Question about Electrical Supplies
Wiring help Hello. I have a problem and I'm not sure where to get help. I'm not working on any particular product. I am trying to make something. I would like to make a box with two 120V outlets in it. One controlled by a toggle switch, the other controlled by a float switch. I thought I could just wire it up with the entry point possitive to negative, but I only get 32V on the second outlet, and about 3 to 5 volts on the first outlet. Thank you for any help you can offer.
  • 2 more comments
  • the_jaydog Nov 28, 2008
    Yes, I think this worked. I realized that what I needed was a switch with two outputs. I went to radio shack and bought one and it fixed the problem. I know that I couldn't have done it without help from you guys. Thanks
  • Kevin O'Brien
    Kevin O'Brien May 11, 2010
    Did you do wire it like this?
  • Kevin O'Brien
    Did you do it like this?
  • kuwaitim
    kuwaitim May 11, 2010
    Are the toggle switch and the float switch rated for 120V?
  • 45 Answers
You seem to be misunderstanding something. The drawing which Blue Dog posted above shows a common power source connected to two separate switches. (one being your toggle switch, the other your float switch)
It does not show a single-pole, double-throw switch. (aka: a switch with two outputs)
Based on your earlier comment regarding "positive to negative" I assume that you were using a DC voltmeter. AC voltage is neither positive, or negative and it requires an AC voltage tester.
BTW:Be sure to observe correct polarity on all of your connections:
Silver colored screws: Neutral line
Copper colored screws: 120v line
Posted on Aug 25, 2009
  • 75 Answers
Sorry for my failed graphics!  You should do it like this, and like kuwaitim says, make sure everything is rated for your voltage.wiring help - 6a0feea.jpg
Posted on Nov 28, 2008
Hr 15 ecu pinout
Hello Persad Rajaram,
"Hr 15 ecu pinout"
Might be a wonderful INTERNET search... but way to cryptic for human understanding (both of your questions).
There's no EXTRA charge for intelligible.
What kind of trouble... (quest/issue).
What kind of vehicle... (year, make & model).
For free schematic drawings... (for POPULAR USA vehicles) I go to BBB Industries site (at the bottom)... REGISTRATION REQUIRED. If you don't have a USA model... use a close equivalent... The cars are usually similar... just the names are change to confound consumers (global games).
A better recommendation are WORKSHOP manuals...
In particular MANUFACTURERS ...
"PIN-OUTS" are usually a sign some-one is trying to REVERSE-ENGINEER something... Be very careful you are not violating intellectual property rights (patents & copyrights)... Something we are actually NOT going to violate on this sight.
Help us help you... (communicate).
Carnac the Magnificent BBB Industries Premium Alternators
Starters Power Steering Products
Sep 05, 2016 | Cars & Trucks
Mouse not working
Hi Anthony,
First thing i would check is to see if the Video cable is securely installed on both the PC and Monitor. As for the Mouse, did you try a different port? If that doesn't work, and since you said you had to move it, you might want to try reseating the RAM. Sometimes when PCs are moved around, things can get loose or misaligned, especially if it's bumped or knocked into something...particularly RAM and Video Cards.
Hope this helps!
Feel free to get back with me if you need further assistance:)
Gary
Jul 03, 2013 | Computers & Internet
Nintendo ds will not turn on. Plugging in the charger blinks and orange light, and then nothing. will not power on while plugged in, or not. is this the battery?
No Power
Make sure that the word "Wii" and the model number "RVL-002 (USA)" molded into the AC adapter. Unlicensed products are not fully compatible and may not work correctly.
Avoid the use of unlicensed products such as memory cards, controllers, and cheat devices. Some of these products are poorly manufactured and may result in damage to your system. If one of these products is attached to your system, remove it and try resetting the AC Adapter (see below).
Check all accessories, licensed or not, for phsyical damage. Physical damage, such as frayed wiring or a cracked housing can cause the system to shut down. Remove any damaged products and try resetting the AC Adapter (see below).
Make sure the Wii has good ventilation. Avoid operating the Wii while it's on carpeting or inside an enclosed space. If you have the Wii placed in a vertical position, make sure the vent on the bottom is lined up properly with the hole in the plastic stand and no foreign material is obstructing that hole.
Check the vents on the back and side of the Wii for dust build up. The system will shut down if it cannot vent properly to prevent overheating. If there is a build-up, remove it using a vaccum cleaner with a soft brush attachment.
Make sure that your wall outlet works. To check it, try plugging a lamp into the same outlet where your system was plugged in. Turn the lamp on the verify the outlet works. Also, make sure you are not using an outlet that is operated from a wall switch. If you do, make sure the wall switch is in the ON position.
Make sure the AC adapter is attached properly. Firmly plug your AC adapter into the back of the Wii (the port is labeled 12V IN) and into a working wall outlet (not a power strip or surge protector). Click here for detailed instructions.
Once plugged in, check the power light on the Power button to see if the system is receiving power.
If this fails, try resetting the AC adapter.
Unplug/remove all accessories from the system (including game discs, SD Cards, memory cards, Nintendo GameCube controllers, hookup cables, the AC Adapter, and Sensor Bar) from the outlet and Wii.
Let the system rest for about 90 seconds. While you're waiting, check to see that controller cords, AC Adapter, and Stereo AV cables/Component Video cables are not frayed or have exposed wires (this can cause the system to shut off); if so, you should replace those parts.
After the 90 seconds, Plug the AC Adapter into the system and directly into a wall outlet, not a surge protector or power strip. Check to see if the power light on the Power button comes on.
If the system works, plug ONE accessory into your system starting with the Sensor Bar, then turn the system on to see if it still works. Repeat this process with ONE accessory at a time. If your system doesn't work once you put a particular accessory in (Sensor Bar, GameDisc, Nintendo GameCube controller, Memory Card, SD Card, etc.), there may be something defective with that accessory.
If the power is still continually shutting off regularly, please click here for repair options. For this particular symptom, it is best to include your Wii console's AC Adapter with your system. This will help our technicians ensure they are able to resolve your issue.
Aug 14, 2011 | Nintendo DS Lite Console
Trying to help friend with her washing machine. It is a Kenmore 110.24532300 top load washer. It is filled with water and clothing at the moment. I have attempted to drain by moving it to Rinse and Spin...
Must be a broken lid switch.
To check it unplug the lidswitch
All the lid switches are not the same on these particular models.
Also the different models controls all flip up but how they flipis different
depending on production run. But I have a video:
Their are 4 or more styles of lid switches.
This connection has 2 live wires and a green ground wire. You can jump out the 2 live wires to operate the machine with the case off. Make sure what 2 wires are hot because it is different from model to model.
How it works
service manual and more
Feb 10, 2011 | Kenmore 22642 Top Load Washer
My download speed has been reduced from 20 Mbits to 2 Mbits after having plugged in a set of XE102. Why? Can I do something ? Regards Mogens Villy Møller Copenhagen Denmark
The top speed between the devices is 14 Mb/s, so they will never attain the 20Mb/s speed you had with you router / modem.
Netgear offers this FAQ for Powerline devices:
Problem: var js_3;function initPsDisplay(){js_3 = new PsDisplay({"info":{"controller_name":"PsDisplay","name":"PsDisplay_3","type":"FormField","w_id":3},"attrs":{"label":"","tabindex":"","field_name":"description","cf_id":"","table":"answers","highlight":0},"js":null});js_3.init();}YAHOO.util.Event.onDOMReady(initPsDisplay);
Workaround: var js_4;function initPsDisplay(){js_4 = new PsDisplay({"info":{"controller_name":"PsDisplay","name":"PsDisplay_4","type":"FormField","w_id":4},"attrs":{"label":"","tabindex":"","field_name":"solution","cf_id":"","table":"answers","highlight":0},"js":null});js_4.init();}YAHOO.util.Event.onDOMReady(initPsDisplay);
  • Powerline products work better when plugged into the wall without power strips, extension cords, surge protectors, or uninterruptable power supplies.
  • Passwords. Powerline products have both a network password, and a device password. A particular device's password, which is not changable, is printed on the Powerline product label. Once you have collected all your Powerline device passwords, use the encryption dialog box, as described on pages 9 and 12 of the XE102 User's Guide, to change the network password. (Without password protection, it is possible, although unlikely, for someone very nearby to access your network.)
  • If you changed the default network password, make sure that all the Powerline products use the same network password.
  • If you've moved a Powerline unit, or disconnected the cables, your other network devices may need about 5 minutes to refresh their information about the Powerline's current status.
  • If you have earlier Powerline products, switch to the encryption used by later products. (Early versions of XA601 and XE602 are known to have compatibility problems with newer models.)
  • To test whether a house's electrical wiring is contributing to Powerline problems, plug units in the same room. Examples of potential problems are:
    • Old fuse boxes.
    • Old wiring that does not meet modern wiring building codes.
  • Swap devices to isolate the problem to a particular Powerline unit.
  • Reset the Powerline adapters to the default settings using the utility.
  • Use all the same Powerline models for best connectivity. Also, software for one model may not work for another model. In particular, remote and advanced features may not work between Powerline manufacturers.
  • Powerline is not directed at businesses, however it may work in a business environment, anyhow. See Assessing Powerline for Business Environments. In some cases noise can be limited by placing line conditioners or surge protectors between the source of the noise, and the Powerline units. (Not between the units.) Consult a professional electrician to evaluate your electricity's noise and to suggest remedies.
Sep 29, 2009 | NetGear XE102 Powerline Ethernet Adapter...
The power bar is on red and it doesnt turn on
Here, this is directly from Nintendo-Costumer Service
No Power
If the power is still continually shutting off regularly, please click here for repair options. For this particular symptom, it is best to include your Wii console's AC Adapter with your system. This will help our technicians ensure they are able to resolve your issue. This is direct from; nintendo.com
Aug 20, 2009 | Nintendo Wii Console
No wirelesss network adapter or sound after installing Vista
Most likely the drivers aren't installed. Go to the product page for your computer and download the appropriate drivers for your OS.
Aug 02, 2009 | Dell Inspiron 1501 Notebook
Lanzar amp 1000 watt stays on protect mode
Hello snow11879,
I haven't been able to locate any support information online about your product, other than the email contact for support questions:
support@lanzar.com
If the amp stays in protect mode all of the time, I would suspect a short in the speaker wiring or speaker(s) voice coil(s), or perhaps a faulty ground. If it plays for a short period of time and then goes into protect mode, it is most likely overheating. First check all of the wiring. Test your speakers on a known good amp and make sure there are no places in your wiring where the insulation may have been damaged, causing an intermittent problem.
Many owners have reported that this particular amp has a tendency to overheat. Also, when run in bridged mode, the speaker impedance needs to be at least 4 ohms. It will overheat if the impedance is below 4 ohms.
Hope this helps.
Apr 18, 2009 | Lanzar VIBE266 Car Audio Amplifier
Frigidaire Actuator model glhs68egpb1
that awaur is definalty apain in the rear to reconnect, i would first see that the wire is in correctly( should fold along normal lines to get proper orentation)check both end of connection, remove power first, so as not to blowe any circuitry,a small pieceof masking tape should hold the wire at either end to teh facade so as to minimalize the stress/flexing of ribbon wire. be sure to check the up[per wire harnesssa s well, perhaps you disconnected and never re attached
Jan 06, 2009 | Refrigerators
Can't connect to the internet....
buy a better one - netgear or something less cheap and nasty
_Ahoy_
Oct 26, 2007 | Belkin (F5D7050) 802.11a/g/b Wireless...
Electrical Supplies Logo
1,201 people viewed this question
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
