Question about Motorola Mobility MD451 Cordless Phone
CHARACTERS ARE ILLEGIBLE ON THE DISPLAY WINDOW.
My base unit MD451: Dispaly characters unreadablel Missing all characters in several vertical columns. Neither the old or a new battery won't charge fully.
  • vhpearson1 Sep 08, 2008
    THanks for a quick though disappointing response.
    VHP
  • 13,433 Answers
Hey,
remove the batterys for a while and try again, check your language settings. Not much else. Got a faulty set on your hands?
check your charger if its giving out the expected output.
Posted on Sep 08, 2008
  • 97 Answers
Hi
It seems the problem with display as well as to the charging unit. Display problem can be repaired only br replacing the display. And for your set, its not worth to get the display replaced. You can get the handset to your near service man to check whether the power charging unit works well.
Thank you
Phone are 5.8 ghz vtech
may be the frequency problem for noise problem.
pleaSE CHECK IT OUT.
ADJUST THEM AT SOME PROPER LEVEL..
AND THEN TRY.
Oct 18, 2008 | Vtech 5.8 Ghz Handset Cordless Phone...
On close up all characters heads are missing
Faulty resistor in vertical deflection section.
Aug 17, 2014 | Televison & Video
Printronix P5215 not printing full columns. I have changed phase settings but still leaving characters from the right margin. Please help
If you are missing columns of print (vertically), the ink is making the hammer frets stick. The shuttle probably needs to be removed and the frets cleaned. This is a common problem.
Apr 19, 2011 | Printronix Line Matrix P5215 Printer
Can you replace the printer ribbon on the Seiko DPU414 Printer?
ANSWER: Since it is a thermal printer it does not have a ribbon to replace.
Description:
The Seiko SII DPU 414 thermal Printer. For a compact desktop or portable thermal printer, the DPU-414 is an excellent selection. It incorporates the STP printer mechanism to ensure silent and high-quality printing of characters and high-density graphics. And in quadruple-density bit image mode, 640-dot (maximum) CRT display hardcopy is possible (with horizontal vs. vertical radio of 1:1).
Product Specifications
  • Model DPU-414-30B
  • Printing Method Thermal serial dot printing
  • Number of dots/line 9 x 320
  • Paper width (mm) 112
  • Printing width (mm) 89.6
  • Max Speed (character/sec) 52.5
  • Paper path Curved
  • Character matrix (H x W dots) 9 x 7
  • Character size(H x W mm) 2.5 x 1.9, 2.5 x 0.9 (Condensed)
  • Number of columns 40, 80(Condensed)
  • Character type Extend Graphics Character set, Alphanumeric, International Characters, Katakana Character set
  • Interface Parallel (36pins Amphenol), Serial (9pins D-SUB)
  • Input buffer 28Kbytes
  • Command ESC/P * conformity
  • Cutting Tear bar
  • Operating Temperature (°C) 0 to 40
  • Humidity (%RH) 30 to 80(Non condensing)
  • Service life (line) 500,000 **
  • Dimensions (W x D x H mm) 160.0 x 170.0 x 66.5 (printer unit only) ***
  • Mass (g) Approx.580(without Battery)
  • Compliance FCC, CE, VCCI
Manual:
http://sii-thermalprinters.com/pdf/manuals/DPU414/DPU-414_User_Guide.pdf
Feb 13, 2011 | Seiko Office Equipment & Supplies
Illegible Ascii characters on display
You may restorte defualt settings of your bios..if still then check out if Numlock is off or on and let me inform you that ASCII only recognize (NUMBER) format not Alphabatical format .. if i'm wrong at this you may inform me at my email id of here (azm_zem@hotmail.com)
Jun 12, 2009 | Microsoft CompuRegister POS-1000 POS...
Tally 6100 missing lines
horizontal or vertical characters missing???
if your missing horizontal lines, look at where the print is missing if you see imprints... u have bad ribbons.
if your missing vertical characters down the page
Power off the printer & unplug from wall
Remove with phillips the top right cover. u will see that the control panel has a plastic clip needs to be pressed in for the control panel to come loose from the top right cover.
Then you will see P703 Hammerbank Ribbon Cable and
P704 Hammerbank Ribbon Cable swap these 2 cables on the Engine Controller Board part# 083368.
IF your missing characters move to another place on the printout then u will need to replace part# 083368.
IF your missing characters are still in the same place, then you will need to replace hammer module part# 081152, their is qty 11 of the individual 081152 about 1 inch wide. this will save $$$ ordering and replace 081152 if you have some at your work semi technical.
Be very careful with hands when powering the printer with the top right cover off
Electrically and mechanically.
Need more help you may call Toby at x311
Apr 24, 2009 | Tally Line Matrix T6100 Printer
Data sorting in Excel
If the serial numbers of all the names on the column are A1-A100.
and you want to count the no of people with a name that appears on A6.
use this
=COUNTIF(A1:A100,A6) function go(url) { window.open(AppendFromParamToUrl(url), "_self"); } function OpenInNewWindow(url) { window.open(AppendFromParamToUrl(url), "_blank"); } function AppendFromParamToUrl(url) { if (null != url) { url += (url.indexOf("?") > -1) ? "&from=" : "?from="; url += escape(window.location.href); } return url; } var L_UNDEFINED_TEXT = 'Help could not locate this inline definition.'; function InlineDefNotFound() { alert(L_UNDEFINED_TEXT); } function AppendPopup(oSource, sPopup) { InitializeGlobalData(); if (typeof(allDivsInPage) == 'undefined' || null == allDivsInPage) return; var theDiv = allDivsInPage['divInlineDef_' + sPopup]; if (typeof(theDiv) == 'undefined' || null == theDiv) { InlineDefNotFound(); return; } if (theDiv.style.display.toUpperCase() != 'INLINE') theDiv.style.display = 'inline'; else theDiv.style.display = 'none'; } var strAssetVersion = '0';var strGoDisplayCountOK = "Remaining characters: {0}";var fDisableCounter = false;var fDisableCounterFirst = true;var fWasLastCountOver = false;var fIsSimpleFeedbackWiz = false;var fIsOn2Lines = false;var strGoDisplayCountOver = 'You entered {0} characters. Please enter {1} or fewer characters.';var strGoDisplayCountOverStar = '* ';var strErrorCommentTooLong = 'The text you entered is too long. Please do not type more than 650 characters.';var iFeedbackWizStarRated = 0;var iRvasap = 0;var fFeedbackWizJustRated = false;var strYouAreNotOnlineErrMsg = 'You are not online.';var strPageAssetId = 'HP100704801033';var strFeedbackPageUrl = 'http://office.microsoft.com/assistance/fbk.aspx';var strPageLoggingParams = 'CTT=98&Origin=HP100704801033';var strCommentOnThisTemplateLnk = 'http://office.microsoft.com/en-gb/suggestions.aspx?AssetID=HP100704801033&Type=0&Rating=0';var strCannotSubmitFeedbackErrmsg = 'Your feedback could not be submitted.';var rgStrClickToRate = new Array(5);rgStrClickToRate[0] = 'Click to rate: 1 out of 5 stars';rgStrClickToRate[1] = 'Click to rate: 2 out of 5 stars';rgStrClickToRate[2] = 'Click to rate: 3 out of 5 stars';rgStrClickToRate[3] = 'Click to rate: 4 out of 5 stars';rgStrClickToRate[4] = 'Click to rate: 5 out of 5 stars';var rgStrYouRated = new Array(5);rgStrYouRated[0] = 'You rated: 1 out of 5 stars';rgStrYouRated[1] = 'You rated: 2 out of 5 stars';rgStrYouRated[2] = 'You rated: 3 out of 5 stars';rgStrYouRated[3] = 'You rated: 4 out of 5 stars';rgStrYouRated[4] = 'You rated: 5 out of 5 stars';
Jul 18, 2008 | Microsoft Excel for PC
Lexmark T642 Missing Character
change font size CPI from 10 to 15
Jul 04, 2008 | Lexmark T642 Laser Printer
I'm a Fresher in ASP.NET 2.0, Please help me
You need to change the column type from BoundField to TemplateField and call the substring method like this
<asp:TemplateField>
<HeaderTemplate>
Comments
</HeaderTemplate>
<ItemTemplate>
<%#Eval("Comments").ToString().Substring(0, 25)%>
</ItemTemplate>
</asp:TemplateField>
In this snippet, I am displaying only the first 25 characters of the Comments field.Only problem with this approach is that if even one of the rows contains a comments field with less than 25 characters, this might trigger an error.The fool proof way then is to write a small function in codebehind which will check the length of the field, chop off any extra characters and in case of shorter strings,
( THANKING " Balgates " For this HELP )
Apr 21, 2008 | Computers & Internet
Motorola Mobility MD451 Cordless Phone Logo
270 people viewed this question
Top Motorola Mobility Lands Phones Experts
John Donghia Jr.
John Donghia Jr.
Level 1 Expert
Eric Sutherland
Are you a Motorola Mobility Lands Phone Expert? Answer questions, earn points and help others
