Printer is 3 y.o.-new computer with windows vista & cannot communicate in order to print
    Scholar:
  • 55 Answers
Have you looked for an updated Vista printer driver on the web site of your printer manufacturer? The XP driver may well not work.
Posted on Sep 08, 2008
My Kodak ESP 3 Won't Scan
Did you install the full software driver for the all-in-one? The drivers are here: http://www.kodak.com/global/mul/service/downloads/DownloadLookup.jhtml?pq-path=9103/12666/12667&product=EKN034524
Next try a new USB cable and plugging the unit into a different port. If you use a print server or USB hub, try connecting directly to the computer. Scanners need bi-directional communication with the computer and thus are likely to have issues even if the printer doesn't.
Can the scanning software on the computer initiate the scan? (That is in the full software package. Alternatively Vista came with Paint and File> Import from Camera or Scanner > New Scan.)
I hope this helps.
Apr 13, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Wireless printer communication unavailable via USB
Hi. Hope you got it working fine now on your Windows 7. If not, go to Start Menu > Devices and Printers > right click on the Lexmark print object > Troubleshoot. Make sure the printer is on and is still connected to the computer via the usb cable.
Mar 12, 2010 | Lexmark Wireless X4850 All-In-One Inkjet...
I have a Dell924 printer/scanner/copier. There is no communication between printer and computer. I have got a new cable, reinstalled printer, configured the usb port, anything I can think of. I looked at...
The problem could be because of ONE out of FOUR problems listed below. Try the steps recommended and it should fix the problem.
Thanks,
Abhishek
Jan 14, 2010 | Dell 924 All-in-One InkJet Printer
Vista 64-bit driver or windows 7-64 bit driver
Please note that PS121 does not require drives for its configuration. It can be configured manully using a browser:
Step 1:-
1.Connect the PS121 to the router & check the lights
2.Press the diag button with a paper clip, it should give a print out which should include a IP address (make a note of the IP address)
3.Open the browser & enter the IP address on the address bar, it should give you a prompt for a Username & password (Username = admin; password = password), this will show if PS is communicating with the network.
4. Make sure that all the firewalls are disabled (including windows firewall)
Step 2:- (For XP)
1. Go to control panel then go to printer and faxes.
2. Right click on the printer icon go to properties.
3. Click on the ports tab on the top.
4. Click on add port.
5. Select standard TCP/IP port and click on new port.
6. Press next.
7. Enter the IP address of the print server it will show you the port (IP_ip address).
8. Press next.
9. Select the second option custom and click on settings button.
10. Select the protocol as LPR; enter the queue name as q1.
11. Select LPR byte counting enable.
12. Click on ok and press next then click on finish.
Step 3:- (For Vista Computer):
1. Please confirm you are able to print by connecting the printer to the Vista computer directly.
2. Click Start - select Control Panel then switch it to Classic View from left side.
3. Double click on Printers & Click on 'Add a Printer'.
4. Select 'Add a local printer' & Click next.
5. Select 'Create a new port'.
6. Select 'Standard TCP/IP Port' as 'Type of port' then click 'Next'
7. Enter the IP Address of the Print Server in the 'Hostname or IP address' field.
8. Uncheck 'Query the printer and automatically select the driver to use' & Cilck next.
9. Select 'Custom' then Click on 'Settings' on the next dialogue box.
10. On the next dialogue box, select 'LPR' as the 'Protocol'.
11. Under the LPR Settings put in any name for the 'Queue Name'.
12. Check 'LPR Byte Counting Enabled' then click on OK and next.
13. Select the Manufacturer and the Model Number of the printer. If it is not available then click on 'Have Disk'. Click 'Next'.
14. Check 'Set as the default printer' and click next.
15. Try to print test page, it'll print.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards
Anand
Nov 09, 2009 | NetGear PS121 Print Server
Unable to install DP G 301 For laser jet 5 printer
0.Follow the manual instructions to configure the Printer Server (tpc/ip), connection toyour local wireless LAN, etc. then, specific for Vista: 1.Vista Start Button 2.Control Panel 3.Printer 4.Add New Printer 5.Select Local Printer 6.Click on "Create new Local Port" and from the menu "Standard TCP/IP Port" 7.Click on "Next" button 8.Menu "Type" select TCP/IP and write the IP address of your Printer Server. UNSELECT "detect printer to..." then press "Next" button 9.If everithing is fine, it must find your printer server. 10.Select your driver ... that's it .... unfortunately I found some problems printing documents: it works till half page then the printer stop and I must cancel manually from the printer the job in order to reset the printer itself.... looking for solutions
Mar 16, 2009 | D-Link Computers & Internet
Wireless lexmark not communicating
maybe its not compatible with your comp at happened to me
Dec 27, 2008 | Lexmark Multifunction Wireless Printer/...
Communication Error DELL 926 AIO Printer
Follow these steps in order to resolve the issue:
Stop the Print Spooler Service: 1) Click Start. 2) Type ‘cmd’ in the Start Search box.Search results should appear. 3) Right-click on ‘cmd’ in the search results, and select Run as Administrator.The command window will appear.4) Type ‘net stop spooler’ into the command window and press <ENTER>.The Print Spooler service should now be stopped.
Delete the Printer Drivers: .
1) Click Start.
2) In the Start Search box, type ‘C:WindowsSystem32SpoolDriversw32x86’ and press <ENTER>.
3) Delete all the files and folders in this directory.
NOTE: If the folder will not delete, rename folder to w32x86.old.
Remove the Dell printer software:
1) Click Start.
2) Click Control Panel.
3) Click Programs.
4) Click Programs and Features.
5) Click the software related to the attached Dell printer to highlight it.
6) Click Uninstall/Change.
7) Follow through the prompts in order to remove the software.
8) Restart the computer.
At this point, the user should install the latest printer software from http://support.dell.com and be able to print successfully.
Dec 24, 2008 | Dell 926 All-In-One InkJet Printer
MY LEXMARK X6100 WON'T PRINT. I JUST BOUGHT A NEW COMPUTER WITH WINDOW'S VISTA INSTALL IN IT. I INSTALL THE PRINTER SOFTWARE, THE COMPUTER CAN'T FIND IT ON MY COMPUTER AND IT WON'T PRINT.
1)right click the my computer icon
2)click properties and then click hardware n go to device manager.
3)uninstall all usb ports and then scan for hardware changes
4)ur pc will detect your printer and ask for printer drivers
5)re load drivers and your pc will communicate with your printer
6)for reloding install the cd follow the instructions on the screen and click next
7)restart when the printer is loded.connect the wires and cords properly
Oct 12, 2008 | Office Equipment & Supplies
Unable to print
With the Lexmark printers communication subsystem you MUST let the driver ask for you to plug in the printer. DO NOT plug the printer into the USB port until told to do so.
To fix a fouled install :
(1) Uninstall the Lexmark drivers in Add Remove Programs
(2) Shutdown the computer
(3) Disconnect the printer from the USB port
(4) Restart the computer
(5) Run the Driver Installation software
(6) Cancel ALL attempts by windows to auto install the printer
(7) When the sofware asks for the printer connect it and continue
Sep 07, 2008 | Lexmark X73 All-In-One InkJet Printer
Vista cannot regocnise my rx600
Windows Vista printer and scanner drivers are available for your product. The printer software is available by using the Automatic Software Update service built into Windows Vista. The scanner software is available for download through Epson’s website.
PRINTER DRIVER DOWNLOAD
Please follow these steps to set up your Epson product and automatically download the Windows Vista printer driver for it from Microsoft:
1. Connect the USB cable to your computer and then to your Epson product.
2. When the FOUND NEW HARDWARE window appears, select Locate and Install Driver Software (Recommended).
3. Your Epson product drivers will install automatically. You may need to select this option more than once during installation.
4. Close any open windows on your screen.
5. Try printing.
*NOTE:
-Depending on your system the computer may ask for your Windows disk, if so insert your Windows CD into your CD-ROM drive and click OK.
-As the driver is part of Windows Vista, there is no Status Monitor available for your printer. Some printers may have an INK LEVELS options included as part of the resident driver. Otherwise, the printer does have its own indicators. The LCD will display which cartridge is either low or out of ink.
-If the ink levels do not appear, click GET INK LEVELS to refresh the driver. Ensure the printer is directly connected to the computer as the Ink Levels does rely on full bidirectional communication.
SCANNER DRIVER DOWNLOAD AND INSTALLATION
1. Go to the Epson Support website (www.epson.com/support).
2. Select your model, then select Drivers and Downloads.
3. Select and download the TWAIN Driver and EPSON Scan Utility for Windows Vista. Save the file to your desktop and make a note of the file name in order to easily retrieve it.
4. Double-click the downloaded file and follow the on-screen instructions to complete the installation.
If a message appears indicating “The scanner has not passed Windows Logo testing”, click Continue Anyway. Then click Finish.
5. Re-start your computer before testing the scanner software.
Jan 05, 2008 | Epson Stylus Photo RX600 All-In-One InkJet...
Computers & Internet Logo
21 people viewed this question
David Payne
David Payne
