Question about Canon Cameras
Canon Power shot SD950 IS Digital ELPH camera lents will not extend on back screen it reads lens error restart camera camera was in use the previous night testing a flash unit and was not knocked etc thanks for your help jk mc darby
SOURCE: restarting the camera
this would be because there is something stuck in the lens..could be the rubber protection stuck not enabling your lens to pop bback into position.i tried gently tapping the lens an gently twisting it to enable movement in my lens
Posted on Apr 27, 2008
  • 13 Answers
SOURCE: lens will not retract. reading "lens error - restart"
The lens motor is burnt out. Has to be replaced.
Posted on Apr 30, 2009
SOURCE: y Canon Power Shot SD400 digital Elph camera won't shut down
Your problem in your lens...Try to bring service center. Cause, canon lens it for me it not easy to disassembe dan assemble it again...Different with other camera lens, like KODAK and Samsung.
At sony camera "E18" can be "Turn the power off and On again" like my Sony W.35
Posted on Aug 22, 2009
  • 58 Answers
SOURCE: camera in water
Remove the battery, card and bake it in the sun(window sill, front seat of the car) with any plugs or doors open for a few days. Same as cell phones. Good luck. It doesn't always work.
Posted on Sep 18, 2009
  • 11967 Answers
SOURCE: my canon powershot SD950 IS,
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error", or "lens error, restart camera". Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in "no heat" setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Sep 22, 2010
I have a canon powershot sd750 and when i turn my camera on it says lens error, restart camera
Hi Shawn,
Check the link below and you will be able to fix the issue by doing the troubleshooting.
Click here - > Camera Troubleshooting
Regards,
Suhail
May 17, 2012 | Canon PowerShot SD700 IS Digital ELPH /...
Canon power shot SD800 Is digital elph. Lens is stuck in the extended position with lens error reading
You need to have the lens assembly replaced, it's the only way to fix the problem. It's about $75-85 total for a refurbished lens, installation and return shipping of the camera.
Thomas Drayton
Owner, Darntoothysam.com
Affordable Digital Camera Repair
Sep 07, 2011 | Cameras
Y Canon Power Shot SD400 digital Elph camera won't shut down
Aug 22, 2009 | Canon PowerShot S400 / IXUS 400 Digital...
I need HELP
Dear ashlyw:
A lens error due to impact damage most often requires service.
If you get an E18 message or a "lens error restart camera" message on your LCD screen and you restart the camera several times to no avail, you will almost certainly need to call Canon Tech Support at 1-800-828-4040 and have it sent in for service as there is little or nothing you can do to resolve the issue.
Hope this helps.
Sincerely,
HeavyDLB
Jun 02, 2008 | Canon PowerShot SD630 Digital ELPH / IXUS...
Canon PowerShot SD630 LENS WONT CLOSE,LENS ERROR RESTART CAMERA
I have the same problem. How do you restart the camera. I have pulled the battery and SD card, but can't get to a menu screen to restart to camera.
Apr 16, 2008 | Canon PowerShot SD630 Digital ELPH / IXUS...
Cameras Logo
100 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
