You might have to uninstall your keyboard restart your computer then reinstall it
try blowing out all of the dust from your keyboard using a fine air blower from an air compressor making VERY sure there is no MOISTURE in the lines.
dust causes static which causes lots of problems with a computer and its parts
click start control panel administration tools computer management device manager scroll to keyboards you might see a yellow exclamation or question mark or red x you will need to update driver right click to update driver
make sure the lead connection is secure and dust free (if applicable)
make sure the usb device is inserted correctly into the usb port (if applicable)
if your computer came with a motherboard disk the drivers could be on it
or restart you computer tap the f8 key repeatedly to enter safe mode where the only things working will be your keyboard and mouse allowing you an attempt to repair your computer
if you need more help with this post a reply
hope this helps you
