Question about Xerox Office Equipment & Supplies
I have a Xerox phaser 8500 with a 09,038,46:79099 code
  • Jerrell Mitchell Sep 08, 2008
    Thank you for your help. We have not got the training course for this model yet.
    President:
  • 2,072 Answers
That is a code telling you your black ink stick has not moved down into the ink loader properly.
Look at, in particular the black sticks, thats what teh ,46 means, 46 refers to the black ink.
One may be cracked, twisted or some ways stuck not sliding down into the bottom of the ink loader.
If you have to remove it, use a screw, a drywall type screw to twist into the block and slide them back and out.
If you somehow managed to get an ink stick in the machine from another phaser model, those are shaped different and will not actuate the swit5ch at the bottom of the loader.
Posted on Sep 08, 2008
Replace drum in xerox phaser
asic technical parameters forToner cartridge chip of Xerox Phaser 3450B:
chip-b.jpg" ]
Version: No area limited
Yield: 5,000-10,000.
Printers Model compatible: Xerox Phaser 3450B
Toner cartridge Model: Xerox 106R00687-BK and Xerox 106R00688-BK.
Manufacturer regulations pages yield ofToner cartridge chip for Xerox Phaser 3450Bis 5,000-10,000 then printer do not print andDrum chip for Xerox Phaser 3450Bhas mission paper pages count.You should resetDrum chip for Xerox Phaser 3450Bcaused by following reasons:
And then, you can choose one in three following plans: replace Toner cartridge, replace Drum chip or reset Toner cartridge chip.
1.Replace new Toner cartridge for Xerox Phaser 3450B:
- If you choose plan replace Toner cartridge then cost is too high. Each Toner cartridge for Xerox Phaser 3450B (Xerox 106R00687-BK and Xerox 106R00688-BK Toner cartridge) costs about $150 - $200
- With replace new Toner cartridge solution is not optimal, because the price is quite expensive.
- When Xerox Phaser 3450B shows errors about computing limits of Toner cartridge chip, you continue to replace new unit.
2.Replace new Toner cartridge chip for Xerox Phaser 3450B :
khe-chip-b.jpg" ]
- If you choose plan replace Drum chip then cost higher than reset chip. EachToner cartridge chip for Xerox Phaser 3450Bcosts about $6 - $10/color.
- With replace new Toner cartridge chip solution is cheaper replace new Toner cartridge.
- When Xerox Phaser 3450B shows errors about computing limits of Toner cartridge chip, you continue to replace new Toner cartridge chip.
3. Reset Toner cartridge chip for Xerox Phaser 3450B
If you choose plan resetToner cartridge chip for Xerox Phaser 3450Bthen that is best plan. It cheaper than replace Toner cartridge or replace Drum chip
The phenomenonToner cartridge chip for Xerox Phaser 3450Bout of count are printer do not print and display error on the LCD monitor:
-"Drum low", "Drum eppty", on monitor laptop or desktop appear yellow exclamation mark corresponding color, on monitor printer report Drum empty.
-"Tone life end", "Replace new unit"
- "The x unit an error". In that "x" is color of Toner cartridge or code of Toner cartridge
How to fix the errors:"Drum low", "Drum eppty", on monitor appear yellow exclamation mark corresponding color,"Tone life end", "Replace new unit", "The x unit an error"? cheaper, the most effective.
We use unismart device toreset Drum chip for Xerox Phaser 3450B
Unismart is a device reset Drum chip. Unismart can reset for many Drum chip of manufacturers: Samsung, Hp, Canon, Epson, OKI, Xerox ...
Unismart system is designed to offer a complete solution for writing, resetting, testing various chips with the combination of Unismart Box and Unismart chips. Unismart include: unismart box and test head, power adapter, Data wire, flat writer.
unismart1.jpg" ]
Test head is used for data transmission between Unismart Box and Unismart chips. There are 20 types of test heads designed according to different chip shape, which can be used for operation on all chip models that
current Unismart system supports. Please choose the right test head in accordance with the PCB code. Some PCBs share a same test head, which is clearly indicated in the chip compatible list.
In Case You Still Having Problem Then Follow Us For On :Xerox Printer Support
Jan 23, 2014 | Xerox Phaser® 860, 8200 Standard Capacity...
Xerox Phaser error code: 09,038.46:37640
The ink loader 133K27771 is probably defective
Whit
Item, Inc.
Jul 26, 2010 | Xerox Phaser 8560DN Laser Printer
What is error code 941 on a Xerox Phaser 7400?
www.support.xerox.com -phaser 7400- support -fault code-941 says cyan or magenta toner failure, but the solution says to
1. remove & reinsert the cyan or magenta imaging units.
2. replace imaging units .
check out the site to see if helpful
Jul 01, 2010 | Xerox Phaser 7400DN Laser Printer
Xerox Phaser 8200 Error Code 15004.45:18370
unless you know how to service preheater/drum heater then you have no choice but to ask the qualified person to do it for you....
YOu can read more details baout the failure at below link..
http://etech.maiila.com/xerox-phaser-8200-drivers-software-manual-and-troubleshooting
Apr 22, 2009 | Xerox Phaser 8200 Laser Printer
Phaser 8560 error code
Most likely you are using generic ink or ink not made for that specific machine. The black ink is the one causing the problem. the printer will then need to be reset.
Apr 15, 2009 | Xerox Phaser 8500/DN Printer
Phaser 8200
That normally indicated a heating issue with the print head. Could be the printhead itself or an issue with the electronics module providing the source voltage for that heater
Mar 12, 2008 | Xerox Phaser 8200 Laser Printer
Phaser 850
Flat Rate - Complete On-Site Repair Service of your broken Tektronix / Xerox Phaser Printer
iTezen.com is Now offering Complete On-Site Repair Service of your broken Tektronix / Xerox Phaser Printer at a flat rate. Basically we repair any problem you may be having with your Phaser Printer for a flat rate. The flat rate covers cost of parts, labor and travel expenses. The flat rate is all you will pay to get your printer back in order. No hidden fees or charges. We show up! We Repair it. You pay us the rate for you model.
Our Flat Rates:
MODEL: Tektronix Phaser 840 Color Printer Repair - $159
MODEL: Tektronix Phaser 850 Color Printer Repair - $159
MODEL: Xerox Phaser 860 Color Printer Repair - $159
MODEL: Xerox Phaser 8200 Color Printer Repair - $159
MODEL: Xerox Phaser 8400 Color Printer Repair - $179
MODEL: Xerox Phaser 8500 Color Printer Repair - $199
MODEL: Xerox Phaser 7700 Color Printer Repair - $209
MODEL: Xerox Phaser 7750 Color Printer Repair - $249
MODEL: Tektronix Phaser 780 Color Printer Repair - $179
MODEL: Xerox Phaser 790 Color Printer Repair - $179
To further guaranty the quality of our services we accept COD payment (Cash On Delivery of service).Our technician will arrive at your location and repair your printer, get you printing again, then collect the payment.
We have technicians in:
Alabama, Arizona, Arkansas, California, Colorado, Connecticut, Delaware, Florida, Georgia, Idaho, Illinois, Indiana, Iowa, Kansas, Kentucky, Louisiana, Maine, Maryland, Massachusetts, Michigan, Minnesota, Mississippi, Missouri, Montana, Nebraska, Nevada, New Hampshire, New Jersey, New Mexico, New York, North Carolina, North Dakota, Ohio, Oklahoma, Oregon, Pennsylvania, Rhode Island, South, Carolina, South Dakota, Tennessee, Texas, Utah, Vermont, Virginia, Washington, West Virginia, Wisconsin, and Wyoming.
Itezen, Inc.
Tel. 516.776.7346
http://www.itezen.com/
Email: sales@itezen.com
Feb 08, 2008 | Tektronix Phaser 860DP Thermal Printer
Phaser 860 error code 07.003.45:116163
It is a print head tilt error.
Most likely ink is in the stainless steel pivot block at the bottom of the print head.
Also the printer could have been unplugged and the cleaning blade is stuck to the print head.
Or a cable is binding the print head movement.
Nov 12, 2007 | Tektronix Phaser 860DP Thermal Printer
74 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Whit
Whit
Level 1 Expert
iteminconline
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
