Question about Logitech Webcam
Feed realtime audio and vdeo from webcam back to laptop.
Hi! I have a Logitech 4000 wecam/mic connected via USB (with an extension totalling around 5 meters) to my Dell laptop running Windows XP. I'm running the webcam under the door to another room where I'm trying to monitor a new litter of kittens. The Mama cat is feral, so I'm trying to limit actually entering the room. The Logitech software lets me monitor realtime video in it's "Quick Capture" mode - waiting for me to snap a pic or record a video, but there's no live audio from the mic. I've tested the mic and playback functions, so I know the mic built into the webcam works, but so far the only way I've been able to get realtime audio AND video is through Windows MovieMaker in it's "ready to record" mode. However, the realtime video feed window is much smaller then the Logitech software offers. I could record videos with audio and play them back, but I want realtime monitoring, plus I have a limited amount of hard drive space left. Is there any easy way (for free) to get BOTH realtime video and audio?
Thanks, Mark.
  • MarkVe Sep 15, 2008
    Thanks for the solution. Rather not buy more hardware if I can help it, though. Want to believe I can loop the audio back. Still, a good work-around. Thanks!
    Mark V.
  • 43 Answers
To avoid short time agravation just put a inexpensive baby monitor i the room for the sound and use computer for video ... or get xn10 equipment ...
Posted on Sep 13, 2008
  • neely07728 Sep 16, 2008
    have you tested all you equipment in your room with the computer... isolate where your trouble is may be your ext cable is a problem. i've already experienced a defective usb extender cable .
I have just brought a Logitec Webcam C120 and cannot get any sound. Do I have to get a microphone? When I do the sound test can't get any recording back.
Hi lynne_law ,
Many people mistakenly think that webcam can be used for audio as well as video transmission.
  1. Webcams don't usually come with microphones , therefore you would require a separate microphone for your voice recordings and voice chats.
  2. I would suggest you get a headset which would have the microphone option as well , or you can get a hand held mic.
  3. Once you get a new mic, you need to connect it to your computer by plugging in the mic in the appropriate slot , and by default the mic should work.
  4. If it does not work , you just need to change the microphone settings using the volume control option or audio settings via control panel.
Hope this helps ... ) Your feedback would be appreciated.
May 17, 2011 | Labtec Logitech 1200 Webcam
I HAVE A LOGITECH QUICKCAM PRO 4000, I HAVE HAD
Make sure skype is configured to use the webcam mic as the communitcation mic, to do this on skype goto tools then options, then audio settings and in the drop down menu's make sure you have corerect communications devices selcted and turned up. hope this helps
Nov 28, 2009 | Logitech QuickCam Pro 4000 Webcam
The microphone is not detected
you cn check the connection b going into the properties of your sound card page and go to the section for input check if the mic shows up have you any drivers loaded for the mic... if you go to setting then control panel look for the sound and audio box there is block there for speech check you mic is selected.. you can try connecting via afront panel usb port as well or via you sound card inputs on the back panel
Jul 31, 2009 | Logitech USB Desktop Consumer Microphone
Lose webcam connection in Skype when using a headset
Have you checked the recording settings in Windows and in Skype? Try changing the default recording device to specifically indicate the device that has your headset plugged. I think the webcam also has a mic and that should not be selected.
Other thing to check is if there is some kind of resource conflict between your USB controller and audio card (use Device Manager).
Jules
Mar 02, 2009 | Logitech Quickcam Chat Webcam
QuickCam mic doesn't work
I read another post that said to go to Logitech itself for up-dates. This I did......downloaded all new drivers, etc. (the disc that comes with the cam must be out of date !). Then when that was done, I went back on Skype and where you do a 'voice test' I was able to this time around to "choose" my webcam - this was not coming up before at all. So in doing that it activated the mic on the webcam and all was OK. We seniors are supposed to be savvy with the forever changing world of electronic devices today! (LOL)
Feb 12, 2009 | Logitech QuickCam Messenger Web Camera
No sound when connected on aim
Is your microphone integrated into your webcam? Make sure the correct device is selected. Go into Edit, Settings, Enhanced IM. Under Audio and Video, make sure the Microphone device selected is a functioning mic, such as Logitech Mic, or if using a headset, select the USB headset (if usb) or your sound card if using a mic plugged into your built in or add-on sound card.
Dec 01, 2008 | Logitech QuickCam Connect Webcam
Normal 0 Go to Control Panel and Click on Sounds, Click on Audio, then Click on the Microphone. Then Click on the drop down and select Camera Microphone.
Click OK and it should work.
Hope this helps. Bud
Sep 17, 2008 | Labtec Webcam Pro
My mic doesnt work
to put that in cam microphone working, you need to see on audio settings properties and change the "recording device" to usb audio device, instaid of the soundcard as is. That means that the sound recording will be from the cam's microphone.
The steps are:
1- rigth mouse click on the speaker next to the clock OPEN VOLUME CONTROL
2- OPTIONS - PROPERTIES - RECORDING
3 - in MIXER/RECORDING DEVICE (where is your soundcard's name) change to USB AUDIO DEVICE and then OK
4- In the remaining volume control window, select MICROPHONE and then close all the volume control windows
5- you can test the mic settings in messenger (any version) because of volume and to a clearest voice sound in your pc.
ATTENTION: carefull with the distance between your cam and your sound speakers because of distorcing sound and feedback
Jan 23, 2008 | Logitech QuickCam Fusion Webcam
Mic
first make sure that you have connected the wire properly into your microphone port at the back of your system
den click start> all programs > accessories >master volume >
click options>properties>then check microphone > then click ok
then uncheck the mute button it must work now .
good luck :)
Oct 12, 2007 | Logitech Quickcam Zoom 5 Pack Webcam
Logitech Webcam Logo
128 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
