVM318, WGR614 1. Open a Web browser, and type the router's IP address (The router's default IP address is 192.168.0.1). Click Go. 2. Enter the username and password for the router (Default username is admin and password is password). 3. From the browser Main Menu select Advanced > Security. Some routers, such as the MR814, use the WAN Setup Options, page, instead. 4. Enter the server's IP address. 5. Click Apply. To Create a DMZ for FR114P, FR114W, FM114P, FR328S, FVL328 1. Open a Web browser, and type the router's IP address (The router's default IP address is 192.168.0.1). Click Go. 2. Enter the router's username and password (Default username is admin and password is password). 3. From the browser Main Menu select Advanced > Security. 4. Click Rules. 5. Check the box for Default DMZ Server, and enter the server's IP address the corresponding box for the IP Address. 6. Click Apply. To Create a DMZ for RH340, RH348, RT328, RT338, RT311, RT314, RP114, RO318, MR314, DG814 * Going through the GUI and going to Port Forward in the left menu bar. * For RM356: Going through telnet and from the main menu go to menu #15. 1. Open a Web browser, and type the router's IP address (The router's default IP address is 192.168.0.1). Click Go. 2. Enter the router's username and password (Default username admin, password 1234). 3. From the Main Menu of the browser interface, under Advanced, click Port Forwarding to view the port forwarding menu. 4. Enter the IP address of the DMZ server in the corresponding Server IP Address box. 5. Click Apply at the bottom of the menu.
Feb 19, 2006 | NetGear RP114 Router
Configure DMZ Host
enter username admin and password blank (nothing), i got 401 Unauthorized messege 3 times reset the routher DI-524
Feb 16, 2006 | D-Link DI-704P Router
NetGear MR314 (MR314NA) Wireless Router Logo
300 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
