Question about Zooper Boogie Jogger
Modify zooper I am wondering if a zooper i bought for my daughter for one child can be modified to accomodate a second infant? she will have a new baby so that makes two under the age of two! Her zooper is green and i am not sure of the actual name -- it is wonderful but was quite expensive and has not had that much usage, so buying another one is prohibitive at this time. Any suggestions would be great. Thank you -- happy nana.
    Problem Solver:
  • 4 Answers
HI, I think the only thing you can do is getting a kiddyboard. So one child would stand. Good luck....
Posted on Apr 16, 2010
Hello,how do i unlock child lock from a hotpoint washing machine WDUD 9640 .I hold button mor times dosent work.switch off and on doset work I need a help please
Check page 6:
http://docs.hotpoint.eu/_doc/19509812000_GB.pdf
CHILD LOCK button:
to activate the control panel lock,
press and hold the button for approximately 2 seconds.
When the symbol CHILD LOCK is illuminated,
the control panel is locked.
This means it is possible to prevent wash
cycles from being modified accidentally,
especially where there are children in the home.
To deactivate the control panel lock,
Feb 04, 2018 | Hotpoint Washing Machines
Just wondering what is: P1811 Maximum Adapt And Long Shift
P1811
The transmission pressure is modified by an adaptive modifier which controls the shift execution time. This diagnostic tests the time required to accomplish the shift. If the shift takes longer than 0.65 seconds and the adaptive modifier cannot shorten this time, then a counter increases by one.
If the PCM detects a counter value of 2 during one trip, then DTC P1811 sets. DTC P1811 is a type C DTC
The 1-2, 2-3 or 3-4 shift is longer than 0.65 seconds, twice in one trip.
Ask the customer about possible overloading, exceeding the trailer towing limit, or towing in overdrive.
Ensure that the current PCM calibration is correct for the final drive ratio.
  1. Use the scan tool snapshot mode in order to record the shift times.
  2. Drive the vehicle in D4 in order to obtain a 1-2, 2-3 and 3-4 upshift.
  3. Record the shift times.
Did all the shift times exceed the specified value?
0.65 seconds
Perform the Line Pressure Check Procedure.
Refer to the Line Pressure Check .
Is the line pressure within specifications?
Go to Diagnostic Aids
You may want to take this to the dealer !
Apr 20, 2015 | 2003 Chevrolet Impala
Car Seat Base for Eddie Bauer Model #22-627 FRK
Seat was recalled in 2009 and is expired. Do not use.
Aug 24, 2017 | Baby Gear
Bypassing the amp
Sounds like an electrical NIGHTMARE to me! Don't know why anybody would want to do that to a vehicle.
It would probably be a lot less work to just run new wires to everything than it would be to try to modify the vehicle wiring harnesses to accomodate an aftermarket radio that does not require a seperate amp.....
May 25, 2012 | 1998 Land Rover Range Rover
Zooper sport replacement tires
Try eBay for Scooter tires. I've found different sizes there.
Sep 28, 2009 | Zooper CoolZone Sport Stroller
Back seat child seat for mercedes sl with modified seat belts
This is not advisable for safety reasons.
Dec 23, 2017 | Baby Gear
Forgot admin password-need to re-install parental controls
If you are still able to use command prompt, try the following:
a) Start, Run, type "cmd", Enter
b) type "net user user_name new_password
- user_name : will represent your admin user account name
- new_password : will represent your new password for the account
c) press enter
d) Restart the computer and login using new password
Mar 12, 2009 | HP Pavilion dv6000z Notebook
Reset wash cycle
Changing Cycles, Options and Modifiers
Not all Options and Modifiers are available with all cycles. Cycles,
Options and Modifiers can be changed anytime before HOLD TO
START is selected.
Options and Modifiers can be changed anytime after HOLD TO
START is selected and before the start of the selected Option or
Modifier.
To cancel a cycle and select a new cycle
1.
Select PAUSE/CANCEL twice.
2. Select desired cycle.
3. Select the desired OPTIONS.
4. Select HOLD TO START (for approximately 1 second) to
restart the washer at the beginning of the new cycle.
To cancel a cycle
1.
2. The washer powers down, the door unlocks, and clothes can
be removed.
NOTE: If the water level or the temperature is too high, the
washer will drain automatically before the door unlocks.
To change Options or Modifiers after the cycle has started
1.
Select PAUSE/CANCEL.
2. Select the desired OPTIONS or MODIFIERS.
3. Select HOLD TO START (for approximately 1 second) to
continue the cycle.
To drain the washer manually
1.
2. Select DRAIN/SPIN.
begin the drain.
4. When the spin is complete, the door unlocks. Items can be
removed from the washer.
Nov 23, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Making my zooper available to 2 children with an attachment
First of all, a heartfelt congratulations! Second, it's definitely challenging having children so close together.
The Zooper Boogie is a good stroller and it's engineered in a VERY specific way to provide baby safety and comfort. It does this by providing a slightly lower center of gravity focused on the rotating single front wheel. This makes it more maneuverable for parents and keeps baby at the center of the swivel. Attaching a second compartment on the front or back of this particular carriage would undermine the engineered balance, tremendously. At least one occupant would suffer from an extended swing when maneuvering that could be more than just uncomfortable, especially if it was extended forward over the front wheel. Some stroller companies might be willing to do this, Zooper doesn't.
The best alternative that they offer is the Tango which is engineered for two. I know that you mentioned that you wouldn't purchase a double stroller but modifying a single might be uncomfortable and possibly dangerous for your little ones. I would recommend against it.
Once again, congratulations on your blessings!
Nov 11, 2007 | Zooper Boogie Jogger
Zooper Boogie Jogger Logo
146 people viewed this question
Top Zooper Baby Gear Experts
Jennifer Rock
Jennifer Rock
thegtw
Dorel UK
Dorel UK
Are you a Zooper Baby Gear Expert? Answer questions, earn points and help others
