Question about Polaroid FLM-3734B 37 in. LCD HDTV
Same won't turn on
CHANGE THE CAPACITORS!! it works! I just did it over the weekend and it runs fine.
Found the two 1000uf 10V capacitors that were bulged out on the power supply board located inside the main control box, replaced them with 1000uf 16v capacitors from Allied Electronics at $3.00. Took the parts to an electronics repair shop and had them replaced, these type of capacitors have a +/- pins so ensure if your soldering these yorself get the polarity correct, and don't replace them with 10v again thats probably why some are only lasting another week or two.
Posted on Sep 09, 2008
I'm getting a funny popping sound from the sub-woofer it appears; because when unplugged I don't hear it.
Looks like the capacitors on the amp are going.
If you hear a hummm sound when you turn it on without anything playing on it, then the capacitors are to blame for sure -> Time to replace the capacitors.
Feb 20, 2016 | Bose Acoustimass 10 III System
Dominic 2820 won't get cold
The Dometic RM 2820 was working last night. This morning it was not cooling and now the front panel and interior light are not working. No smell of ammonia. Any help with this challenge? Thanks,
Jun 11, 2013 | Dometic Classic Rm2820 2 way
My whirlpool duet electric dryer electrical systems and heat work fine, but drum won't turn and belt is in tact.
Check the motor capacitor,sometimes the capacitor could be faulty or the motor is faulty or check if the motor is receiving power,if it's receiving power try to replace the capacitor if the is any in the system,if still it's not working then the motor could be burnt.
Also check weather the timer is perfecty.
Sep 29, 2012 | Whirlpool Duet High Efficiency Electric...
Honda em5000sx generator won't start
I have a EM5000SX. My problem is my generator will not start unless I turn the fuel selector to off. Then crank it until it does start, turn the fuel back on. Run's normal . I run this generator for my cabin every weekend.
Aug 25, 2012 | Honda Electrical Supplies
My goodman condensing units fan won't start to turn on its own
Hello, usually this is a sign of a bad capacitor. Replace the capacitor.
May 21, 2012 | Heating & Cooling
My S5211 is 5 months old and was running perfectly. Last weekend I took it out to vacuum house but it would not start. I checked the fuse in the plug but it was fine. I replaced the dustbag but still it...
if you put everything back in place properly it should be working,check dust bag properly seated, and cover reseated, still not working do as planed, take it backto the shop, hope this helps
Sep 01, 2011 | Miele S5211 Deep Black Vacuum Cleaner...
The fan wouldn't start for the condenser unless I turned the blades with a stick so I replaced the start capacitor and it still won't start without turning the blades with a stick. It runs fine but...
This problem could be caused by a bad motor run capacitor. Please see our If your motor capacitor is not the problem, then more than likely you need a new motor.
Jun 13, 2011 | Ruud UBHC Air Conditioner
Wow great site! Problem with my 600 series penguin Unit started acting strangely last weekend, smelled something electrical when I first turned it on. but then cooled fine. This weekend DW took it out for...
Hello my name is Heath it will be my pleasure to assist you. What you are looking at is the start capacitor for the motor a $7 part at any HVAC supplier. If it is leaking it is definitely bad and needs to be replaced. This gives the compressor a boost on start up and drops out of the circuit after the compressor is running.
Jun 13, 2010 | Dometic Rooftop RV Air Conditioner
Condenser fan rotating the wrong way
If nothing has been changed you have a bad capacitor and need to change it. Then the fan will run in the right direction. RUSS
Jul 17, 2009 | Heating & Cooling
Polaroid FLM-3734B 37 in. LCD HDTV Logo
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
