Question about Dryers
Blowing cold air only I have a whirlpool estate electric dryer from 2004
  • 374 Answers
Your heating element has more than likely died. If you have a multimeter you can test this part to see if it is faulty. You can also test the timer out as well. The more common fault of most dryers are the heating element thoough.
Hoope this helps you.
Posted on Sep 09, 2008
The dryer runs but will not blow hot air
This is the most common locations for thermal fuses and heating element on Whirlpool,Kenmore,Estate dryers. Check these fuses for continuity and replace the one that does not have continuityseth765.jpgseth765_0.jpg
Feb 04, 2011 | Whirlpool LEQ8000JQ Electric Dryer
My dryer blows cold air
You need to do some checks. Unplug the dryer and remove the rear cover. Your heating element looks like this:
I have a manual and more here
Jan 13, 2011 | Estate TEDX640JQ Electric Dryer
I have a whirlpool elect. dryer it runs but it blows cold air what could be the reason why
Hello & Welcome to FixYa
When the dryer blows cold air then the issue is with the Thermal fuse which is located on the blower wheel housing inside the rear panel that is bad and needs replacement. Please get back to me if you have any other questions.
Kevin
Nov 30, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Estate by Whirlpool. TGDS680EQ3. Dryer turns on but air blows cold. Any insights?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Nov 04, 2010 | Estate TGDS680EQ Dryer
Electric dryer not drying clothes
The electric dryer requires 220 volts to dry clothes but only 110 volts to turn the drum .reset your circuit breaker even if it looks ok ,if that dosent work, unplug from the wall and check where the plug wire goes into the back of the dryer and look for loose or broken wires.
Apr 26, 2009 | Estate TEDX640JQ Electric Dryer
Blows cold air only
replace thermostat
Apr 15, 2009 | Dryers
My dryer is just blowing cold air
Check the breaker box make and make sure the breaker is all the way over to the on side and then if it still continues check the thermal fuse and the heating element.
Apr 01, 2009 | Whirlpool LER4634J Electric Dryer
Whirlpool gas dryer #LGR4634JQ1 not drying or shutting off
MIGHT NNED A NEW IGNITER
OR GAS VALVE SWITCH
STEVE'S APPLIANCE
516-300-3249
Mar 04, 2009 | Whirlpool LER5636P Electric Dryer
Dryers Logo
70 people viewed this question
Top Dryers Experts
