Question about Kenmore 63074 Top Freezer Refrigerator
Kenmore elite, 2002, side by side, model 106.53609202
The air flow between the freezer and refrigerator is not working properly, and as a result the refrigerator is having difficulty staying cool (below the mid to low 40's). The air from the top vent completely stops flowing into the refrigerator and ice drops form alone the bottom of the box that incloses it. Neither the top or bottom vents are blocked off by any item in the refrigerator or freezer. There seems to be some sort of internal louver in the top vent that is either closing up and sticking closed or getting clogged up and stuck closed with ice. I can open the internal louver by sticking a butter knife through the vent and moving it slightly to the side, and then the cold air flows out like it is suppose to. Is this internal louver passive or hooked up to a mecanical device that regulates whether it is supposed to be open or closed. Is it something I can replace easily, and if so what is the part name(s) and number(s)? Is there someplace I can view a diagram? Or is my problem something completely different?
  • 20 Answers
Ok first we need to see if your vent flap up top is bing iced over. you need either a philips screw driver or a 1/4 in nut driver. take off the cover to that flap. this flap is controlled by the electronic strip that controls the temp. on both sides. one question, is their ice build up in the back of the freezer? ok write me back when you get this done. kelly.
Posted on Dec 22, 2008
A kenmore side by side model 106 5661 2500 has warm refer and cold freezer
If the freezer temps are normal and the refrigerator is warmer than normal, the the air flow from freezer to refrigerator is being hampered either by ice on the evaporator or the freezer is stuff in such a way that normal airflow between freezer and fridge is hampered. If the auto defrost is not working properly you will have warmer freezer temps and a relatively warm refridge. Check the defrost timer and defrost heater element.
Nov 26, 2013 | Kenmore 56612 Side by Side Refrigerator
My kenmore elite side by side refrigerator isn't cooling properly
I need your model number I cannot pull up views without the model number. The number most times looks like 321.654987 Thank You, Sea Breeze
12_9_2012_3_01_59_pm.jpgKenmore
Dec 08, 2012 | Kenmore Elite Side By Side Refrigerator -...
My Kenmore Elite 25' Bottom Freezer Refrigerator, the lower freezer portion is working mainting a -3 degrees but this morning the upper refrigerator portion is not, what would be some likely problems to...
I guess you are talking fahrenheit temperature?
This is ok for the freezer.
The problem could be;
\ ducting blocked restricting air flow
\ evaporator fan not working
\ ice build up on the evaporator blocking air flow
You will need to get a technician to look at this problem for you
Mar 25, 2011 | Kenmore Elite TRIO® 7854 (25 cu ft) Bottom...
Bottom frezzer is working but fridge is not blowing cold air
Refrigerator gets cold air from freezer compartment. Either the air flow is blocked by food items or ice, or the recirculating fan is not working.
The most common failure is that the freezer coils get all iced up becuase the defroster timer, defroster thermostat, or heater has stopped working.
When it's running, you should feel cold air blowing out of the vents that are in the fridge, otherwise, the 'air tower' (air vent) is blocked with ice.
If you manually defrost the whole thing, and it runs fine for a day or so, then it's not defrosting properly. If you manually turn the defroster timer, and you don't hear the scorching/hissing/gurgling of the defroster working, then that would confirm a fault in the defroster circuits.
Based on the following thread, it's probably a bad defrost thermostat.
http://www.applianceblog.com/mainforums/sears-kenmore/13766-kenmore-elite-22-bottom-freezer-refrigerator-fridge-not-cooling.html
Nov 02, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Fridge not cooling freezer works fine?
hi im andy from ac refrigeration in south africa ur fridge is short of gas
Jul 29, 2009 | Refrigerators
Icemaker is not working, but water dispencer is OK Model Kenmore Elite 106.45422800
Hi...
Try to check this
Good luck !!
Regards
PCmania
Jul 08, 2009 | Kenmore Refrigerators
Er dh ken bot.fridge. 795.77552600
one thing to try first is make sure there is enough air flow in the freezer and that the airway between the freezer and refrigerator's is free and clear
Mar 19, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore Elite 75212 fridge doesnt cool off
Well there is a diffrence between no air flow and not cooling is the freezer working?? We can go from there
Sep 16, 2007 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore 63074 Top Freezer Refrigerator Logo
1,118 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
