Question about NetGear ProSafe FVS338 (FVS338NA) Firewall
Port Forwarding How do i handle port forwarding on this router?
    Novelist:
    Scholar:
  • 123 Answers
Instructions for DG834, DG834G, DG824M, FR114W, FM114P, FR114P, FR328S, FVL328, FVS328, FVS338, FVX538, FWAG114, FWG114P, or FVS318v3 These routers do port forwarding by assigning port numbers to a "service" associated with the application you want to run. "Rules" are set for particular services. Rules block or allow access, based on various conditions such as the time of day and the name of the service. To Create a New Inbound or Outbound Rule 1. Submit the router's address in an Internet browser. (The default is 192.168.0.1). 2. Enter the router's username and password. 3. From the main menu, click Security > Rules. 4. Click Add for inbound or outbound traffic, as appropriate to the application you are planning to run. 5. Select the Service. The services the router knows about are listed in the drop down. If the service you want is not listed, add it as described in the next section. 6. Select the Action, for example ALLOW always. 7. For Send to LAN Server, enter the IP address of the local server. Note that this is also the IP address the computers on your LAN will access. 8. For WAN User choose Any, or limit access to particular IP addresses. 9. For Log selection it is reasonable to turn logs on, especially at the beginning when you are unsure of the result of the changes you are making. Later, you may want to set logs to "Never" for performance reasons. 10. Click Apply. As noted in user manual for some models: * Consider using the Dynamic DNS feature on the Advanced menu, so that external users can find your network when the DHCP lease is renewed by your ISP. * If your own LAN server uses DHCP, and your IPs change on rebooting, consider using the Reserved IP Address feature in the LAN IP menu. To Add a Service for These Routers 1. Click Security > Services > Add Custom Service. 2. Enter any name you choose for the service. 3. Select whether the service is to use TCP or UDP. If you are unsure, select both. 4. Enter the lowest port number used by the service. 5. Enter the highest port number used. If the service uses only one port number, enter the same number. 6. Click Apply.
Posted on Feb 19, 2006
Linksys port forwarding
This WEB site shows how to port forward.
http://www.wikihow.com/Port-Forward/Open-Ports-on-a-Linksys-Router
May 05, 2013 | D-Link DSL-G604T Wireless Router
Where do i find the port forwarding?
To access the Port Forwarding option of your router, you will need to access the router setup page and from there you will find Application and Gaming tab and there you will see the sub tab port forwarding that is where you can open the port that you need to work behind the router.
Aug 12, 2011 | Linksys WRT54G2 Wireless Router
Can't view IP cam externally
Follow The Process:-
1.Visit https://www.yougetsignal.com/tools/open-ports
input the port 5000 and check is it open or not, if it is not open it means you need to check port forwarding in your main internet router/modem.
2. By Default Routers/Modems Http port it 80. so you need to change ip camera http port 80 to 81 and do port forwarding and to view on android devices check another ports in ip camera network settings. so same port forwarding and check in yougetsignal website.
Visit Here for next level help:-
CCTV Networking Technical Support
Jun 10, 2017 | D-Link Securicam Network DCS-950G Wireless...
Router cant handle two pc's connecting to same server
Try to do port forwarding. Search for the port number that the game uses and open it on the router's Setup Page using Port Forwarding.
Apr 25, 2009 | Linksys (WRT54GC) Router
Port forwarding & Remote Management setup on Linksys WAG200G
here is how you set up port forwarding:
1. log into the router;
2. Click the Applications & Gaming link near the top of the page. 3. You should now see a new menu. Click Single Port Forwarding or Port Range Forwarding.
4, Enter sth like: HTTP; 80; 80; TCP; 192.168.0.1; check
5. When you're finished, click Save Settings near the bottom of the screen to save your changes.
go to administration-> remote administration to set up remote management
Remember, remote Administrator requires you to forward the 4899 ports.
Mar 23, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Port forwarding GLB-502Trouter With utorrent
Here is a link to the specific steps you need to setup port forwarding on the GLB-502T
http://portforward.com/english/routers/port_forwarding/Dlink/GLB-502T/Lingo_VoIP.htm
Dec 29, 2008 | D-Link ADSL2/2+ Modem/Wireless Router...
New topic about Intellinet Active...
You have a switch which is like a hub. You want a router, the router will assign IP addresses to each computer in your home. If you need to set up port forwarding then you do that within the router settings. For the most part newer routers have Universal plug and play which will handle the port forwarding for you.
May 31, 2008 | Intellinet Active Networking Intellinet...
Port fordwording is not working for Radmin port 4899
when you do port forwarding you must know or have a static ip of the device for the application. For example, if you want to forward port 3074 for your xbox live, you need to enter also the xbox ip address on the port forwarding page. Port forwarding is like opening a port on your firewall for that specific application. Make sure also that you have the latest firmware of the router.
Regards
Mar 07, 2008 | Linksys WRT300N Wireless Router
Port Forwarding
To Enable Port Forwarding for MR314 or RP114 1. Type the router's address in an Internet browser's address bar. (By default the router's address is 192.168.0.1). 2. Enter the router's username and password. 3. Click Advanced > Ports on the left menu bar. 4. Enter the first port number in an unused Start Port box. 5. If only one port number is to be forwarded, enter the same number in End Port. To specify a range of ports, enter the last port to be forwarded in the End Port box. 6. Enter the IP address of your local server in the Server IP Address box. 7. Click Apply.
Feb 19, 2006 | NetGear MR314 802.11b
Port Forwarding
Feb 19, 2006 | NetGear RP114 Router
NetGear ProSafe FVS338 (FVS338NA) Firewall Logo
436 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
