Question about ASUS P5S800-VM Motherboard
AGP card Thanks for answer. What happend if AGP card not working, and will be no signal on monitor, which plug to AGP? can I plug in to motherboard video to see Bios?
  • Anonymous Oct 08, 2008
    drivers
    Sergeant:
  • 306 Answers
Yes, if the AGP video card has failed then there will be no display on the monitor. Try reseating the AGP card first as that is a common problem. If you have a PCI video card you could use that to check your BIOS. For the second asker, Guest, you download the drivers from the ASUS website.
Posted on Nov 15, 2008
I have a Dell Dimension 2400 desktop. It needs a monitor. I tried new ones from Best Buy and Office Max but they say no signal when I hook them up..I tried this computer with monitor in the following
Thank you for replying,
As per the diagnostic LED's, it is an issue with Video initialization failure. Your computer has onboard Graphics which is built into the Motherboard.
Video Initialization failure could happen if there is :
Unseated AGP card
Bad AGP card
Bad motherboard
As per your Svc Tag your system doesn't have AGP Graphics Card, Probable issue with MOBO.
This computer doesn't have a AGP Slot (Graphics Card Slot) to try connecting Graphics Card.
Need to repair/replace MOBO.
Thanks.
Feb 25, 2014 | Dell Dimension Computers & Internet
No display on monitor & if ram open and restart on then no sound on buzzer.
*Please Read full post before trying Also download the Online manual for this motherboard it takes only a minute and probably will answer a lot of questions you might have regarding *********** Board.*
Um... i am assuming your able to still see the display on the monitor if you plug your monitor into the on board video card. I am also assuming that the problem your talking about accursed when you plug in a video card into *********** board and then plug your monitor into that video card. I am also assuming your graphics card that you want to plug into *********** board is a AGP slot card.
If both of these conditions apply to you then try this.
Start your computer with your on board graphics card and unplug any other graphics card form *********** board.
Next go into your bios, and follow these instructions:
Go to "Advanced", "Chipset", And then "AGP configuration".
Next change your "Select AGP 3.0 Data Ratio" to "4X".
Next change your "Graphics Adapter Priority" to "AGP/Int-VGA"
*make sure its set to" AGP/Int-VGA" or your display will not work and you will need to reset your bios via the mother boards jumper cables.*
After that hit esc and go to "Exit" select "Exit
Sep 24, 2010 | ASUS K8S-MX Motherboard
Lights and Fan are working, but no beep.
First open cpu cabinet.
Then refix RAM memory.
Pull cmos cell for 10 minutes so all settings of motherbord are defaults.
Then pull porcessor fan and processor clean dust from all chip and parts.
Remove pci cards from pci slot then check.
Let me know if you need more assistanse.
Thanks.
Sep 21, 2009 | EliteGroup P4M800PRO-M2 (V2.0) Motherboard
Monitor says: no signal input check video cable Even though the computer is on.
Sounds a bit bland but either the monitor has failed or the video card
Only test is to plug your monitor into another system and see if it comes to life
If it does then your video card has expired.
If it is part of the motherboard then the easiest option is to buy a replacement which plugs into the AGP slot
They are dirt cheap unless you are into gaming when the sky's the limit
Jun 27, 2009 | Hannspree HANNS-G 19" Widescreen Monitor
AGP problem
you need to uninstall addon card
Jan 06, 2009 | ASUS P4S8X-MX Motherboard
Don't give any signal at monitor
I mentioned this for someone else with this mb. you can only use a 1.5v (V= Volt) agp video card, older agp video cards are 3.3v (anything new today or in the last 5-6 years is 1.5v) a 3.3v agp video card will permenently damage this motherboard! and some are incorrectly "keyed" for the slot (the last remaining run before the 1.5v turnover)
Funny thing is they recently introduced "universal agp" 3 "keyed" agp video cards. these can be confusing as well because some do have 1.5v and 3.3v capabilitys while others that still have the 3.3v "key" do not, nor will they draw 3.3 volts even if placed in an older 3.3v only slot, just 1.5 volts.
This is a finicky situation, and this motherboard along with many others in its class can leave you with more questions than awnsers in the end the more you seem go searching for them.
I hope you didnt damage your motherboard with the wrong agp card.
and maybe this will help others in the future with the same dilemma.
Aug 02, 2008 | Asrock K7VT4A-Pro Motherboard
Graphic card problem
Hi BIOS21, I know this much. I know you're motherboard can not use a PCI-Express video card. You're board can not support SLI. I know from looking & reading the manual for the MSI KM4-L you're board supports an AGP video card. I also know some AGP video cards need extra power for them to function. This varies from card to card. You did find an open power port on you're AGP NVIDA 6600 256MG 128bit card. So plug in the power cord. Every AGP card receives power from the AGP port. Enough to run the fan. Depending on the card it may also need more power provided by the system to function. This is you're case. The power connector would not be on the card if it was not needed. Other AGP cards use the same power cord as a floppy drive. (Just so you know).
Mike
Jun 11, 2008 | MSI KM4M-L Motherboard
Video signal
If it worked fine before the AGP card was removed then the problem is probably related to your BIOS settings. The BIOS setting that controls the integrated video may be set to OFF.
  1. Insert an AGP video card
  2. connect the monitor to the card
  3. boot to BIOS
  4. check settings
  5. turn ON integrated video
  6. save and exit BIOS
  7. shutdown
  8. Remove AGP card
  9. connect monitor to motherboard video port.
  10. Reboot.
What happened?
Jan 26, 2008 | EliteGroup 661FX-M Motherboard
Video card
actually your computer is working on the onboard video adapter.
1. connect first the monitor to the onboard video card.( do not remove the connected geforce video card.)
2. switch on the computer and press "F2" on new model computer, "Delete" on old model computer.
so that you can enter to bios setup.
3. if bios setup is open; try to find the "AGP bridge configuration"
(some other bios AGP B C is in chipset) by arrow up,down,side left and right) enter.
4. Find " primary graphics adapter"
5. In there, select : If Video card is "pci" connected ; select "pci"
If Video card is "AGP" connected ; select "AGP"
6. press F10 to save and exit the setup.
7. after saving the configuration, disconnect power cord and transfer the monitor to the video card (Gforce). and then connect the ac power cord and then start. or switch on the computer.
Note: be sure to install the drivers of your GFORCE for optimum performance of the card.
hope this help.
Dec 21, 2007 | ASUS P4P800 SE (890552603657) Motherboard
ASUS P5S800-VM Motherboard Logo
115 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
