Question about NetGear FM114P Cable/DSL ProSafe 802.11b Wireless Firewall (FM114PGE) Router
How To Configure FM114P or FR114P for an Internet Connection and Printer Sharing
    Novelist:
    Scholar:
  • 123 Answers
There are three steps: 1. Configuring the router for Internet access 2. Installing and configuring the print server 3. Adding the printer to the Windows configuration To Configure the Router for Internet Access 1. Connect the modem to the router's Internet port and your LAN computers to the router's LAN ports. 2. Shut down your LAN computers. (Power them off.) 3. Power off the router. 4. Power off the modem. 5. Power on the modem. 6. Power on the router. 7. Start the LAN computers. 8. Enter 192.168.0.1 in a Web browser's address. 9. Type username and password (by default admin and password). 10. Click Setup Wizard to configure the router's Internet access. To Install and Configure the Print Server 1. Install the Printer Server Driver program on a computer. 2. After installation, make sure to select the Run Print Port Setup now box. 3. Click Finish. Print Port Setup runs, showing you the firewall and the printer. 4. Click Port 1. 5. Click Add. A pop-up message says whether a port was created, then the Add Printer wizard starts. To Add a Printer With the Windows Add Printer Wizard 1. Continuing from the last section (or clicking Start > Settings > Printers > Add Printer), click Next. 2. Select Network Printer, and click Next. 3. Click Next again (leaving the port as LPT1). 4. Select the manufacturer and printer model of your printer. (If your printer does not appear, you need to get the CD or floppy that came with the printer, and use Have Disk to specify the file location. Note that it is looking for a file that ends with .inf.) 5. Click Next. 6. Change the printer name to something users on your LAN will recognize easily. 7. If prompted by the Add Printer Wizard about sharing: DO NOT enable sharing! Now test the printer. Other information about Windows configuration is available in Windows help in the article "To connect to a printer on a network".
Posted on Feb 19, 2006
SOURCE:
Unable to find printer sharing for mfc6890 over window xp
To set up printer sharing in your home network, you need to configure printer options in the control panel of Windows XP Operating System. You could get a menu while right clicking the printer icon in the Control Panel. From this, you need to select the sharing option. You also need to make sure that you have enabled printer sharing option in the network card properties. To connect a printer in the network you need to set an IP address for your printer. If you have any troubles with printing with your printer in the network it might due to the errors in the network. So, you need to make sure the network connection.
Apr 06, 2011 | Brother MFC-6890CDW Printer
Tip
How To Use Your Mac As a Wireless Router
1) You need to configure your Mac (the one connected to your modem) to share its Internet connectivity with other wireless devices. To do this, select System Preferences from the Apple menu, and then click on Sharing.
2) In the Sharing window, click on the Internet tab to bring up Internet Sharing. Select Built-in Ethernet from the Share your connection menu. Then, select Airport in the To computers using list
3) Click on the Airport Option button to configure some wireless security options. You Only want to be sharing your wireless connection with Your Other computer. Enter a Network Name, select channel as Automatic, and enable encryption and enter a WEP password, which will be required to join your new wireless network. now click on Ok
4) Now your mac is acting a wireless router just connect to your network from other computers and enter the WEP key when it ask for it.
You found this to be an excellent solution when you don’t have a wireless router, but would like occasional wireless access in your home or small office.
Regards
Sandeep Shrivastava Founder & Owner of FixMyPCAndMac.com TotallyTechStuff.com Visit for More Solutions
on May 19, 2010 | Computers & Internet
Tip
Set up and Use Internet Connection Sharing
To enable Internet Connection Sharing on a network connection
You must be logged on to your computer with an owner account in order to complete this procedure.
Open Network Connections. (Click Start, click Control Panel, and then double–click Network Connections.)
Click the dial–up, local area network, PPPoE, or VPN connection you want to share, and then, under Network Tasks, click Change settings of this connection.
On the Advanced tab, select the Allow other network users to connect through this computer's Internet connection check box.
If you want this connection to dial automatically when another computer on your home or small office network attempts to access external resources, select the Establish a dial–up connection whenever a computer on my network attempts to access the Internet check box.
If you want other network users to enable or disable the shared Internet connection, select the Allow other network users to control or disable the shared Internet connection check box.
Under Internet Connection Sharing, in Home networking connection, select any adapter that connects the computer sharing its Internet connection to the other computers on your network. The Home networking connection is only present when two or more network adapters are installed on the computer.
To configure Internet options on your client computers for Internet Connection Sharing
Open Internet Explorer. Click Start, point to All Programs, and then click Internet Explorer.)
On the Tools menu, click Internet Options.
On the Connections tab, click Never dial a connection, and then click LAN Settings.
In Automatic configuration, clear the Automatically detect settings and Use automatic configuration script check boxes.
In Proxy Server, clear the Use a proxy server check box.
Bhautesh.
on Feb 24, 2010 | Computers & Internet
How to conect with wireless internet
The Network and Sharing Center in Microsoft* Windows Vista* can be used to set up a secure wireless connection to the Internet.
Note: If an Internet connection is not automatically made by the operating system, you may need to contact your access point (AP), broadband wireless router manufacturer, or Internet Service Provider (ISP).
Set Up a Secure Wireless Connection to the Internet
These steps assume that your network adapter; AP or router; and cable, DSL or another type of modem have already been physically connected and configured. They allow you to create a new connection and configure it accordingly.
Follow these steps to set up a secure wireless connection to the Internet.
Note: If a wireless profile does not exist, you will need to create a secure wireless profile before you can set up a wireless connection to the Internet.
1. Access the Network and Sharing Center.
2. Select Set up a connection or network.
3. Click Connect to the Internet.
4. Click Next.
5. Select Wireless. At this point, if the network(s) that are listed say that the network settings do not match the network requirements, as shown in Figure 1, create a secure wireless profile and then follow the steps again.
6. Select a network and click Connect. If you are not connected to the Internet, you may need to contact your AP/router manufacturer or ISP.
To access the Network and Sharing Center, use one of the following methods:
  • Start » Control Panel » Network and Internet » Network and Sharing Center
  • Start » Network » Network and Sharing Center
  • Right-click the network system tray icon (the icon that displays two computer monitors) » Network and Sharing Center
Jan 21, 2011 | Computers & Internet
I hooked up my D'link to modem and computer and connection is good. But i can't find it when i search on laptop wireless connection. I think you need i driver but i can't find one. Thank You
4. Click Next.
B52Computers
Jan 14, 2011 | D-Link 802.11g Wireless Router WBR-1310...
Can't get my lap top to connect wirelessly to my router. Model # WRT54G2. The laptop says it is reaquiring the network address, but nothing happens.
4. Click Next.
Jan 10, 2011 | Linksys Wireless-G WRT54G Router
I got this computer for christmas and I cant get it to connect to any wireless wifi system. I dont know what I'm doing wrong. Could you please give me some instructions on how to connect it to a home...
4. Click Next.
B52Computers
Chris Thrash
Jan 10, 2011 | Computers & Internet
Internet sharing problem
hi..hmm try to remake new connection and it must all be the same like if your connection is MSHOME the other computer should be MSHOME. if is dosnt work configure your router wan and Lan.
Jul 12, 2009 | D-Link DES-1008D 8-Port Ethernet Switch...
Xbox live on this laptop
I assume you have a crossover ethernet cable.
put the my network places on your desktop.
right click on desktop/properties/desktop/customize desktop/tic
then on the network places icon on desktop right click/properties
right click on wireless and bridge devices
they are now sharing the same ip
be sure and remove /delete bridge when not sharing as the ip will stick forever likely.
that should do it if you need more info /open my computer and hit help and search for internet connection sharing as the firewall may need to be configured.
Jan 30, 2008 | Sony VAIO PCG-K35 Notebook
Feb 19, 2006 | NetGear FR114P Router
NetGear FM114P Cable/DSL ProSafe 802.11b Wireless Firewall (FM114PGE) Router Logo
231 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Mike
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
