Well it depends on the interface of the barcode scanner. Most barcode scanners interface with a PS2 wedge or a USB cord. If you have the PS2 wedge then you will need to also plug in a PS2 keyboard into the other side of the connector and then plug the whole unit into a PS2 port. The color of the PS2 keyboard port is purple. You can find this at the back of the CPU.
If it's a USB barcode scanner simply plug it into a USB port. There are PC cases which have USB ports in front of the case, you can try to use them. If you don't see one in front, you can definitely find one at the back.
Most barcode scanners emulate a keyboard so when you scan a barcode it reads the characters and then shoots the data to the computer like a keyboard quickly pressing the right keys. Most barcode scanners you can scan into any application that accepts keyboard typing.
Tell me if this is of any help. Thanks!
Which main unit to Front end of what?
Sorry to say,but your question is not very clear about which product you need support.
Thus, please give some more detail on your product whenever you ask any support so that the experts can search the exact products and provide better support as there are hundreds of similar products in the market.
Please give exact Make and Model number of your product and also some more detail on your problem so that we could identify your issue better ant give appropriate solution.
Thank you.
I never asked about a scanner I asked about the horizon booklet maker 2000
How come I ask for one thing and I get an answer what I never asked?
