Question about Whirlpool LEB6300 Electric Dryer
Whirlpool electric dryer LEB6300 door
The dryer is on but won't start when the door is shut.  Apparently the light remains on. I can see it from the back of the dryer.  I believe the problem is the light switch on the door.  If I push it up and flat against the dryer frame and tape it down the dryer will then run. How do I replace this switch?  Thank you for your help.
  • 958 Answers
You have to lift the top cover. then from there you can access the door switch of the dryer.
look closely between the front wall and the top cover. pry the top cover slowly and push the plastic lock that is holding the top cover.
then you can see the switch now and replace.
tnx 4 using fixya,
drcool
Posted on Sep 08, 2008
It will not turn on. When I unplug it and plug it back in the start light is constantly blinking. I checked for error codes and the 4 lights blink 9 times and the start button blinks 14 times.
Electric dryer no start does nothing
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage.
CHECK THERMAL SHUT OFF THERMOSTAT USUALLY LOCATED ON THE BLOWER. for OHMS or resistance with a meter. Should show a closed circuit. Ohms WHEN THIS FUSE BLOWS IT WILL SHUT DOWN EVERYTHING.
NEXT Test the PUSH start switch with meter for OHMS. Should show OHMS when pushed in or on start, and no ohms or infinity when in off position.
If you hear a humming/clicking sound from motor area you more than likely have a bad motor.
Try this test out to see if u have weak windings or relay/capacitor on motor.
Open the dryer door and turn by hand the drum while machine is on ON position. And you or someone else presses the door engagement switch in. If it starts up then u have bad windings
Another thing to check is the belt safety switch. With a multi meter.
Especially if u just replaced the belt. The belt safety switch is attached to the Tensioner and motor. IT LOOKS LIKE A DOOR SWITCH SOMEWHAT a little black pc of plastic with 2 prongs going into it. Sits at bottom of motor. Under the Tensioner. Attach meter clips to the 2 prongs on switch, Then when the little white push button is pressed in it should show continuity and none when released.
Lastly check ur DOOR SWITCH for continuity with a meter when the button is pushed in the (on/Door closed position,) it may have gone bad.
https://www.youtube.com/watch?v=MhVUEhngZMg
https://www.youtube.com/watch?v=9xD7lCXJ0ZM
https://www.youtube.com/watch?v=sTRP6kHqAFs
Hey GOD IS GOOD !!!! WHICH IS WHY MY ADVICE IS FREE
Kenmore Whirlpool Dryer Won Start Easy Fix What to Test When Whirlpool or Kenmore Dryer Won Start or Run Kenmore Whirlpool Dryer Won Start Easy Fix Troubleshooting Why Your Dryer Won Start PartSelect com
Nov 09, 2015 | Kenmore Dryers
Won't start !
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 13, 2011 | Whirlpool LEB6300 Electric Dryer
REPLACING HEATING ELEMENT IN ELECTRIC ESTATE WHIRLPOOL DRYER
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jul 27, 2010 | Whirlpool LEB6300 Electric Dryer
When I push button to start dryer nothing happens Is it the switch or could it be more?
check your door switch! make sure its working also check your breakers and recept voltage
Jan 13, 2010 | Whirlpool LEB6300 Electric Dryer
Whirlpool LER8620 electric dryer, shuts off at random. When it
Sounds to me like a thermal fuse. The link gives you multiple scenarios and you can even order replacement parts. I have used it myself with success on washers and dryers. Good luck!
Sep 13, 2017 | Whirlpool LER7646E Dryer
Overheated , now fixed but have no powe
You may hae a non-resettable thermal fuse that opened.. when that happens.. system won't operate..
Sep 03, 2008 | Whirlpool LEB6300 Electric Dryer
Dryer won't start
i would start simple, check your door switch for continuity and then check the start switch. If this is an electric dryer make sure you have a ull 220 volts to the dryer, anything less and only part of the machine (timer) will operate
Feb 10, 2008 | Whirlpool LEB6300 Electric Dryer
Whirlpool LEB6300 Electric Dryer Logo
62 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
