Question about Sanyo VPC-S7 Digital Camera
My camrea i cant get my computer to load the disk and all the camrea says is computer is connecting what do i do
It may be that you are already using a drive that the camera is trying to open on, like if you are on a shared drive, most likely E or F. You should disconnect from whatever is occupying that space and the camera will apear when turned on.
hope this helps!
Posted on Sep 25, 2008
Cant get computer to load says operatingsystem not found exiting broadcom andmedia test failure
Your computer has been unable to read from your disk-drive, and so it tries to communicate through your Ethernet cable, hoping to connect to a "boot-server", i.e., another computer that would feed a copy of Windows through your network connection, so that your computer can load Windows. If there is no "boot-server" on your network, then the 'PXE' (Pre eXecution Environment) reports that it has "failed".
But, it's your disk-drive that either is "dead", or not getting any electrical power (loose connector? or dying power-supply?) or the data-cable between the motherboard and the disk-drive is loose/disconnected.
Mar 14, 2014 | Gateway Keyboard For Nv40 Nv-44 Nv-48...
I cant download from the camrea
You neglected to specify the make and model of your camera, so I'm assuming it uses a memory card of some type.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
May 09, 2012 | Cameras
Will not download pictures to computer last down load was about a month ago with no problems, did everything the same way but i dont think my computer is reading my camrea
Try NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Oct 13, 2010 | Polaroid i735 Digital Camera
My camrea is only 1month old and was working very well but since i uploaded pics on the computer the camrea keeps turning off or it refuses to come on at times
When you removed the connecting cord from the computer, did you remember to use the "safely remove hardware" function?
Apr 25, 2010 | Cameras
Dont know what to do?
buy a card reader or connect the usb cable to the computer
the rest will be expalned in simple english
Dec 12, 2009 | Digital Concepts Digital Camera
Install disk for Largan chameleon camera
i have usb20 6LED 8MP web camera i do not have instalation due it is driver less prodect bt not ale to see my fae
Jan 05, 2009 | Computers & Internet
My pictures need to come off my camrea
This will do it for you. Connect the usb cable between the camera and the computer. Make sure the camera is off. After you connect the camera to the computer, then you can turn on the camera. Go to My computer on your pc and you will see all the drives. Look for VTech 773. Double click on the drive and you will see a PHOTO folder, pictures will be there. Remember: if your using an SD card with the camera, then you will see that drive listed under removable drives. Your pictures could be there too. Let me know if that helps.
Rob
Dec 18, 2008 | Vtech Kidizoom Digital Camera
hallo sir .........
i need a softwere 4 the the largan chameleon xp camerea i hope u will tell me the solution
i shall wait 4 r corpration
Apr 11, 2008 | Largan Chameleon XP Digital Camera
Vivicam 3750 Driver
i have problem with my vivicam ditigal camera, i can't load pictures off of my camrea to my computer, because my disk for the camrea burned up in a house fire last september, can you help me please,
Oct 07, 2007 | Vivitar ViviCam 3750 Digital Camera
Sanyo VPC-S7 Digital Camera Logo
Top Sanyo Cameras Experts
ray gallant
Are you a Sanyo Camera Expert? Answer questions, earn points and help others
