Question about AT&T Sony Ericsson W580i Cell Phone - White
Phone wont turn on!
It started to ring with a blank screen an nun of the buttons responded so i pulled the battery off and when i put it back it wont turn on, it wont charge and whenever i try to turn it on a red light blinks on the right side of the phone.......can u assist me ?
    Brigadier General:
  • 7,752 Answers
Try a new battery if that does not help then the firmware needs to be reflash on the phone you can try at topsony.com or have a technician look at the mobile for you.
Posted on Oct 25, 2008
HTC blank screen
Hello, have you tried turning off the phone, take battery out for 30 seconds then put the battery back in, then turn it back on?
Apr 24, 2015 | HTC Cell Phones
Siri keeps asking "Which setting' What setting should I say?
Never happened to me, but try reseting the phone. You do this by turning the phone off and then back on again but hold the home button while turning it back on. If this doesn't work, you might have to take your phone to a repair center.
Oct 07, 2014 | Apple iPhone Cell Phones
Iphone wont switch on
this is a tricky one you need to open the phone. use a sucker place the sucker on the screen near to the home button. slowly pull up the screen slowly. when open up a bit you will see the screen connection etc carefully remove these.( take care of the hidden cable dont brake the flap that holds the cable in place just lift the black part from the bottom) and pull away the screen. now when this is done, take away the numbers cables in order it has them on it 123456 etc. and un screw the board. remove the sim card holder and lift from the bottom and pull out from the bottom at same time lifting up. now with board out clean the connections on the bottom of the board the copper squares etc a nail file pad will do. dont go to made doing it. then do the same to the others on the phone case. while the board is out get an old tooth brush and some nail varnish remover and put some on the tooth brush and clean out the connector for the usb and charger socket. and lave to dry. put phone back together in revers order. now when it is done plug into a pc/laptop not charger. it should turn on to charging leave to charge up fully. and phone should be fine.
Apr 26, 2013 | Apple iPhone4 4G iPhone 4
My lg wont respond to me touching the screen
take the battery out and leave it out for a few minutes put it back in if this keeps happining call att and get a replacement phone
Mar 13, 2010 | LG Xenon GR500 Cell Phone
Completely frozen
Hay hay I did it. How I got it to work is thi, pull out the battery on your samsung pixon. switch it back on and continuesly press the ring button. you should get the menu up to ring some one. then start tapping everything. I did this an managed to get the touch screen and the buttons to work!
From Sean
Aug 19, 2009 | Samsung M8800 Pixon - Unlocked QuadBand...
Screen is Blank- key pad lights up??? no ring tones???
Then, you need 2 get a new phone.
The phone U have is done.
Sorry
Jul 22, 2009 | Motorola Mobility RAZR V3
Black Berry 7250 not allowing me to scroll or answer calls
Sounds like you need to do a hard reset on the device. Try pulling out the battery while the device is on, leave out for 15 seconds and then put back in.
May 26, 2008 | RIM BlackBerry 7250
Samsung Sync
Its one of the most common problem in Samsung SGH-A707.It is mainly due to one reason i,e. your cell got wet.....!!!
But you can try following steps to get rid of it:
  1. Takeout the battery of your phone.
  2. Leave your cell in air for a day or two without attaching battery and battery cover to it.
  3. Put the battery back,it should work.If still problem exists, then I'll recommend you to buy a new battery for your cell........and before you put that new battery in your cell,leave your cell in air for another two days with the same procedure.
Apr 17, 2008 | Samsung SYNC SGH-A707 Cellular Phone
Phone blinks white and wont respond.
sometimes when you turn the phone off, take out the battery, put the battery back in, then turn the phone back on, it fixes the problem... sometimes it doesn't though
Dec 21, 2007 | Motorola Mobility RAZR V3
Screen stuck on hellomoto
Hi try pulling out the battery for a few min and later when you put back the battery , keep your phone for charging. Then try switching off and off when the charging is taking place. Hopefully it should solve the problem.
Oct 20, 2007 | Motorola Mobility MING A1200
AT&T Sony Ericsson W580i Cell Phone - White Logo
88 people viewed this question
Top AT&T Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you an AT&T Cell Phone Expert? Answer questions, earn points and help others
