Question about Coustic Car Audio 481QE Car Audio Amplifier
Car Amplifier Hello: I have a Coustic 480 car amplifier that has a problem. The amp will come on for a second or two then shut off. This happens frequently. Sometimes it will stay on but it has become more off than on recently. The power light goes from red to green while this happens. I have checked all connections and supply voltages. Woofers connected to the amp are good. I feel that the problem is internal. The amp does the same thing cold. Any idea what this problem could be? I have experience in replacing circuit components. Thanks.
    President:
  • 1,114 Answers
Hi - You can download the manual by clicking the link underlined in blue below:
Coustic 480
So the startup red led shows an over current condition, if your sure the speakers are OK then you will need to go "under the hood". The best start for this is the following web site:
Basic Car Audio Electronics
This will give you a basic guide to troubleshoot the amp.
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Informatica
Posted on Sep 08, 2008
Can i run my amp at 1ohm and how
You should look your amp up online to see if it can handle 1 ohm stable....most can't. Lower ohmage does make the bass hit harder but can heat your amp up pretty gd....if your amp can handle it you may want to get a capacitor if you don't already have one.
Apr 10, 2012 | Coustic Car Audio 321QE Car Audio...
Sound turns on and off. Green light sound, red light no sound. It is like playing name that tune. A few seconds of music then off then on and repeat. It is not the deck as it has meters showing output. The...
Amp is probably going into protection mode, or does not have enough current from the power wire to continue operating. Check that the speaker wires are not shorting out against each other. Also check your power wire and ground wire. Ensure that the amp is solidly grounded. Are you using the proper gauge of power and ground wire? (4awg recommended.)
Mar 10, 2011 | Coustic Car Audio 481QE Car Audio...
My amp light blinks
try disconnecting the amps power for 30 seconds. Then plug back in.
Jan 25, 2010 | Coustic Car Audio 481QE Car Audio...
Every time i hook up my coustic car amp the radio will turn on with out the radio on
THE GOAL HEAR IS TO DETERMINE IF THE INSTALLATION IS CAUSING YOUR PROTECTION FAULT OR IS IT THE RADIO OR AMPLIFIER ITSELF HAVING INTERNAL DAMAGE. REMOVE THE RCA INPUTS AND DISCONNECT THE SPEAKERS, THEN POWER THE AMPLIFIER UP WITH THIS NO INPUT, NO SPEAKER LOAD CONDITION. IF IT STILL POWERS UP ON ITS OWN, THEN REMOVE THE REMOTE TERMINAL COMING FROM THE RADIO. IF THE AMPLIFIER SHUTS OFF, THEN YOU MAY HAVE A SHORTED TURN-ON TRANSISTOR WITHIN THE RADIO AND IT IS OUTPUTTING THE DC NEEDED TO TURN THE AMPLIFIER ON. IF YOU REMOVE THE REMOTE TURN-ON FROM THE RADIO TO THE AMPLIFIER AND THE AMPLIFIER STAYS ON, THEN THIS POINTS TO A FAULT WITHIN THE AMPLIFIER AND IT WILL NEED TO BE SERVICED. MAKES SURE THAT THE AMPLIFIER AND RADIO GROUNDS ARE 100%. LET ME KNOW IF YOU NEED FURTHER ASSISTANCE.....V
Jan 15, 2010 | Coustic Car Audio 401SE Car Audio...
Hello i want to know if a can feed weel a punch P1 subwwoofer in a vented enclousure or i need something bigger?
It does not have to be ported, if you want a deeper base use a enclosed box, if you want more sound and vibration use a ported box
May 15, 2009 | Coustic Car Audio 400S Car Audio Amplifier
Coustic 800s 4-Channel amp,getting bad rumbling noise.
Sounds like it could be a bad ground. Make sure also you don't have your gain turned up to much on the amp. I know it sounds like a volume control, but it is to balance your input with your output. Also does this noise happen when vehicle is running or off or both.
Feb 05, 2018 | Coustic Car Audio 800S Car Audio Amplifier
Coustic 601se power on but bad sound
Still doesn't work. Email it to me.
babin_perry@yahoo.com
Aug 23, 2008 | Coustic Car Audio 601SE Car Audio...
This is generally caused when there are blown output transistors but that generally causes the fuse to blow or causes the amp to go into protect mode.
If you connect a 15 amp fuse in series with the main power wire and it blows when remote voltage is applied, the amp is drawing excessive current. The problem could be either in the power supply or audio circuits.
Do NOT apply power without having the transistors clamped TIGHTLY to the heatsink. They can fail in seconds when there is a problem. The heatsink helps protect them.
The following page may be helpful when troubleshooting.
Amplifier Repair Primer
Let me know if you have any other questions.
Coustic Car Audio 481QE Car Audio Amplifier Logo
103 people viewed this question
Top Coustic Car Audio Car Audio & Video Experts
Greg Cann
Greg Cann
rd2xpld
JonSnell Electronic
JonSnell Electronic
Are you a Coustic Car Audio Car Audio and Video Expert? Answer questions, earn points and help others
