Question about Microsoft Xbox 360 Console
No Display Console is working but no display on screen. i changed it from pal hdtv and can't get back. Is there a way i can do a master reset.
Well I think resetting your whole Xbox will fix it, the setup you have to do when you first bought it, go to your system blade and go into console settings and it would be somewhere in there to return your console to pre-bought settings and you will have to do them again, hope I helped.
Posted on Sep 09, 2008
My xbox 360 causes my hdtv screen to crash and display colored static. It only does this on the 'optimal display' of 1680x1050. I plugged in my laptop on the hdmi and it worked perfectly. Is t
Try manually choosing lower resolutions in your xbox display settings. My Insignia HDTV does that when switching resolutions like on Hulu in between commercials and then back to the show but only for a second or so. Also does this when going from the loading screens to the game screens for a few seconds when playing the game Split/Second
Jan 10, 2013 | Microsoft Xbox 360 Console
My Xbox 360 shows a grey screen, the sound works fine and i do have picture
Hey dude, I had this problem and found a solution on another website. Basically, I had either changed the display settings on my tv, or it had done it by itself or my new ps3 had done it or whatever, but to fix it I went into the TV menu, went to display options, on my tv it has something entitled 'Colour system' I changed that to PAL-60 and I now have colour, just to give you an idea of whether you have the same problem, try setting your x-box display to pal-50 and see if that shows colour (if it's easier to do), if it does then try then solution above! Hope it helps!
Mar 13, 2012 | Microsoft Xbox 360 Console
My playstayion is only showing on the screen in black and white and i have no idea why. can someone help please.
change the display from pal to ntsc or ntsc to pal and it will show in colour. try on the tv first if that doesnt work go into system settings on the ps3 and change it there
Mar 30, 2011 | Sony Playstation 3 (PS3) Console
Chicken wafflez
change your pal setting from 50 to pal 60 go to my xbox , then system setting , thencounsel setting, then pal display setting select pal60 , confirm let me know bluchevy20042000@yahoo.com
Apr 04, 2010 | Microsoft Xbox 360 Console
Black and white display screen
If you have an HDTV use HDMI or component to connect to get colour...if you have an SDTV and use the RGB cables unfortunately the PS3 will output NTSC signals for JApan/NA and your SDTV will accept PAL signals (EU). THere may be an adapter, but if you have an HDTV this problem should solve itself via HDMI/component cables.
Aug 29, 2009 | Sony Playstation 3 (PS3) Console
Display
To troubleshoot sound without picture issues, follow these steps:
  1. Reset the resolution of the console to 640x480. To do this, start the console, hold both triggers, and then press and hold the Y button as the console starts. For more information about how to reset your display settings, click the following article number to view the article in the Microsoft Knowledge Base: 911059 (http://support.microsoft.com/kb/911059/ ) How to reset your Xbox 360 console display settings to the default display settings If you see a picture on the display after you try this step, you can continue to use the 640x480 resolution, or you can try to use a higher resolution setting. If you still cannot see a picture, continue to the next step.
  2. Disconnect the VGA HD cable from the display, and then remove the console power cord from the power outlet.
  3. Wait five seconds.
  4. Reconnect the console power cord to the power outlet, and then turn on the console.
  5. Reconnect the VGA HD cable to the display. If you can see a picture on the display after you try this step, you can continue to use the 640x480 resolution, or you can try to use a higher resolution setting.
Aug 08, 2009 | Microsoft Xbox 360 Elite Console
NO PICTURE
first check to see if the game is running at 50 or 60 pal make sure its the same on your xbox or try turning off your console take out the game turn it back on with the guide button the hold right trigger and y this will reset the display settings on your console
Jul 17, 2009 | Microsoft Xbox 360 Console
Picture will not show
You might want to try the following:
1. make sure that the AV cable is not loose or incorrectly seated in both the Xbox 360 console and the TV
2. make sure that you have the correct AV cable for your TV, to verify that the AV cable is connected correctly to the Xbox 360 console and to the TV, disconnect the AV cable and then reconnect the AV cable to both devices
3. if you are using composite cables, do not try to set any HDTV settings because you may lose the picture
4. make sure that your TV is set to the same video broadcast system as your Xbox 360 console (PAL or NTSC)
Example:
- if your Xbox 360 console is an NTSC console, make sure that your TV supports NTSC
- if your Xbox 360 console is a PAL console, set your PAL settings to PAL 60
- if your TV has a type of picture compensation enabled, disable it
5. reset your Xbox 360 console
- Remove any discs from the disc tray
- Turn off the console
- Turn on the console
- As the console starts, press and hold the Y button, and then pull the right trigger at the same time
- The Xbox Dashboard resets the display settings to the default settings and then automatically restarts the console.
6. Do not take your Xbox 360 console or its accessories to your retailer for repair or for service unless an Xbox Customer Support representative asks you to do this
Mar 09, 2009 | Microsoft Xbox 360 Console
Xbox 360 Console, Faulty, NO DISPLAY!!??
What do you mean, no display? Is is game-related display issues? Have you checked the AV cable connection? Or is it about the settings? Is this the first time that you are going to connect your xbox console?
To determine whether the display issues are specific to a particular game, try playing a different game to see whether the same symptom occurs. Reminder, some Xbox original games that were released for the original Xbox console may show some display issues when you play them on the Xbox 360 console.
Next, make sure that AV cable is connected correctly to the Xbox 360 console and to the TV. To verify that the AV cable is connected correctly to the Xbox 360 console and to the TV, you can disconnect the AV cable and then reconnect the AV cable to both devices. Note: If you are using composite cables, do not try to set any HDTV settings. If you try to set HDTV settings, you may lose the picture.
You might also want to check your TV's settings because some display issues can be caused by how the TV is set up. To make sure that this is not the case, please check your TV's settings.
In your TV's settings, you should check the following:
- Make sure that your TV is set to the same video broadcast system as your Xbox 360 console (PAL or NTSC)
- If your Xbox 360 console is a PAL console, set your PAL settings to PAL 60
- If your TV has a type of picture compensation enabled, disable it
- If your TV's settings are correct, you may want to try using a different TV, if you have one available. Try connecting your Xbox 360 console to another TV to see whether the same display issues occur
Next, reset your Xbox 360 console. To reset the display settings to the default settings, follow these steps:
1. Remove any discs from the disc tray.
2. Turn off the console.
3. Turn on the console.
4. As the console starts, press and hold the Y button, and then pull the right trigger at the same time.
Mar 09, 2009 | Microsoft Xbox 360 Elite Console
PS3 PAL HDMI video problem with a HDTV SAMSUNG SQ01
hmmm maybe your tv should be set to a different setting other than PAL
Feb 09, 2009 | Sony Playstation 3 (PS3) Console
Microsoft Xbox 360 Console Logo
35 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Troy Gorman
Troy Gorman
Pablo Gonzalez
Mike Neath
Mike Neath
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
