Goodmans Xpro gtv42p4 cannot get my wharefedale model dsa243 dvd player to work from hdmi socket to the dvi socket on the tv. The picture comes up briefly then disappears, flashes off and left with a fuzzy screen with coloured lines on sides of tv. Can you help please? Pat
SOURCE: UPCONVERT DVD PLAYER HDMI PROBLEM
I have the same issue with this player hooked up to a Samsung 58 inch 1080p plasma.
Posted on Jun 16, 2008
  • 191 Answers
SOURCE: Goodmans LD3755HD Picture Problems
for cms voodoo, change your power module.
for tomchik, check your input voltage for voltage drop or fluctuation, if any employ voltage stabilizer, then change your power module. make sure that there is enough ventilation around your tv.
for bananahead , go and change your backlight inverter
Posted on Oct 11, 2008
  • 306 Answers
SOURCE: HDMI to DVI gives pink screen
Make sure the Geforce outputs in DVI-digital
then  Boot the PC while the TV is on and connected. This allows the card to read the EDID from the TV and provide the best resolution...
Most displays work best at their native resolution, which is either 1920 x 1080, 1280 x 720, or 1024 x 768 for most HD TVs. It sounds like your video card has difficulty handling resolutions that high and that may be your problem.
One has to remember that DVI/HDMI is capable of carrying two types of Colourspaces: RGB and YPrPb. Unless modified, the PC will always output RGB.
Do you any other components that use HDMI that you can test, or another HDMI port on your TV that you can use? If not, then the best you can do is swap the cable and contact your provider about the problem,  Make sure the Geforce outputs in DVI-digital
Do you any other components that use HDMI that you can test, or another HDMI port on your TV that you can use? If not, then the best you can do is swap the cable and contact your provider about the problem, as well as contact toshiba if swapping the cable and box doesn't resolve the color problem.
Posted on Oct 17, 2008
farr64
  • 121 Answers
SOURCE: goodmans 42" plasma tv Model NR GTV42P4
not sure i can solve this but you could try tapping the bottom of the set's case or back cover to see if its dry jointed. as you said both speakers are working so the fault lies with one of the outputs of the sets amp.if you have a headphone socket check to see if both channel's work . dry joints are quite common. also have had this problem and it turned out to be a faulty scart lead always check the obvious first good luck ..colin
Posted on Apr 27, 2009
wiqi546
  • 1511 Answers
SOURCE: Connected DVD Player to TV using HDMI cable doesn't work
Have you changed the input of your TV unit to AV1, AV2 or component...or what ever? If so and yet the problem prevails, then try to Plug the AV cable to the input of your Cable Box, if it has so.
If i was helpful, kindly do Rate!
Posted on Jul 21, 2009
Philips quadrasurf TV
Analogue TV reception has nothing to do with signals from Blu-ray players.
Connect your Blu-ray player to either a HDMI port on the TV, or use a HDMI to DVI adapter (which is picture only) and supplement it with a a connection for audio via RCA/phono- or RCA/phono to jack cable from the BD player to the TV.
Press the AV Input button on the remote to cycle through the input sockets.
Sep 08, 2014 | Philips 40MF430B/F7 model Magnavox LCD TV,...
I want to hook up a blue ray dvd player they told me to m=buy HDMI cable and this only goes to the tv, but doesn't have to go hooked up through the cable box
If you want to connect your blu-ray player to your tv, use the HDMI cable.
If you want to connect your cable box to your tv, I'd use component cables or get another HDMI cable.
You're right, you don't have to use your cable box to use your blu-ray player.
Mar 10, 2011 | Insignia 50 in. Flat-Panel Plasma HDTV
Need a manual for Goodmans XPRO GHC 304 DVD Recorder
Please try these links and post your requirement of the model;
www.devicemanuals.com/guide/???DVD-manuals.html
www.tv.manualsonline.com/???manuals/device/???dvd_???player.html
Sep 30, 2010 | Televison & Video
Can i connect a dvid cable from the monitor to my flat screen tv hdmi to watch videos from my computer? Thank you Martin
the Flat Screen TV if has, a HDMI input, also has VGA Input.
You must choose :HDMI or VGA, if HDMI The VGA board must Have HDMI Connector, and you connect a HDMI cable to the TV.
The HDMI is a digital signal input/output, VGA is Analog Signal. You must have Signal Converter if you Use the 2 signals
Oct 31, 2009 | LG Flatron F700P 17" CRT Monitor
Goodmans 42" plasma tv Model NR GTV42P4
Oct 05, 2008 | Televison & Video
Dell w3000 & PS3
This may not be DVI issue.
I connected DVD player HDMI ----> DVI ( Dell W3000) LCD TV.
Later I found that Dell TV version of DVI does not support HDCP protocol ( High Definition Content Protection protocol). So I could not play HDMI to DVI movies from my DVD player instead I use Y Pb Pr -- this works ok.
Hope this helps... I am not use PS3 enforces HDCP - I assume Sony linked with Sony Pictures would enforce HDCP on HDMI cable.
Dec 27, 2007 | Dell W3000 30 in. HD-Ready LCD Television
HDMI to DVI Cable
I had a similar issue, try adjusting the advanced settings on the DVD player.....I can't recall which settings it should be on, but when I adjusted them on my upconverting DVD player everything worked fine after.
Dec 07, 2007 | Sony Grand WEGA KF50WE610 50" Rear...
Televison & Video Logo
49 people viewed this question
Top Televison & Video Experts
