Question about Frigidaire GLTF2940ES Front Load Washer
Frigidaire washer control knob problem
I am currently in the process of having my laundry roon remodeled. When my washer was taken out of the room, the control knob was caught on the door jam. I didn't think it did any damage at the time, and it worked fine after. However, now it is changing settings at will or even beeping and turning on as if I had pressed a button of turned the knob to activate it. Do I need to replace the entire control panel? Or, can I just replace the part for the knob? Also, how difficult would this replacement be? Can somoeone who is mechanically and electrically skilled do this?
  • 6 more comments
  • jjdkjdk Sep 08, 2008
    Can I just replace the knob and its stem, or should I replace the control panel?
    I found this parts manual for my washer. Can I just replace parts # 3 and 4 to fix this problem?
    ftp://ftp.electrolux-na.com/ProdInfo_PDF/Webster/5995464194.pdf
    Would replacing the stem for the knob be a possible solution? I would rather not have to replace the entire board if I can help it. Or is the component that could be damaged inside the control panel?
    It will beep occasionally. But if the knob is bumped, it will reset for a drain/spin cycle of 19 minutes. It seems to be very touchy as if there is a cross connection or short.
    Could the problem just be loose connection or a wire that has been knockes loose? If I am understanding correctly, I should replace the control panel to fix the problem, right?
    How difficult is it to remove and replace the control panel? I didn't see any screw holding it on. Are there clips that need to be removed first?
    I there a repair manual that will indicate where the screws or clips are to remove the panel? I don't want to attempt to pry it off if it does not just pop on or off.
    Thanks everyone for all your help. I will see if there are any loose connections first. Then I will see if the knob and stem are the probelm. Finally, if I have to, I will replace the control panel. If I can, I will let you all know how it turned out. Thanks again.
  • 435 Answers
Its better to replace parts # 3 and 4 to fix this problem....
Thanks
Posted on Sep 08, 2008
  • Narmada Anand
    Narmada Anand Sep 08, 2008
    Yes , its better to replace it......good luck
    President:
  • 1,952 Answers
It may cause some loose connection in between them...so better change ur now alone and change ur setting in ur panel..
  • 2 more comments
  • mohammed marika thambi
    mohammed marika thambi Sep 08, 2008
    if ur having tis pro na..better u change ur control panel and try...
    try ur part no 28
    better u call a repair man and all solve ur pro...if u change any settin..it ll create more pro and circuit will be shorted...
    i too suggest u to change tat parts
  • 796 Answers
You need to first check if the internal control board is fine...as you are saying its randomly doing all functions like beeping buzzing...there may be any short circuit...in that case you need to replace the whole module..
  • 2,326 Answers
Check the link provided here to see a exploded view of the appliance.
You can contact them for parts availability. I do not think you will need to replace the entire panel but for sure the part where the knob is attached to(Timer/Selector Switch).
  • 1 more comment
  • Jaime Hernandez Sep 08, 2008
    If you are electrically knowledgeable you can remove the control board and check for loose solder and or wire connections. Lastly you can replace the control since that is the brain of the appliance.
    Parts # 3 and 4 are only accessories that move the switches or contacts inside the timer/control. The part # 1 should be replace.
    Item # 24 should be remove first to get access ot the control panel. There should be some screws at the back of the top cover and this cover should have some snap in clips as well.
  • 13,433 Answers
Hey, If you know how to take things apart basicly without breaking them in the process. Then Id say you can repair / replace this at home, do remember to unplug and be carefull and obviously unplug.
replacement parts are available at
http://www.repairclinic.com/SmartSearch/SmartSearch.aspx
lets see if I can find it for you.
  • 97 Answers
Hi
I think the problem wont be that much serious. Try any electrically skilled labour to check the knobs and get it replaced. Dont allow those who dont know about electrical/electronic things.
Thanks
  • Ganeshkumar Arumugasamy
    I dont think, the whole contro pannel has to be replaced. But be sure you give to skilled labour to repair. As the problem should not become more complex.
    Sorry for double post.
My Frigidaire stackable laundry center will not fill with water?
Hi Keith Knapp, I appreciate your inquiry!
I understand that your Frigidaire laundry center is not filling with water. It sounds like you could be having a problem within water valve, control board, or door switch. I would recommend having a technician out to your home to properly diagnose and repair your appliance. Hopefully this is helpful. -Matt
Aug 21, 2014 | Frigidaire FFLE2022MW Electric...
How to replace frigidaire gallery washer knob?
Good afternoon friend, that's a great question!
I understand that you are trying to replace the selector knob on your Frigidaire washer, GLTF2940E. Normally this is not a DIY job and we would recommend having a technician come out to the home in order to properly disassemble your front panel and replace the selector knob as needed. Hope this is helpful. -Matt
Jul 29, 2014 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
How to diagnose washer timer not turning?
Good Afternoon Friend,
I understand that the washer timer on your Frigidaire laundry center, model# GLEH1642DS, stopped turning and you want to know how you can diagnose this. Typically, this is not be a do it yourself repair, as there are no step by step repair instructions. I suggest contacting your local authorized technician for further assistance. They have been trained on your appliance and should be able to diagnose it and determine what is causing the timer button to not turn. Hope this is helpful.
-Best Regards-
WP
Jun 29, 2014 | Frigidaire GLEH1642DS Front Load Stacked...
Frigidaire front loading washer model FWT449GFS1
For a repair manual, contact Frigidaire directly.
Oct 07, 2017 | Washing Machines
Dryer timing button off
Hi - Are you referring to the dryer timer button (located on the far left side on most laundry centers) is broken? If so, you might need to replace the entire button. You can contact the manufacturer directly to get part or go through a part distributor but part numbers can be different.
Knob, dryer timer, white-part number: 131873304/MSRP: $24.20
Sep 25, 2012 | Frigidaire FEX831CS Top Load Stacked...
Ge Spacemaker Laundry the washer knob popped out
take knob off again and look at the stem where the knob goes does it have a round side and a flat side? if so the knob will have the same profile thats the way it goes on
Sep 09, 2009 | GE Spacemaker Washer and Dryer Electric...
Timer gets stuck on frigidaire front load washer
It appears that your timer is failing. The process to remove and replace the faulty timer is relatively easy to do with just some simple hand tools.
You should unplug the washer from the wall outlet before taking the top backsplash (control panel) apart. There are screws on the backside of the control panel, that you need to remove the back panel. Doing this will let you get to the wiring plug connector on the timer motor.
You'll also need to remove the timer/cycle knob on the front of the panel so you can use a socket (or a adjustable wrench) to remove the mounting nut and lock washer that holds the timer to the metal panel.
Once you have everything loose and accessible, all you need to do is unplug the connectors on the old timer and out them on the new timer and reinstall the lock nut and washer and button up the panel.
That shoud be all that's needed to get things working again.
Here's link showing a drawing of your washer along wtih the parts list (and prices) for parts.
The timer is part #134378400 and costs about $89.00
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=FTF530ES1&productCategoryId=0153200&brandId=1428&modelName=WASHER&diagramPageId=00001&componentDescription=CONTROL%20PANEL&documentId=R0509003&backToLink=Return%20to%20Sub%20Components%20list
Hope you find this Very Helpful and best regards!
Aug 21, 2009 | Washing Machines
How to replace the selector control knob on a Frigidaire front load washer Model FWT449GFS2
Push-in center knob and and turn Counter Clockwise to loose it from the treaded shaft. Next, without Pushing in, continue turning CC till it comes off.
If necessary, remove the outer indicator knob by sqeezing the two release clips in the center. This knob is keyed to only go back on one way so you don't need to remember its location before removal.
Reverse the process to install new knobs.
Oh, if you need to replace the cam or timer which are behind these knobs, the front panel will have to be removed by first removing the top cover of the washer. Now you can access the six screws inside the washer and one in front behind the detergent dispenser.
Jun 05, 2009 | Frigidaire FWT449
Maytag discharge into wastepipe backs up, floods laundry room.
best approach is be sure to clean drain pipe build up over the years may have created partial blockage
Apr 26, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Frigidaire GLTF2940ES Front Load Washer Logo
74 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
