Question about ASUS P5RD1-VM Motherboard
Emachine Problems Tells me that my BIOS is not correct and that my CMOS is wrong
  • sanjay25 May 11, 2010
    Sir, I have a Asus P5RD1-VM motherboard. The Original driver CD of this board is unreadable. Suddenly my HDD has crashed and I was trying to load windows XP on it. But during the Installation the system prompt that NO HDD found in the system. In this board, there is Uli SATA raid controller and I have not a driver disk of this. Please solve my problem and provide me sata raid controller disk.
    Problem Solver:
  • 15 Answers
Http://support.asus.com/download/download.aspx?SLanguage=en-us
product = Motherboard
series = socket 775
model = p5rd1-vm
there are 33 files for XP
Posted on Nov 21, 2008
How do I restore bios?
If all you have done is change the CMOS battery then the BIOS should be fine but it will have been reset to default settings which may have changed the Boot device and / or boot sequence.
Go in to the BIOS setup when you power on the computer and check that you have your main hard disk drive set as the main boot device.
Jan 13, 2012 | eMachines T3508 PC Desktop
My emachine notebook is need to reformat but the bios has a password and i forgot it. i need to clear the cmos but mi cant find the internal battery.what the best solution in this problem? please help
To reset the BIOS password read the information from this link http://www.fixya.com/support/r7229632-reset_or_remove_bios_password
In case of your laptop I would suggest using software from Hiren's Boot CD to clear the BIOS (there's Kill CMOS on there that wipes the BIOS).
Jan 21, 2011 | E-Machines M5312 Notebook
When i start up my emachine laptop it tells me to push f2 when i do it,it ask me for the password i type in the password i made to access my computer and it says thats the wrong one
IT'S EITHER THE HIDDEN ADMIN ACCOUNT OR THE BIOS PASSWORD iF IT'S THE HIDDEN PASSWORD IT MAY BE ADMIN...ADMINISTRATOR, OR JUST LEAVE IT BLANK.
IF IT'S THE BIOS PASSWORD DISCONNECT THE CMOS BATTERY FOR 5 MINUTES AND THEN PUT BATTERY BACK IN AND THAT SHOULD CLEAR PASSWORD.
IF YOU ARE STILL HAVING PROBLEMS YOU CAN MAIL ME AT doctorphibes53@yahoo.com
good luck
If this helps you resolve your problem, please
consider giving a good rating and a quick thanks
or good job.It will help me as well Thank you.
Oct 24, 2010 | Acer eMachines E7254520 Notebook PC
Cmos checksum error & keyboard not function
CMOS checksum errors
Explanation: A checksum is computed as an error-detecting code, to protect the BIOS settings stored in the CMOS memory. Each time the system is booted this number is recomputed and checked against the stored value. If they do not match, an error message is generated to tell you that the CMOS memory contents may have been corrupted and therefore some settings may be wrong. BIOSes react in different ways to encountering this sort of error. Some will warn the user and then continue on with whatever settings were in the CMOS. Others will assume that the settings that were in the CMOS were corrupted and will load default values stored in the BIOS chip "for safety reasons". The error message will indicate which your system is doing.
Diagnosis: The most common cause of checksum errors in CMOS is a battery that is losing power. Viruses can also affect CMOS settings, and motherboard problems can also affect the stored values.
Recommendation: Follow the instructions in this section to address the CMOS corruption. You should make sure that all of the BIOS settings in the system are correct, by rebooting the system, going into BIOS setup and double-checking all the values (hopefully against a recent BIOS settings backup).
Sep 24, 2010 | Computers & Internet
Cant get 4600i started. powers up but will not get past intro screen. screen shows F1 to continue and when i press F1 it tells me to press it again to retry reboot, F2 for setup options.
you need to go to cmos or bios setup, set all the date and time and proper boot setting there save and exit, it is a cmos or bios failure that causes these problems try replacing the cmos battery if the message still continues
Nov 22, 2009 | Dell Dimension 4600 PC Desktop
WHEN BOOTING IT ALways stops with notice "Checksum Error"
replace the cmos battery into new one that is specified the exact volt..hope this helpful...
Oct 25, 2009 | Abit KR7A-133R Motherboard
Boots to 'CMOSS checksum error'
Explanation: A checksum is computed as an error-detecting code, to protect the BIOSsettings stored in the CMOS memory.Each time the system is booted this number is recomputed and checked against the storedvalue. If they do not match, an error message is generated to tell you that the CMOSmemory contents may have been corrupted and therefore some settings may be wrong. BIOSesreact in different ways to encountering this sort of error. Some will warn the user andthen continue on with whatever settings were in the CMOS. Others will assume that thesettings that were in the CMOS were corrupted and will load default values stored in theBIOS chip "for safety reasons". The error message will indicate which yoursystem is doing.
Diagnosis: The most common cause of checksum errors in CMOS is a battery that islosing power. Viruses can also affect CMOS settings, and motherboard problems can alsoaffect the stored values.
You should make sure that all of theBIOS settings in the system are correct, by rebooting the system, going into BIOS setupand double-checking all the values (hopefully against a recent BIOS settings backup).
If you have created a backupcopy of your CMOS settings then use them to restore the settings to the correctvalues. To find the problem itself:
Apr 06, 2009 | Intel Motherboard
Bios lock
It sounds as though your computer has the wrong time in the CMOS. The CMOS (Complementary Metal-Oxide Semiconductors) is the chip that holds the basic startup information for the BIOS, system and its peripherals while the system is turned on and off.
If you can get into the BIOS check the date and time settings and make sure they are correct.
It may also be a case of the CMOS battery going out. When this happens your computer will tend to not keep the correct time. They are cheap and relatively easy to replace. Before buying a new batter your can try to take it out and let it sit for about 10 minutes or so to reset the CMOS and then go put the battery back in and go into the BIOS and reset the clock.
Hopefully taking the batter out or replacing it will get past your lock icon asking for the password. Just search for CMOS or BIOS default password for your brand of laptop.
Feb 03, 2009 | IBM ThinkPad R52 Notebook
ASUS P5RD1-VM Motherboard Logo
55 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
