Question about LG Refrigerators
Ice forming daily on freezer bottom
On a daily basis, we are having to chip await about a 1/4 inch of ice which is forming on the left bottom of the freezer. If we don't do this, eventually it starts to melt and leak out of the freezer onto our floor. We don't hear any strange noises. We do notice a drip line (frozen) on either side of the back of the freezer of what looks like a vent into the freezer. We don't see this on the right side of the freezer. We notice a little frost in the middle of the freezer at the top. Any ideas?
  • 1,031 Answers
Ice build-up on the bottom of the freezer usually means that there is a problem in the self-defrost system. You may even have damaged door gaskets. When you open the freezer door, you also let in a blast of warm, often humid air. This moisture usually freezes onto the evaporator coils immediately. Self-defrost freezers are supposed to self-defrost themselves. Every 6-12 hours they turn off the compressor for a few minutes. A defrost heater then turns on to melt any frost build-up on these coils, which allows the frost and ice to melt, then it drains off to the pan underneath. Unfortunately, though, when a component fails, too much frost can build up on the evaporator coils. With no air flow over the coils, cooling in the freezer compartment becomes almost non-existent.
You can manually defrost your freezer by turning it off for 24-48 hours and turn it back on to see if it begins to work properly. If your freezer now works the way it's supposed to, test the three other components in the self-defrosting system, the defrost heater, the defrost thermostat, or the defrost timer.
You can visually inspect some defrost heaters to see if there is a break. If it looks physically broken, then it needs to be replaced. Otherwise, check the defrost heater for continuity.
The defrost thermostat, which is just a bi-metal switch, lets current pass through at factory set temperatures. It also prevents current from passing through at the temperatures set by the factory. The set temperatures for the defrost thermostat vary from manufacturer to manufacturer.
You can test the defrost timer by manually advancing to the defrost cycle. You can usually manually advance this timer with a screwdriver. Insert the screwdriver into the advancement pinion and turn clockwise a 1/4 to 3/8's of a turn. The timer should advance out of the defrost cycle in less than an hour.
If, after testing these components, it still does not cool properly, there may be a problem with the refrigerant level and you will need to contact a professional appliance repair person.
Posted on Sep 08, 2008
Freezer forming ice stalagtite under ice tray
Sounds like the ice maker is allowing too much water in to the tray. There is an adjustment screw under the front cover of the ice maker. A 1/8 turn at a time counter clockwise will shorten the time the water delivery solenoid is open. It is possible that something foreign is keeping the solenoid valve to stay open too long, so it should be inspected too.
Jul 28, 2017 | GE Profile PSS26PSTSS Stainless Steel...
I bought a maytag side by side in 2002; model # MSD2454GRQ, SN 18157432AL, REV # 18. Ice is forming at the bottom of the maytag freezer department. Overnight ice will form at about 1/8 inch and left has...
Defrost problem: 3 components. Defrost Heater. Timer (circuit board or motorized) & Thermostat.
Remove cover on the inside back wall (usually 6 screws). Note frost pattern. (bottom of evaporator coil)
Put refrigerator into defrost cycle and note the defrost heater come on, or not. (careful heater can glow red hot)... Unplug Frige and test defrost components. Replace bad component... Refrigerator should defrost every 8 hours. when the cycle slows or quits the freezer will freeze over the evaporator coil and no air flow = no cold air...
Nov 15, 2010 | Maytag MSD2756G Side by Side Refrigerator
Hotpoint CTF15ELD top freezer refrigerator - freezer O.K. refrig too warm
It's likely the door was inadvertently left open, and the cold air passages from the freezer have built up enough ice that the cold air from the freezer has no way to enter the refrigerator. Check the cealing of the refrigerator. If you can see or feel ice in the passages between the freezer and fridge, you can probably solve the problem by finding a safe temporary home for your food, and leaving the refrigerator unplugged overnight.
May 25, 2009 | Hotpoint HTS16HBR Top Freezer Refrigerator
Ice on bottom of the freezer
Your drain is blocked causing the ice in the bottom of the freezer.
The drain is located about 7 inches up from the bottom rear of the freezer.
Just below the back freezer panel.
Turn the fridge OFF.
Remove the bottom bins.
Take a hair dryer and thaw the ice in the drain.
Pour 1/4 cup of bleach in the drain line.
Problem solved.
Feb 24, 2009 | Maytag 25.6 cu. ft. Wide-By-Side...
Icemaker making too much ice & Freezer frosting up.
Hi gpss,
It sounds like you are getting large amounts of warm moist air into the freezer. This can be caused by the door being left cracked open or the door seal not sealing properly. Check your door gaskets on both sides of the refrigerator. One other possible is the ice chute. If it is not closing all the way it will cause the same problem. You will get alot of frost forming in the freezer then it will melt when the refrigerator defrosts. Let me know if this helps, and if you have anymore questions.
Mike
Sep 30, 2008 | GE GSH25JSTSS Stainless Steel Side by Side...
Flat ice forms at the bottom of the freezer compartment
check your freezer door see if it (ajar) what you can do if you can unplug unit clar drain with hot water then get apiece of shave wire hook on the defrost heater and put in drain line 1/8 in the drain line put back wall back together and plug unit in
Apr 07, 2008 | GE Profile 21.6 cu. ft. Side-by-Side...
Kitchen Aid Model KBLC36MHS01
The drain under the evaporator is frozen/plugged.  You can take the back panel inside the freezer off and run hot water down it to thaw it out completely and this will solve your problem.
Oct 17, 2007 | Refrigerators
Ice forming in bottom of freezer
Rita, your drain hole is frozen over and when your refer goes into defrost the water is running out into the cabinet instead of down the drain hole. Remove the evaporator cover and poor some boiling water in the evaporator drip pan. This should melt the ice and clear the drain hole....Catriver...post back.
Aug 16, 2006 | Frigidaire FRS26KF5C Side by Side...
Refrigerators Logo
217 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
