Question about Sanyo DS27820 27" TV
Can the remote be programed for digital and analogue? i need to know right away, if possible. i have read the directions and it doesn't look like it can. thanks - jodell heath
I SIMPLY PACKED UP THE TELEVISION BACK IN THE BOX AND I AM GOING TO RETURN IT TO THE PLACE WHERE I BOUGHT IT. FURTHERMORE, I DON'T BELIEVE I SHOULD HAVE TO GET A PLAN OR PAY ANYONE TO ASK A SIMPLE QUESTION, WHICH IS ALL I HAD. IT WAS ANSWERED BY SOMEONE AT SANYO FINALLY AFTER TWO DAYS OF CALLING AND SINCE I GOT MY ANSWER, THE SET GOES BACK BUT THANKS ANYWAY.
Posted on Sep 09, 2008
Connected antenna but no reception. cant get tv to auto program channels. like there was no reciever. do not have original remote. spent $70 for antenna
Channel scanning probably was selected using the original remote. All remotes do not have equal capabilities.
Sep 19, 2016 | Televison & Video
I bought a oneforall universal remote but need a code for a supersonic 1380
If you are a user of AT&T Uverse remote, your technician might have possibly programmed your Sanyo TV remote before leaving.
If your remote is not programmed you can easily program it by following steps which will be mentioned in the user guide, these include:
  • You must know the four digit code for AT&T Uverse which might have been given to you at the time of TV set up.
  • The remote control codes for Sanyo TV AVM - 1337U are 1045, 4062, 1095, and 1380.
There are different methods to make your Sanyo TV remote work. For example, if you have a black remote, press the zoom button which will be on the right hand corner of your TV. Then you will have to press fast forward for two seconds or till the time the TV shuts down automatically. Then once again switch on the TV and press zoom, your remote will start working once again.
In case you have a silver colored remote control, enter code 922, you will be guided to a menu. You must select RCA. IF code 922 does not work for you, enter code 1041.
  • Any of the codes mentioned in your user guide book will definitely work. Once the code is accepted by the TV, you can program it easily and set the channels of your choice.
  • While setting programs you can program it either the manual programming method or the code search method.
  • Device codes assigned to the TV will again be mentioned in the user guide booklet.
  • The Uverse remote control is a universal remote control which is user friendly.
  • These programmed remotes are configured to work with other audio and video devices too. Uverse also offers other services such as high speed Internet, cable TV service, home phone, etc. It's rated as the best service provider in the market.
Audi Air Intakes
Jun 07, 2012 | GE Televison & Video
We purchased a 32 inch tv from WalMart and I'm tring to program my remote to it but in the categories of tv selections it doesnt have the ilo brand name so I don't know how to set up the remote. Please...
I had the same problem with my ILO tv, I found a code for Funai- manufactured by the same company. Unfortunatly I don't know the codes anymore, but I hope it helps.
Jan 26, 2011 | iLO IWT3206 TV
Tunes Terrestrial analogue stations but will not tune digital stations. Help!
If this is in the UK, Have you got a Modern, Fit for Purpose, Digital spec Airiel properly instaled with good cable?
If not, get it done.
Oct 03, 2009 | Sony FD Trinitron WEGA KD-32FS130 32" TV
The TV is on analogue and I cannot change it to digital.
i just had this happen when my son sat on the remote and i have dish network too. i don't know if this will work for you but this is what i did- go under menu and go to antenna and make sure it is set to cable. then take your dish remote (as long as it is programmed to your tv) and press the satellite button at the top till it lights up for a second or so and if there is a second there where it switches to your satellite signal and goes off again, you have to take that one second to press the guide button and it will stay on your dish connection. wierd, but it has worked twice now for me.
Jul 22, 2009 | Sanyo Televison & Video
Since digital switchover yesturday loss of digital channels
It may well be your aerial despite the success with your DVD recorder.
Digital signals are very much weaker than analogue ones, and when multiple devices share a single aerial you can get this kind of problem. You also lose about 60% of the signal at each point in your aerial cable where there are signal splitters.
There are a number of possible solutions:-
First, look at every bit of coaxial cable you have between the aerial and each appliance. Check especially at the aerial end for corrosion or poor shielding/installation and especially for evidence of rain water penetration. If the aerial is on the roof then it will cost almost as much to get the aerial inspected as it will to have it replaced, so skip to the next option. But otherwise, check along every bit of the cable for any cuts or splits in the insulation and properly remake every junction or joint if there are any doubts about them. If the cable is in poor condition then consider option three instead.
The second is to try to see if you get a better digital signal from another transmitter, this will involve trying different aerial positions so is impractical if your aerial is roof mounted but is worth trying if it's in the loft instead. It doesn't always follow that your best digital signal will be from the transmitter which you used for analogue transmissions.
Thirdly, if you're still using the same aerial as you have done for years then it's worth upgrading to one optimised for digital reception. When doing this it's foolish not to replace the cabling as well as you need it to be as good as possible. With analogue, many installers got away with using cheaper cable intended only for very short cable runs from the wall socket to the tv.
The fourth option is the budget option but can work as well as the third option: fit an additional analogue style aerials and run a separate cable down to each appliance. If these are fitted in the loft and you have the space, then there's no aesthetic or planning concerns. Normally the extra cables can run partway down through the house alongside existing cables, but for best signal quality keep them separate and ensure that the cable runs as as short as possible.
One further thing which you may want to try before all else: connect your digital box directly to the aerial cable which currently feeds your dvd recorder. Leave all other tv devices disconnected from the aerial. If the box retunes correctly then it's definitely a supply of signal issue as outlined above and if not then you should add the exact make and model of your digibox as a comment to this answer as there are a large number of earlier digibox models which cannot retune correctly due to evolving standards.
Jul 02, 2009 | Sanyo Televison & Video
Change to channel 3 rather than 2 on Zenith 27" withot a remote
You can use the menu button on the front to autoprogram the unit. Make sure the direct tv is on so the tuner will pick it up. After that, you can program the direct tv remote to operate the tv. The reason the channels won't change is there are none in the memory
Dec 19, 2008 | Zenith C27A24T 27" TV
SANYO MODEL DS27510, CHANNEL DISPLAY IN CORNER WON'T GO AWAY.
If you can program a Comcast remote or another universal remote that has an info key, you can get rid of it. I just succeeded in programming my comcast remote thanks to Dave Taylor:
http://www.askdavetaylor.com/how_to_program_comcast_cable_remote_control.html
Once the remote is programmed, hit the "info" button and watch your frustration disappear!
Dec 05, 2008 | Sanyo DS27510 27" TV
Orion tv codes
try these codes for the orion tv:0121,0135 or 0035. good luck
Nov 03, 2007 | Orion1934 19" TV
Sanyo DS27820 27" TV Logo
21 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
