Question about Lexmark X7170 All-In-One InkJet Printer
Copy Quality (When printing of making copies only) Prints are too dark on normal setting, and even darker down both sides. Prints that don't require scanner are ok. (aligning page and test pages) I have cleaned machine, including optics.
    Problem Solver:
  • 10 Answers
Open lid press copy is scanner bulb bright white if not bulb is burning out or has burnt out
Posted on Mar 17, 2009
Copy darker
go into the menu and look for copy/print settings. you should see an option to lighten or darken the copy. It should look like a ascending /descending slider. tap to the left for lighter or to the right for darker
Nov 27, 2013 | HP Officejet 5610 All-In-One InkJet...
Our copier is copying in light shade. how to make it darker
To adjust the default lighter/darker setting
1. On the LaserJet 3015, press MENU/ENTER.
2. Use the < or the > button to select Copy setup, and then press MENU/ENTER.
3. Use the < or the > button to select Def. Light/Dark, and then press MENU/ENTER.
4. Use the < or the > button to adjust the setting. Move the slider to the left to make all of the
copies lighter than the original, or move the slider to the right to make all of the copies
darker than the original.
5. Press MENU/ENTER to save the selection.
Page 48 of the User Guide has instructions for adjusting the light/dark setting during a copy job.
Also see the Troubleshooting section of the User Guide for other possible reasons for light/faded copies.
If your copies continue to come out too light, you may need to clean the insert a new toner cartridge or change brands of toner. I tried several "generic" toner cartridges and refills, but my prints and copies were always faded or streaky. After going back to genuine HP cartridges, I haven't had any print quality problems.
Jul 21, 2011 | HP LaserJet 3015 All-In-One Printer
Canon ir 1600 my copier print copy image is very poor
iR1600 are special machine that needs a little bit more care.
First, clean the laser unit and optics ( beneath copy glass too ). Then use some polisher and polish the developing cylinder and clean/replace developer cylinder blade.
Use GENUINE CANON DRUM UNIT and GENUINE TONER.
Jul 02, 2010 | Canon Office Equipment & Supplies
When I copy, how do I adjust the light/dark, I need to get a darker copy!
The only way to adjust and print, copy or scan quality is by using the Lexmark software. Just go to your printers folder and then right click on the printer and go to properties there you will find the quality options.
Feb 04, 2010 | Lexmark X2500 All-In-One Printer
Copier acted like it needed new toner cartridge, but when I replaced, copies are still very faded. When I adjust for darker copy, then I end up with dark shadows. This is Canon PC 921.
the 1st thing you need to determine is where the faint copies are coming from. is it copies or prints (from your PC.
if its the just the copies that are faint it is could be due to the optic section (these are the mirrors in the scan unit). if you have these cleaned with either an alcohol or ipa solvent this should bring your copy quality back to normal.
if you are having faint prints then it could be 1 of 2 things. either the transfer section (in laymen terms it pulls the toner from the drum onto the paper) has a poor connection/needs replacing. the other reason for this could be the charge unit that will be situated next to the drum. this over time will need to be serviced. be carefull with this part 1stly as the drun cant be in the light for to long and 2ndly the charge wire is a very fine and delicate wire. this can be cleaned and could get copy/print quality back to stardard, all that this needs to solve the problen is a service (clean charge wire and transfer roller or replece parts.
i hope this i more help than you need and you can get the problem sorted.
lloyd
Dec 09, 2009 | Canon PC-921 Black and White Copier
How do you print from dark to darker using HP officejet 5610 printer ? When I am photo copying, the result of a copy, is hard to be read.
there is a setting on the control panel for "Best Normal or fast"select best for high quality, Normal for normal and fast for draft copies.
Jul 29, 2009 | HP Officejet 5610 All-In-One InkJet...
Toshiba 2060 Photocopier prints copies that are a bit too dark.
restart the copier while holding down the "0" and "5" keys. you will now be in service mode. enter "5" and press "start" key a number should show up in the display. this is the exposure value - how dark or light the copies will be. 5 is the automatic exposure setting. around 128 is the normal value. the larger this value the lighter the copies are - the smaller the value the darker the copies.
Enter a new number (exposure value) and press the "interupt" key to save the value. Restart the copier and check what the copies look like. Keep adjusting until it looks good/better.
Mar 26, 2009 | Toshiba 6560 Copier
Copy Problem
Since you cleand the scanner and scans are fine, the other item I seen cause that problem is the power supply.
Jan 07, 2009 | Xerox WorkCentre M20i All-In-One Laser...
My ink prints too dark is there an adjustment on the printer
yes.there is a adjust ment.go to printer properties and there printing preferences and there adjust the print quality to normal which is set on beat mode so the prints are comming extra dark.
Dec 11, 2008 | Epson Stylus CX5000 InkJet Photo Printer
Lexmark X7170 All-In-One InkJet Printer Logo
135 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
