Question about Canon imageRUNNER 400S Copier
Replacing staples Lost the instruction manual(s). Can someone walk me thru replacing a staple cartridge?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Canon Master
  • 1,362 Answers
1-Open door in finisher ( where paper is delivered and stapled)
or push finisher away from copier and look on the right rear
2- remove the old unit by lifting up and out ( should be a small white box
3-before inserting new staples remove the band surrounding it : Careful not to drop, if you do you must make sure they face the right way in the box !!!!!!
4-insert in stapler
Posted on Sep 08, 2008
How to add staples to copier
Oper the finisher door. Pull out the staple cartridge holder and replace the new staple cartridge. Follow detailed instructions at the side panel door ..
Jul 07, 2014 | Toshiba e-Studio 4540C Multifunction Color...
How do I reload staples into my Xerox WorkCentre 7530?
You did not indicate finisher? Xerox MFPs' come with the most finishing options of any manufacturer.... I included instructions for all of them below. Enjoy!
Solution : Load Staples in the Professional Finisher With Booklet Maker The stapler in the booklet maker uses two Staple Cartridges labeled R2 and R3. Booklet stapling requires that both Staple Cartridges be free of jammed staples.
WARNING: Do not perform this procedure when the printer is copying or printing.
  1. Make sure the printer has stopped copying or printing.
  2. Open the Finisher Front Door.
  3. Squeeze the orange R2 and R3 levers together and pull the Staple Cartridge unit out of the Finisher until it stops.
    NOTE: The Staple Cartridge unit does not detach from the Finisher.
  4. Grasp the orange tabs on both sides of the Staple Cartridge and lift the cartridge out of the Staple Cartridge Unit.
  5. Push the new cartridge into the Staple Cartridge Unit.
  6. If no jammed staples are found, repeat step 4 - 6 for the other Staple Cartridge.
  7. When finished, return the Staple Cartridge Unit to its original position.
  8. Close the Finisher Front Door.
Solution : Load Staples in the Main Stapler of the Professional Finisher NOTE: Using Staple Cartridges other than the recommended staples may impair quality and performance. Only use only Staple Cartridges recommended for this Finisher.
  1. Make sure the machine has stopped copying / printing.
  3. Grasp the orange R1 lever on the Staple Cartridge and push it to the right.
  4. Grasp the orange tabs and pull the cartridge out of the Finisher.
  5. Check inside the Finisher and remove any loose staples.
  6. Pinch both sides of the staple case and remove the staple case from the cartridge.
  7. Insert the front side of the new staple case into the Staple Cartridge, then push the rear side into the cartridge.
  8. Grasp the orange tabs on the cartridge, and then insert the cartridge into the Finisher until it click into position.
  9. Close the Finisher Front Door.
Solution : Load Staples in the Booklet Maker of the Optional Office Finisher LX NOTE: The Booklet Maker uses two staple cartridges. Booklet stapling requires that both staple cartridges contain staples.
  2. Open the Finisher Side Cover.
  3. If the Staple Cartridges are not visible, grasp the vertical panels to the left and right of the opening and slide them to the center.
  4. Hold the tabs on both sides of the cartridge and pull the cartridge out of the finisher.
  5. Hold the tabs on both sides of the new cartridge and insert it into the original position in the Finisher.
    NOTE: If you have trouble inserting the cartridge, make sure the staples are positioned correctly in the cartridge.
  6. Starting at step 3, repeat the procedure for the other cartridge.
  7. Close the Finisher Side Cover.
Solution : Load Staples in the Integrated Office Finisher WARNING: Do not perform this procedure when the printer is copying or printing.
  1. Make sure the machine has stopped printing or copying, then open the Front Cover on the Integrated Office Finisher located under the Scanner Assembly.
  2. Remove the Staple Cartridge by grasping the cartridge by the orange handle and pulling it straight out of the Finisher.
  3. Remove any loose staples inside the Finisher.
  4. Pinch both sides of the staple case and remove the staple case from the cartridge.
  5. Remove the new staple case from its packaging and insert the front side of the case into the staple cartridge. Push the rear side into the cartridge. The cartridge will click into place when it is installed correctly.
  6. Grasp the cartridge by the orange handle and insert the cartridge back into the stapler until it clicks into position.
  7. Close the Front Cover.
    NOTE: If the Front Cover is not completely closed a message will be displayed. The machine will not operate if the cover is even slightly open
Nov 18, 2013 | Xerox WorkCentre M-24 Color Copier
I have been trying to load the stapler but when I put the cartrage back into the unit it starts making a weird noise and the the screen still shows load staples so I do not know whether I am doing...
Remove the stapler cartridge and look on the clear plastic part of the cartridge. Do you see the arrow pointing towards the puncher side of the cartridge. The arrow of the replacement staples should line up. I've had customers put the staples in upside down before. The only problem is that you then have to take the staple cartridge apart to remove these staples and reuse them. . You just have to release the 4 clips at the bottom and carefully remove the piece. Be careful of the black arm that hangs down when the cartridge is held in the up position. When replacing the bottom back on, the orientation of this arm is important ( upside down or right side up) . This tells the copier that the staples are out. Hope this helps.
Jan 13, 2011 | Canon imageRUNNER 5570 Copier
Need instructions to load staples in Canon imagerunner 2270
pull the finisher out
you will see the staple in the end of it
pull up the staple cartridge using the green handle
then insert the new one
Apr 06, 2010 | Canon imageRUNNER 2270 Copier
How to load staples in canon imagerunner 3300 copier
Does your copier have the finisher or saddle to have staples? There should be instructions in the user manuals for replacing staples. If you don't have the user manuals, I'd ask Canon to purchase replacement copies or look on the web.
Nov 23, 2009 | Canon imageRUNNER 3300 All-In-One Laser...
Air leaks thru portals on cap after replacing rings and gaskets?
Remove the bumper cap and black exhaust hood from the gun. The three screws that hold the plunger to the poppet need to have lock washers and BLUE locktight on them. Clean them totally and reassemble.
Oct 03, 2009 | Stanley Bostitch STB-MIIIFS Flooring...
I think a staple is stuck and have lost the instruction book
I decided to leave it, as I no longer need the staple gun
Many Thaks
Oct 02, 2009 | Tools & Hardware - Others
Swingline 520e does not staple
The trick to clearing this is to rn the stapler WITHOUT the cartridge in. We removed several visible jams, but once we ran it with the cartridge out, a huge piece of staple came out, and then we were able to put the cartridge back in and use it. Woot!
Sep 16, 2009 | Staples Swingline® 36115 Staple Guns Tools...
My Swingline model 520e jams every other time I staple.
There were a few staples left in the cartridge when the stapler stopped working. I went thru all the steps on bottom for stapler after changing the cartridge with two different cartridges. It makes the noise and puts marks in the paper, but no staples come out of it.
Mar 18, 2009 | Staples Swingline® 36115 Staple Guns Tools...
Canon imageRUNNER 400S Copier Logo
210 people viewed this question
old marine
old marine
Corne Viljoen
