Question about NorStar T7316E Corded Phone
Lines 4 and 5 in use.
I have lines 4 and line 5 showing as inuse. I know they are not in use, and I am not sure how I managed to get them that way. I've seen a thing saying unplug the cabinet, but I am concerned that it will erase the programming of the system/voicemail etc. Can anyone advise?
  • charleenshaw Apr 08, 2009
    I tried that and it didn't work so what can I do now.
  • NorStar Master
  • 2,460 Answers
One of the annoying features of a Norstar is the auto hold. If you switch from line to line, you put the calls on auto hold. It doesn't take much to conference two lines together and drop out of the call. Now you're at the mercy of the Central Office as to whether it sends a disconnect to drop the lines.
Two bad things that we advise customers to unplug the system is when they have mystery lines tied together and/or external paging tied up. That drops all current connections and lets you start again.
Carl
Posted on Sep 08, 2008
Vertical lines
I would contact customer support and find a manager.
Make him aware that they are dropping the ball.
They are giving you back usede problem equipment.
May 23, 2014 | Samsung UN46C7000WFXZA - 46in Led Hdtv...
Panasonic kx-t7630. PABX lines have been reducede from 5 to 3. how can re assign CO buttons? now line 2 and 5 are no more in use, but still show as free. And if I press usual 9 to get outside line it...
If you know how to do system programming, the best thing to do is to move the lines into the first 3 positions on the cabinet and go into system program 600 and reduce the lines to 3. Your system installer or manager may be able to do the programming in less than 30 minutes.
Carl
Oct 21, 2010 | Panasonic KX-T7630 Corded Phone
I was informed to blow the carbon from my gas lines,there are 4 lines and I don't know if it is all 4 or just two lines. I have a 2004 hyundai sonata, difficulty putting gas in car and right after car...
This isnt a job for you. Whoever replaced the canister should have assured all the lines were clear. You want to take ALL of them off and confirm all are clear. make sure the vent valve is operating.
Aug 26, 2010 | Hyundai Sonata Cars & Trucks
Polycom SoundPoint 550-Only Showing 1 line
On the phone, press the menu button, then status, then IP status or whatever and get the phone's IP address. Write the ip address down. On your computer, open up a web browser and input the phone's IP address into the address bar and press enter. This should arrive you at the web gui for that phone. It'll probably ask you for login credentials; by default, the name is "Polycom" (yes , it is case-sensetive) and the password is 456. Once you are logged in, you should see several links like "General" "Network" "Sip" and "Lines". click on Lines. under "line 1", you will see the configuration for that line. simply duplicate the entries for lines 2, 3, and 4.
Jul 29, 2009 | Polycom SoundPoint IP 550 IP Phone
Line buttons showing wrong phone lines
When a phone has only 2 lines, it's not programmed. By default, a Nortel system has 2 lines and that's all. Go into system programming and assign the number of lines and intercoms to a phone. After that, you can copy the buttons from a working phone to the new phone and you're done.
Carl
Jun 22, 2009 | NorStar Meridian M7310 Phone
SMDR not showing all CO lines
i will making tda-200 ext and co lines cable
Mar 16, 2009 | Panasonic (KX-TDA200)
Second line not working
The phone will show that "line in use" message when it's not connected correctly.
If your two phone lines come in to one jack, make sure you are using a 4-wire line cord connected to the "line 1 and line 2" jack on the phone. You may be using a 2-wire cord so the second line isn't reaching the phone.
If the two lines are on separate jacks you need to connect line 2 to the separate "line 2" jack.
If you know for a fact that both lines are properly connected to the phone and it still doesn't see the second line, then it's time for a new phone.
Dec 10, 2008 | AT&T E2562 Cordless Phone
Printing thick black lines in copies from the automatic document feeder but not from the scanner
You can remove the plastic knob by pulling it gently forward and disconnecting it to clean inside and then reconnecting and closing again.
Jul 29, 2008 | HP Officejet 5610 All-In-One InkJet...
2 parallel lines show up on the copies
try to clean the cover glass at the top of the copier with alchol.
be sure that ther is no any dot or lines on top of tha glass specialy the right side.
Apr 11, 2008 | Sharp AL 1631 Copier
Vertical Lines of Sony Bravia 46
IT CAN BE FIXED BUT NOT BY YOU
BOARDS NEEDS TO BE REPLACED OR RIIBON CABLES NEED TO BE RESEATED. YOU CAN DEAL WITH A SERVICE COMPANY(NOT ALL ARE AS GOOD AND KNOWLEGABLE AS THE ONES YOUR READING HERE)
OR EXCHANGE IT
YOUR CALL
Feb 21, 2008 | Sony BRAVIA KDL-46V3000 Television
NorStar T7316E Corded Phone Logo
254 people viewed this question
Top NorStar Lands Phones Experts
Oloyede Monsuru
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
