Question about GE GSH22SGRSS Side by Side Refrigerator
My GE side by side refridgerator makes a "howling" sound. Any ideas?
My GE refridgerator is about 4 years old and recently began to make a "howling" sound? it is very loud and appears to be coming from the freezer section only. Any Ideas?
  • Anonymous Oct 18, 2008
    My GE side-by-side is making a similar sound--it sounds like wind howling. I decided to away from the wall, unplugged it and vacuumed the grate on the back bottom, then I opened up the grate and vacuumed the dust inside as well. I'm going to clean up the fan in there as best as I can and give it a drop of oil and see if that helps things at all. I will post results!
  • Brother Don Dec 05, 2008
    I also have a GE side-by-side that is making the same noise. My until is about 4 years old as well. It is definately coming from the freezer side and seems to be related to the blower that is on the inside of the freezer compartment. It seems like there is a damper somewhere that is opening and closing - and the howling noise comes and goes with the opening and closing of the damper. I do not have any idea how to fix it and would welcome suggestions.
The problem you are having is in the main control board. ge has had a problem with this part causing the fan motor to go into high and low speed which causes the howling noise. unfortunately it is a costly fix, around $125 for the part. if you are savy to changing this part it is a matter of unplgging about 5 connections and replugging them. the new board has an extra set of pin that nothing connects to. READ the instuctions and it is a simple fix, saving about $50-60 in labor costs.
Posted on Dec 09, 2008
My GE GSH22SGRESS has a howling noise comes from the evap. fanin the freezer. After I took it out, cleaned up and put it back in, the howling noise disappeared for several hours. Then it came back. Any time I tried to reseat the fan again, or changed the digital setting for temperature, the noise went away for a few hours while the fan running, then it ... comes back ! It certainly drives me crazy.
Is it the fan or the control board ?
It appears that the problem relates to the fluctuation of fan speed which is caused by the voltage jittering - driven by the control board.
Posted on Apr 11, 2011
G E side by side refrigerator is not working properly....
Could be the start relay device on the compressor. Does it try to start every minute or so?
Sep 10, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Anyone solve the howling problem please share.
sounds like the fan bearings are wearing out. this causes imbalance and makes a vibrating howling noise.
Aug 26, 2009 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
GE Fridge - Model #GSH25JFTA CC - is making a howling noise...
FAN MAKING NOISE BECAUSE OF BAD COMP BOARD, PUT UP WITH NOISE OR REPLACE EXPENSIVE BOARD
Sep 12, 2008 | GE GSS25JEM Side by Side Refrigerator
I also had the same problem (gsh25jfta ww). It did that for a couple of months now the coils freeze up and fridge gets warm. Still looking for solution?
Jul 03, 2008 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
Noise
this fan is a variable speed and is controlled by a board in the rear of the unit. your bearings maybe going out. The fan will ramp up to speed depending on the call for cooling the Thermistors is asking for
May 20, 2008 | GE GSS22JFMWW Side by Side Refrigerator
Howling Refrigerator
I am having the same problem with my GE 2005 refrigerator. Anyone find a solution yet?
Apr 17, 2008 | Refrigerators
Fridge makes loud moaning sound
It is the control board. There is a recall on certain models and serial #'s that will cover the parts, but not all are covered. do a google search for hotpoint or GE howling noise. you will find out all the info you need.
Mar 14, 2008 | Refrigerators
GE GSH22SGRSS Side by Side Refrigerator Logo
932 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
