Question about Ricoh Aficio 450 Copier
Turning the red wrench light on and the screen is totally off
Te machine has done 570.000 copies so far, can you please tell me How I can serviced it or where I can find the step by step instructions to do so, thanks again.
  • hanvar67 Sep 10, 2008
    Hi, thanks again for taking the time to reply me and keep the interest on it, I'm trying to turn on the screen with not success at all, the only signs that turns on is the erros ico with the wrench on red light when I turn the switch on, so I'm just be wondering where I'm should start the search in order to make the screen turns on, Do you think that have somthing to do with the IOB, or burned fuses on panel source, because I'm bearly noticing that the screen turn a tiny litle light on, but I can't see any letter on it and when I turn it off I can see a little black dots than quickly disappear. Thanks in advance.
  • Tim Babcock
    Tim Babcock May 11, 2010
    You probably need a new drum and developer.  Do you have a source where you can get that?
  • Ricoh Master
  • 2,794 Answers
That could be a power supply issue, a cable or a bad board. There should be an SC code with it as well.
As a dealer of those machines. It's cheaper to get a new one in most cases than to get parts for it.
You can find a refurb with 150,000 copies or less for about $500.00.
Posted on Sep 10, 2008
What's your i have Bizhub 600,when i make a copy, the Df, and scanner are working normally, after that you see in the screen (Read to accept another jop) and the machines does not copy please te
Mite be that the copier need s a cleaning inside because it can not complete a copy cycle such as monitor the density of the toner on the drum have a tech do a cleaning when was the last time a 250,000 copy Preventive Maintenance Kit was done on it! Very 250,000 PM is done every 500K new drum. Does your machine a small wrench on the operator screen upper right hand of the purple/white screen
Oct 29, 2012 | Konica Minolta Developer 02xk Dv710 for...
Reset service light on hilti te 706
I have one Hilti Mechie , TE 706 Avr, Now Red Light Only Blinking ,Mechine Not Working
Jun 12, 2012 | Hilti TE 70 Hammer Drill Performance...
DEAR SIR, MY CANON IR 400 MACHINES COPY IS TOTALLY BLACK .I WILL NOT HAVE ANY TYPE OF KNOWLEDGE . PLEASE GIVE THE ANY RESOLUTION, FOR GET CLEAR COPY OR ANY TYPE OF FUNCTION IS USE FOR CLEARING...
I will tell you the problem but you need Technician. First try cleaning/replace the flash rom or change tthe Camera together with the CCD Board.
May 11, 2011 | Canon imageRUNNER 400S Copier
Casio TE 2200 Needs mac codes
Hi.
What MAC code did you use? Are you getting an error on the display? Please describe what you have done so far and I'll try to help.
Mark
Feb 26, 2009 | Casio Parts Cash Register PC Desktop
How do I change out the developer in my e-studio?
Send me an E-mail address I will copy and paste the instructions to you.
Jan 21, 2009 | Toshiba Estudio 200L Copier
Aficio 350e
To get those parts needed to fix it nowadays, it's cheaper to get a new one.
You can find a refurbished 350e online for $500-$800 in American dollars with probably 150,000 copy count or less.
In our shop we don't even work on them with that high of a copy count because of the labor costs and time on it alone.  Their happier getting a new one.
Sep 10, 2008 | Ricoh Aficio 450 Copier
Ricoh Aficio 350e copier Multifuntion machine
This blinking wrench red light means that your copier needs to be serviced. How old is your copier or how many copy have you done with it ?
Otherwise, you may need to call a service man for it.
Sep 08, 2008 | Ricoh Aficio 450 Copier
Sharp -AL1644 flashing L6 error
L6 is a Polygon Motor Lock
You could try to reset the machine with a simulation code 14, which to perform it:
1. Push Clear, Auto, Clear, Auto in a steady rythmic fashion. If done correctly the screen will go blank and all the lights will turn off. If done incorrectly wait 15 seconds then try again. Clear is the red "C" and auto is on the left hand side, the word auto directly above the button.
2. Once you're into this mode enter the number 14 as if you were doing 14 copies then push the green copy key.
If the L6 returns after the reset then you will need service on the machine, Sharp will fix it for a flat rate charge of $140.00 for parts and labor out of warranty. Give them a call 1800 237 4277 in this case.
Feb 29, 2008 | Sharp AL-1641CS Laser Digital Copier
Repair manual
Problem solved! The main power thingy (the thing with the big red wire coming out of it) was all black and dusty. There was 'soot' all over the whole insides of the monitor. I concluded that this monitor should be laid to rest, and a new flat-screen monitor erected in its place.
Nov 18, 2007 | ViewSonic G220f (Beige) 21" CRT Monitor
Ricoh Aficio 450 Copier Logo
127 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
fares
Level 1 Expert
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
