Question about Whirlpool Dishwashers
Dishwasher (whirlpool quiet partner II) leaks from the door panel
  • 1 more comment
  • Anonymous Mar 13, 2014
    I opened the dishwasher while it was running. I closed the door and it would not start back up. None of the control panel lights come on and water is still in the bottom of the dishwasher. I tried a reset code I got off the internet but that doesn't work either.
  • Anonymous Mar 18, 2014
    lock light stays lit
  • Anonymous Mar 20, 2014
    I have a whirlpool dishwasher 2012 Quiet Partner 1.
    Heating element does not engage. I replaced it and still nothing. What could cause this?
I think I solved the door leaking problem by cleaning out the plastic filter screen on the inside (left) door panel. Didn't even know it was there, never knew it was suppose to be cleaned! It was so clogged and gross. I also discovered that my washer had shifted and was off balance. It has wood shims under the steel casing and one block was loose. No doubt from slamming and banging the door open and closed. Had to take the front skirt and kickplate off to see. I had my son use a lever and hoisted it up a little while I replaced the block shim now making the washer level again. Ran a light wash before fixing problems and it leaked. We ran a light wash after the fix's and so far so good. Haven't ran a regular longer wash yet. My water level was fine, no gasket problems, no washer wand cracks, etc... My husband was thrilled! When he came home, I informed him I have good news and not so good news. The not so good news was dinner was going to be late, the good news was I fixed the leaking (for months!)dishwasher and saved alot of money on repairs!
**Cleaned filter screen, made dishwasher level again.
Posted on Sep 09, 2008
How to reset wirlpool quiet dishwasher
To reset it, you will have to have the door open. It can not be latched. Press "Heated Dry," "Normal," "Heated Dry," "Normal" within three seconds of the first pressed button. Now close the door, this should reset your dishwasher.17 Dec 2012
SOLVED: Dishwasher whirlpool quiet partner I push start button - iFixit
https://www.ifixit.com/.../Dishwasher+whirlpool+quiet+partner+I+push+start+button+not...
or try this link.
How to reset wirlpool quiet dishwasher Google Search
Oct 28, 2017 | Dishwashers
How do you reset the control panel on a whirlpool quiet partner II dishwasher?
It should reset automatically. There could be lint buildup inside the dryer airflow inlet that is located just inside the door on the bottom. There could be lint buildup at the exhaust vent at the back on the bottom of the dryer.
Nov 09, 2015 | Whirlpool Dryers
Whirlpool quiet partner II starts and stops. What should I check?
the first thing to do is unplug it for 3 minutes then check to see if it reset by running
Jan 07, 2018 | Whirlpool 24 in. DU951PWB Free-standing...
Quiet partner whirlpool III gold reset
TRY A RESET CODE
Press the "Sani Rinse," "Heated Dry," "Sani Rinse" and "Heated Dry" buttons on the dishwasher's electronic control panel in quick succession to put the appliance in diagnostic mode.
Close the dishwasher door and engage the door latch.
Wait 10 seconds before pressing the "Cancel" button to reset the dishwasher.
Dec 18, 2013 | Whirlpool Gold Dishwasher with Quiet...
Whirlpool quiet partner ii dishwasher has quit working. Power is getting to the dishwasher but it is not coming on at all. There is water standing in the bottom of it and a very foul smell is present.
This dishwasher has a thermal fuse that attaches to the main control board that may have failed, it can be tested with a meter for continuity if it does not have continuity then it is your problem.
Apr 21, 2012 | Whirlpool Dishwashers
Whirlpool Quiet Partner II Dishwasher Model DU1145XTPBA Mine is all black, I would like to get the stainless steel door insert if available. Can you assist me
absolutely-- Go to http://www.applianceart.com
They have the stainless inserts available. They appear to be on sale now too! You can call these guys and get assitance if needed when placing your order. I am including the link for you to the panels themselves below. Hope this helps.
http://www.applianceart.com/Stainless_Steel_Dishwasher_Panel_p/10847.htm
Sep 21, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
Want to repace the door of and old whirlpool quiet partner II is that possible?
You may not have to, go to www.applianceart.com to see many options that go over your current panel. They also have stainless replacement panels. The only dishwashers that have panels that you can replace are "frame" dishwashers. If you have one of these, there will be two screws on the side of the door that, when unscrewed, release one side of the frame allowing you to slide the panel in and out. If you dishwasher has metal that wraps around the side, you may want to trya vinyl and a stainless steel foil option that wraps over your door around the sides. Also available at www.applianceart.com.
Aug 29, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
I have a whirlpool quiet partner II dishwasher. Can the front panel be removed and changed to a differemt color.
check out applianceart.com they have many options to change colors, designs and even stainless steel panels and covers.
Apr 08, 2010 | Whirlpool 24 in. GU1500XT - Multiple Color...
Whirlpool Quiet Partner II not washing or sensing.
I have a whirlpool quiet partner II and for some reason it does not drain the water out any more and I cannot figure out why....people say that it is the filter but that is unbelievably hard to get to and I cannot find any instructions online or paper work that tells how to break it down. If anyone has any insight please let me know
Nov 16, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwashers Logo
1,395 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
