Question about Science & Laboratory
Unlock problem with OHS1
Have a OHS1 surgical microscope that will not unlock for movement when you activate the switches on the hand control. I can here what sounds like a relay in the base unit, but none of the head joints will unlock.
Found bad 12.5A fuse in base. Replaced fuse and problem was solved.
Posted on Sep 09, 2008
1999 blazer Doors lock and unlock even when parked, help
Lock an unlock by them selves ? Door locks are computer controlled ,by the BCM - body control module .
Power Door Locks Circuit Description
The power door lock system includes the following components:
• The door lock actuators
• A door lock relay
• An door unlock relay
• A driver door unlock relay
• The door lock and side window switches
• The body control module (BCM)
• The endgate lock cylinder switch /liftgate lock cylinder switch (utility)
• The keyless entry, if equipped
The door lock and liftgate mechanisms may be controlled by the following switches:
• The BCM
• The endgate lock cylinder switch / liftgate lock cylinder switch (utility)
The following locking functions are included on the vehicle:
• All the doors unlock -- All the doors will unlock, including the endgate/liftgate, when any power door unlock switch is detected. The passenger doors lock directly by pressing the lock switches. The driver door unlocks by the BCM using a driver door unlock relay.
• All the doors lock -- All the doors will lock, including the endgate/liftgate, when any power door lock switch is activated. All the lock actuators will activate directly from the power door lock switch (external to the BCM).
• The end/lift gate lock switch -- All the doors will lock or unlock from the end/lift gate lock switch.
• The lockout prevention -- This function will prevent the doors from automatically locking if the keys have been left in the ignition and the power door lock switch is operated.
The motor is protected by a built-in electronic circuit breaker (ECB). If the motor is overloaded or voltage is applied for an excessive amount of time, the ECB internal resistance increases, essentially creating an open circuit. The resistance returns to normal only after voltage is removed from the circuit, thereby restoring circuit continuity.
You have a bad switch input to the BCM !
Door lock acting up 2005 Chevy Malibu fix it here
Door Locks Go Crazy 2
Jan 07, 2018 | Cars & Trucks
2007 Saturn ion 3 door locks fuse location
Power door lock's are controlled by the BCM - body control module . Are you familiar with automotive electronic's ?
Door Lock System Components
The power door lock system consists of the following components:
• Driver door lock switch--Uses a single signal wire for both lock and unlock switch activations
• Front passenger door lock switch--Uses a single signal wire for both lock and unlock switch activations
• Body control module (BCM)--Class 2 module which requires programming when replaced
• Reversible door lock actuators in each of the doors
• Body control module PWR 15A fuse--Located in the body control module fuse panel, supplies power for the door lock system
Door Lock and Unlock Operation
The BCM PWR fuse supplies battery positive voltage to the BCM for the door lock system.
The BCM supplies and monitors a reference voltage to the door lock switch through the door lock switch lock/unlock signal circuit. The door lock switch also receives a constant ground source. If a door lock switch is placed in the lock position, the reference voltage is taken directly to ground and the BCM senses 0.0 volts on the signal circuit. If a door lock switch is placed in the unlock position, the reference voltage is taken to ground through a 1.5K ohm resistor that is internal to the door lock switches and senses approximately 2.9 volts on the signal circuit. This is how the BCM determines what portion of the door lock switch was activated.
The BCM, upon receipt of a door lock switch lock or unlock signal, will switch the appropriate door lock actuator control circuits to battery positive voltage. The opposing side of the door lock actuators are connected to ground internally within the BCM through the other door lock actuator control circuit and the doors will lock or unlock appropriately.
Vehicles without keyless entry have two internal drivers in the BCM to control the door lock actuators. All door lock and all door unlock. Vehicles equipped with keyless entry have three internal drivers in the BCM. Driver door unlock, passenger door unlock and all door lock. This is done to isolate the driver door lock actuator so it can be unlocked by itself using the keyless entry transmitter.
Nov 26, 2017 | Saturn Cars & Trucks
Where are the fuses for the power dock locks on a 2006 montecarlo06ss
DR/LCK fuse 25 amp . located in the I/P block
Fuse Block - I/P
In the right front kick panel
Power Door Locks System Components
The power lock system consists of the following components:
• Driver door lock cylinder switch
• Front passenger door lock cylinder switch
• Door lock actuators in each of the doors
• DR LK Fuse 20-amp
Door Lock System Controls
The Power Door Lock System is controlled by the body control module (BCM) and can be activated by any one of the following:
• A door lock switch lock or unlock actuation
• A door lock cylinder switch unlock actuation
• A keyless entry transmitter actuation
• An automatic door lock actuation (Personalization function)
• An automatic door unlock actuation (Personalization function)
Door Lock Operation
When the body control module (BCM) detects a transition of either of the door lock switches to the lock position, it switches the door lock actuator lock control circuit to voltage. Since the lock actuator unlock control circuits are at ground potential within the BCM, the door lock actuator motors transition to the lock position.
Driver Door Unlock Operation
When the body control module (BCM) detects a transition of either of the door lock switches to the unlock position, it switches the driver door lock actuator unlock control circuit to voltage. Since the door lock actuator lock control circuit is at ground potential within the BCM, the left front (LF) door lock actuator motor transitions to the Unlock position.
The driver door lock actuator unlock control circuit is a dedicated control circuit used only for the driver door lock actuator motor. This is done so that the driver door may be unlocked by itself using a keyless entry transmitter or an automatic door unlock function (if programmed).
Passenger Door Unlock Operation
When the body control module (BCM) detects a transition of either of the door lock switches to the unlock position, it switches the door lock actuator unlock control circuits to voltage. Since the door lock actuator lock control circuit is at ground potential within the BCM, the passenger door lock actuator motors transition to the unlock position.
The door lock actuator unlock control circuits are dedicated control circuits used only for the passenger door lock actuator motors. This is done so that the driver door may be unlocked separate from the passenger doors using a keyless entry transmitter or an automatic door unlock function (if programmed).
Mar 23, 2017 | 2006 Chevrolet Monte Carlo
2005 Chevy Equinox Driver & Passenger Door Unlock Relay. How To Remove & Install. They Are Power Locks. Front Doors Must Roll Windows Down Use Hand To Open Thanks. Ms. J. C.
When a door lock switch is activated in the lock or unlock position the BCM will receive a voltage signal on either the door lock switch lock or unlock signal circuits.
The BCM, upon receipt of a lock switch lock or unlock signal, will switch the appropriate lock relay control circuit(s) to battery positive voltage. This will energize the appropriate lock or unlock relay(s). The relay will supply voltage to the door lock actuator lock or unlock control circuits to one side of the lock actuator. Since the opposing side of the lock actuators are connected to ground through the other lock actuator control circuit and the normally closed contacts of the lock or unlock relay, the doors and liftgate will then lock or unlock appropriately.
Three relays are used to operate the lock. Driver door unlock, passenger door unlock and all door lock. This is done to isolate the driver door lock actuator so it can be unlocked by itself using the keyless entry transmitter.
Your door locks are controlled by the BCM - body control module (a computer ) . An a scan tool is a must to diagnose system operation . Your best bet would be to take your vehicle to a qualified repair shop . The only way you could try to fix this is by changing parts ! Suppose you find an replace a door lock/ unlock relay an that doesn't fix it ? There could be DTC'S stored in the BCM . Do you know what a DTC is ?
DTC B3132 All Door Unlock Circuit Low
DTC B3133 All Door Unlock Circuit High
Your
Aug 10, 2016 | Cars & Trucks
Why does my 2004 Chevy Silverado lock and unlock while in drive? When turned off and no keys in ignition the drivers door will unlock on its own a short time later.
Gremlins ! HA HA HA sorry ! First off a little bit on how they work an what all is involved in making them work ! There are a few control modules in the mix , switches ,relays etc...
The driver door module (DDM)
The passenger door module (PDM)
The driver information center (DIC)
The rear door lock switch
The door lock relay
The door unlock relay
The liftgate lock relay--utility vehicles with liftgate only
The reversible door lock actuators in each of the doors and liftgate
LOCKS 20A fuse (rear lock/unlock relay supply voltage)
ECC 10A fuse (liftgate lock relay supply voltage)
The power door lock system can be controlled by any of the following:
A power door lock or unlock switch activation
A keyless entry transmission
An automatic door lock function
A delay lock function
Door lock cylinder switch activation
Lockout Prevention
An airbag deployment
The front power door lock switches are integral components of the driver door module (DDM) and passenger door module (PDM). The switches are two position normally open rocker switches. When placed in either the lock or unlock positions, the switches provide a direct input to the DDM or PDM. The DDM or PDM monitors these inputs and sends a Class 2 message indicating a change in the switch's respective position. Modules which activate the power door lock motors receive the Class 2 message and activate the motor in the appropriate direction to lock or unlock the vehicle's doors and liftgate. The rear door lock switch provides a lock and unlock signal to the body control module (BCM). The BCM upon receipt of a lock or unlock signal will control the rear door lock relays and also send a Class 2 message to the DDM and PDM to perform the appropriate function.
The modules which activate the power lock motors are:
The DDM (driver door lock actuator).
The PDM (passenger front door lock actuator).
The BCM (both rear door lock actuators and cargo door/liftgate).
The DDM and PDM are directly connected to the respective door lock actuator through the door lock motor lock and unlock circuits. Once a door lock or unlock request has been received, the module will supply battery voltage to one side of the actuator and ground the other causing the doors to lock or unlock.
The rear passenger and cargo doors differ slightly in that they use lock and unlock relays. The relays supply and coil sides receive a constant voltage through the battery voltage supply circuit. The normally closed contacts are connected to ground and the control side is connected to the BCM. Once a door lock or unlock request has been received by the BCM, the BCM will ground the control side of the appropriate relay. This energizes the relay and allows voltage to be applied to either the door lock motor lock or unlock circuits. since the other side of the door lock actuator is connected to the normally closed contacts of the opposing relay to ground, the doors lock or unlock.
The first place to start is have a factory or equivalent scan tool hooked up , one that can read BCM DTC'S - diagnostic trouble codes ! This could lead to a fix faster ! Watch these three videos !
Door Locks Go Crazy 1
Sep 16, 2015 | Cars & Trucks
Why won't the passenger door unlock?
An automatic door lock or unlock actuation
A last door closed locking (LDCL) actuation
If the driver door cylinder switch feature of the vehicle is functional, the locks may also be operated by a driver door cylinder switch lock or unlock activation.
Power Door Lock Switch Operation
Each door lock switch is wired to the body control module (BCM) through a separate door lock/unlock signal circuit. While these circuits are separated between the BCM and respective door lock switch, they are connected into a single circuit within the BCM. The BCM supplies voltage through the door lock/unlock signal circuits to each door lock switch. When either door lock switch is operated, this supply voltage is pulled to ground, providing the BCM with the required lock or unlock signal. In order for the BCM to distinguish between a lock and unlock signal, the lock switch contains two separate paths for this voltage to flow to the same body ground. When the switch is operated to the unlock position, the supply voltage flows to ground through a 1.5 K?© resistor. When the switch is operated to the lock position, the supply voltage flows to ground through a different part of the switch circuit, which has no resistor. The BCM then interprets the flow of voltage as a lock or unlock request and powers the door lock actuators to the appropriate lock or unlock position.
I'll post a youtube video on how to test the power door locks computer controlled , check it out ! Your problem could be a switch or the lock actuator , BCM , wiring etc.... you need to test it to see !
I'll
How to test computer controlled door locks
Mar 22, 2014 | 2008 Saturn Aura
2004 chevy malibu driver and passenger door lock problems
The locks on your vehicle are electronically controlled by the BCM - body control module . The driver an passenger door switche's are input's to the BCM . Do you know anything about automotive electronic's ? anti theft alarm remote, could this be part of the problem , No it's just a key less entry remote , nothing to do with the anti-theft .
The Power Door Lock System consists of the following components:
• IBCM (PWR) 15-amp fuse
• A door lock switch Lock or Unlock actuation
• A last door closed locking (LDCL) actuation
Driver and Passenger Door Unlock Operation w/o Keyless Entry
When the body control module (BCM) detects a transition of either of the door lock switches to the Unlock position, it switches the door lock actuator unlock control circuits to voltage. Since the door lock actuator lock control circuit is at ground potential within the BCM, the driver passenger door lock actuators transition to the Unlock position.
Your best bet , take your vehicle to a qualified repair shop ! Need special tool to diagnose .
Power Door Locks Inoperative
Install a scan tool.
Turn ON the ignition, with the engine OFF.
With a scan tool, observe the door lock switch parameter in the Doors data list.
Does the scan tool display Idle?
YES - Go to Step 4
NO - Go to Step 8
Activate the driver door lock switch to the LOCK and UNLOCK positions.
YES - Go to Step 9
NO - Go to Step 5
5
Activate the front passenger door lock switch to the LOCK and UNLOCK positions.
YES - Go to Step 9
NO - Go to Step 6
6
With a scan tool, observe the driver door lock actuator command and the passenger door lock actuator command parameters in the Doors data list.
Activate a door lock switch to the LOCK and UNLOCK positions.
Dec 24, 2017 | 2009 Chevrolet Malibu
How do i get free unlock code for g1 google phone
Dear,
  • 1. Side out the Keyboard / Open Left Hand side Notch to unlock Battery Panel.
  • 2. Insert TMobile SIM Card and Battery.
  • 3. Press MENU Button Constantly and Switch the Phone using Red Talk End / Power Button but do not Release the Menu Key.
  • 4. This will put on the Phone in Safe Mode.
  • 5. Press to Emergency Dial Button, Windows dial *#06# and this will show IMEI Number: note it down and also Recheck IMEI with Box.
  • 6. Give IMEI to Unlock Code Provider www.unlock-tmobileg1.com and get the Unlock Code.
  • 7. Now Return to main Screen and Press MENU Button this Will popup APN Button, Just Press it.
  • 8. Go to APN Setting. There will be so many APN already Preset. Again Press MENU Button this will show NEW APN Popup Button again Press.
  • 9. Remember to put Right MCC (Mobile Country Code), and MNC Mobile Network Code, G1 Matches SIM card Data of MCC / MNC with these Setting and then try to use that. Settings.
    All World MCC / MNC codes is available here:
    http://en.wikipedia.org/wiki/Mobile_network_code
  • 10. Now Switch off the Phone and Wait for Unlock codes.
  • 11. Insert the Non T-Mobile SIM Card which you intend to use it with G1 and switch G1 on. (Your SIM must have
    Data plan / GPRS Activated so G1 will able to contact google.com for Activation)
  • 12. HTC G1 will ask for Unlock Codes. Type unlock code carefully, typing wrong code thrice may make Phone Hardware Locked.
  • 13. Once Unlocked your GPRS / EDGE / 3G Data Service will be active as per APN Setting we did before.
  • 14. Type Google User name / Password in Signing Window and this will Activate the Unlock G1 Device on your SIM Card.
  • 15. Make other remaining Data Setting like MMS / Home Page / Port to Active other Data Service
Thanks
Sep 14, 2010 | HTC Google G1/Dream Cell Phone Black...
Disconnecting the alarm, drivers door lock does not work, unable to turn key.
Disconnecting the Imobilizer will not unlock your Lock/Key assembly. You should be able to manually unlock your car with your key. The Imo will only activate when it's been breached illegally but it doesn't prevent you from opening the lock manually. Your lock assembly maybe malfunctioning and regardless what state it's in the IMO doesn't control it's mechanical movement.
Feb 28, 2010 | Volkswagen Golf Cars & Trucks
Remote key fob will not work-battery replaced
VW/AUDI/SEAT/SKODA
Remote Control Programming (1997 ON)
Procedure
1. Switch Ignition ON and leave the key in the ignition.
2. Mechanically lock the vehicle using the Drivers door using a second
key.
3. Using the remote control press the Unlock button once, and the horn
will sound once.
4. Wait 6 seconds and press the unlock button once to activate the coding
procedure. The remote control will now be programmed.
NOTE : When performing programming on additional remotes the procedure
is the same, except you press the unlock button 2, 3 or 4 times for the
different remote.
For example : If programming 2 remotes press the unlock button twice with
a 1 second interval between each press, repeat for 3 and 4 remotes.
5. Switch Ignition OFF.
6. Remove key from ignition and check for operation.
7. The coding procedure can be repeated up to 4 times for additional remotes.
8. The ignition must be switched OFF between programming each remote
control.
Remote Control Erasing (1997 ON)
Procedure
key.
3. Press the remote control unlock button 5 times in 1 second intervals.
A short horn will sound.
4. Wait 6 seconds and press the unlock button once to activate memory
erase.
5. Switch ignition OFF, all remotes are now erased.
Dec 24, 2008 | 2004 Volkswagen New Beetle Convertible
Science & Laboratory Logo
160 people viewed this question
Top Science & Laboratory Experts
Gareth Cockram
Gareth Cockram
William McMath
ray gallant
Are you a Science and Laboratory Expert? Answer questions, earn points and help others
