Printer will not print, it reacts instructions from computer, goes through print process but papaer is either blank or very lightly printed and only in parts
  • Anonymous Mar 15, 2014
    not printing continuus papaer is blank
    Problem Solver:
  • 19 Answers
Make sure your paper is properly inserted and also try to turn and off the printer for some time to make it become cul for some time also make sure the printer is turn offline
Posted on Sep 08, 2008
Pages come out of printer blank
It’s making te noise of printing or just get the paper and got it out fast ? If goes straight out is the driver if goes line by line and is blank the cartridges are dryed or the injector are clogged with old ink. Time to buy a new one or send it to maintenance
Nov 10, 2017 | Kodak EASYSHARE 5100 All-In-One Printer
Print mode does not work pages come out blank
It could be the cartridges in the printer. Disconnect the printer from your computer. Open the printer cover and remove the cartridges. Close the cover. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reinsert both cartridges. Reconnect the printer into your computer. Try to print again.
If that doesn't help, try to clean the cartridge nozzles using the Lexmark software on your computer.
  1. Click Start > Programs or All Programs > Lexmark Z2400 Series
  2. Click Maintenance > Clean Cartridges.
  3. Click Print.
  4. Follow the instructions on the computer screen.
  5. If print quality has not improved, then wipe the cartridge nozzles using a slightly moistened soft cloth to clean it from possible dirt and clogs.
You can also reinstall the printer driver on your computer to repair any corrupted files necessary for printer communication and processes.
Jun 22, 2011 | Lexmark Z2490 Multifunctional InkJet...
My printer will not print from the blackk cartridge although it is showing full and has printed from the cartridge last week when it was changed the printer goes through the motens as if it is printing but...
In most cases the printer driver software can have errors while being in use or is shut down. So to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer to be detected as a new hardware as it will be installed. Now check the printer properties to see the ink levels.
Activate head cleaning before a test is taken . Sometimes it is possible that the head is not reacting to the need of the PC command or can be an issue with ink drying or
poor ink cartridge contacts.
Jun 17, 2011 | Epson Stylus C42+ InkJet Printer
Hp 2210xi printer will print from computer, but not print a copy placed on the glass. machine acts like it's printing, but page comes out blank and no error message.
Try restating your computer, uninstall the printer software, restart your computer, install printer software again, and restart computer again. (leave the printer off during this process unless told otherwise by the on-screen instructions).
If the above doesn't work, then it could be a hardware issue with the scanner. Try scanning a document to your computer and see if that works. If it doesn't, then your device probably needs a hardware repair...hopefully something is just loose in there.
Hope that helps!
Mar 28, 2011 | HP PSC 2210 All-In-One InkJet Printer
Papaer empty
it first detects that no paper in the selected paper supply and it cause an error to your computer memory and printer memory so you must reset the job to clear the error on its memory to the two units.
May 15, 2010 | Xerox Phaser 7760/YDX Laser Printer
Sending to print it goes but the printer prints blank
Try a few cleanings. Press the ink button then test print then quality, it will print a test page, from here you follow the instructions if the quality is bad. It will take you through a cleaning process.
Mar 27, 2010 | Brother MFC-5840CN All-In-One InkJet...
Printer will not print from computer
Question : How do I resolve the error code 3813 "Firmware assert" (all-in-one printer)?
Answer : To resolve the error condition:
  1. Disconnect the power adapter from the printer.
  2. Wait 30 seconds to allow the printer to reset.
  3. Connect the power adapter to the printer. Turn the printer on if necessary.
  4. Wait until the printer is ready to use.
If the error condition continues, contact Kodak.
See also here and here.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Aug 31, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
Deskjet f340
You have a paper jam. get a torch and thoroughly check doen behind unit where paper goes after removing all paper. Oopen cover, let carriage move, once settled, check everywhere her too, all around, rollers, near carriage, teeth, sides, etc, and remember it can be the tiniest slip easily missed. Good luck.
Mar 06, 2007 | HP Deskjet F340 All-In-One Printer
42 people viewed this question
jasbo
jasbo
