Question about Panasonic Lands Phones
I have a panasonic kx-ta624.I have a anolog line coming into port CO1 and feeds all the jacks my problem is i can make calls but cant recive them. I am not using panasonic phones but was told the system was working before with out them.
  • Panasonic Master
  • 2,460 Answers
You have to have ONE 7x3x phone plugged into Jack 01 in the system or you don't stand much of a chance to make this work.
There is no USB interface to program a 624 and the ringing is controlled by programming. By default, turning off the system will tie CO1 to Jack 01 in power fail transfer. If you believe the line is functioning, then plug it into CO1, a phone into Jack 01 and call your number. If it rings, then you have connectivity, now puwer up the system and do the same thing. If it doesn't work, then you need to program the box.
Carl
Posted on Sep 08, 2008
No access to outside lines from one jack
Hi, What you can try is check the plug connection. If they are bent or broken. Replace the cable to and from the phone. If that is OK then you know the phone is the problem. Take it to be repaired.
Jan 20, 2014 | Panasonic KX-T7730 Corded Phone
CO problems
Check your Phone if connected to Jack 01 to do programming below:
on KX-T7730 phone Press Program *# (enter Password) default is 1234
Press 400 SP-Phone(CO NO.? will be displayed) Press *(Mixed or Connect will be displayed), Press AUTO ANS/MUTE untill (NOT Connect will be displayed) Press AUTO/STORE. Press HOLD(SYS PGM will be displayed) Press 400 (CO Connection will be displayed) Press SP- Phone(CO NO.?) Press SP-Phone (Not Connect will be displayed) Press AUTO ANS/Mute until (Connect will be displayed)Press AUTO/STORE PRESS PROGRAM to return to NORMAL Display.
For the incoming Calls PRESS Program *#1234 (ENter Sys PGM will be displayed) PRESS 408(Day IN CO will be displayed) Press SP Phone (CO No? will be displayed) Press SP Phone (CO1:#01:DISABLED if this is displayed PRESS AUTO ANS/MUte the Enabled will be displayed) Press AUTO/STORE. Press Program to return to normal display. In this Manner All Calls will ring to extension which is connected to Jack 01. you dont need to press the button anytime there is an incoming call.
Dec 04, 2013 | Panasonic KX-T7730 Corded Phone
Unable to get an outside line / dial tone from my phone (KX-T7735-B) originally erroneously reported as a KX-T7335
If this is VOIP then the problem is with Comcast. The settings need to be set to recognize a two line phone. The long way around this is to find out the equipment they are using for switching from a digital to an analog signal and call the manufacturer for help.
Nov 14, 2013 | Panasonic Kx-ta624 Advanced Hybrid...
Determining which CO you get when pressing 9
Set outgoing line preference.
Or simply swap the CO1 and CO2 line plugs.
The plug from your service provider that enters in CO1 put it in CO2 port and vice versa.You may need alittle config as well.
Oct 26, 2012 | Panasonic KX-T7730 Corded Phone
I had a KX-T7730, i have 2 line and use to be store as CO1 & CO2.. then other time when i try to store a speed dial.. everything got mix up.. now when i colleague hold a call, i can't pick up the call...
From the idle phone, press PROGRAM the button where line 1 used to be and dial 0 1 STORE do the same for line 2 if you unprogrammed that, using 2. Press PROGRAM or pick up the handset and drop it back down to end programming
Carl
Apr 18, 2011 | Panasonic KX-T7730 Corded Phone
How can I get the music on hold to work on the Panasonic Advance Hybrid System KX-TA624?
On the cabinet, there is a jack marked EXT MUSIC. You plug in an audio source to the jack and then go into system programming and turn it on in program 111.
Carl
Feb 04, 2011 | Panasonic KX-TA1232/KX-TA624 phone
How do I program the phone to ring on an incoming call? The ringer is on.
The solution will depend on why the phone is not ringing. Do you have a good cable? (Can you get a dial tone and make outgoing phone calls?) If you don't have a dial tone, use another phone to check if the phone is the problem or if the jack is at fault.
Next is the phone forwarding calls or in the "do not disturb" mode.
If the problem is one of the above, which model of the Main Unit do you have, KX-TA624 or KX-TA1232?
If the unit is in the "do not disturb" mode, to cancel: pick up the handset, press Program then 0 followed by # with the TA624. For the other model, press Program followed by 0 . Then hang up the handset. For this the manual says press the FWD/DND button not the Program button. I'd check both.
To cancel Forwarding, except for Follow Me Forwarding, pick up the handset, press FWD/DND and then 0 and # (TA624) or 0 (TA1232) then hang up the handset. To cancel Follow Me Forwarding: pick up the handset, press FWD/DND then 8 followed by the extension number. Then press # for the TA624 and hang up; just hang up the handset for the TA-1232.
I hope this helps.
Sep 23, 2010 | Panasonic KX-T7730 Corded Phone
I can't access my co1 outside line on the KT-x7735
It could be a couple of things. First, press PROGRAM and the CO1 button. If it does not say CO-1, then dial 0 1 STORE and it will.
If it does, you probably altered system programming and that line is now restricted from the phone. That requires Installer system access to the programming from the phone connected to the first jack in the cabinet.
Carl
Jul 12, 2010 | Panasonic KX-T7735 Corded Phone
Lands Phones Logo
209 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
